Vinyl wires-HELP!!
Vinyl wires-HELP!!
Posted by Anonymous on Saturday, May 10, 2003 9:07 PM
Greetings y'all!
I have been working on an old IMEX H-D kit for a while now and I have a bit of a problem. The vinyl wire used to replicate hoses does not like plastic cement. I prepped the plastic parts, de-chromed, washed and dryed. I test fit before I glued. But when I put a small drop of glue inside the hose and attached it over the nib and held it for 30 sec or more, THE $@#%^$& HOSE KEEPS FALLING OFF!!!! I have almost melted the plastic nibs completely attempting this! What am I doing wrong? I tried superglue as well but it may have been to old; it didn't work either.
Posted by Anonymous on Saturday, May 10, 2003 9:36 PM
I had the same problem with an old '57 Chevy Bel Air I was working on. I ended up using a pin vise drill and drilling out the nibs just large enough for the wires to slip into. A bit of putty around the wires will re-simulate the posts.
Hope this helps...
demono69
Posted by Anonymous on Sunday, May 11, 2003 3:21 AM
The vinyl is more like insulation, hollow inside. I guess I could cut off the nibs and then drill a hole in the part for the hose to slip into, but I don't want to damage this thing anymore than I already have!
Posted by midnightprowler on Sunday, May 11, 2003 6:02 AM
Like was already mentioned, drill a hole part way in, and use superglue. It should work quite well.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Holley on Sunday, May 11, 2003 6:15 AM
Try drilling the nib out to fit a wire in that is the same diameter as the inside of the vinyl hose. Then press a small length of wire into the hole you drilled, secure with a drop of 5-min. epoxy and then the vinyl hose will press fit over the end of the exposed wire.
Holley When all else fails, read the instructions!
Posted by Anonymous on Sunday, May 11, 2003 10:23 PM
Thanks folks, that helped a lot. I will try your suggestions when I get back home-work is so overrated, but is does allow me to buy models.....
Posted by FITTER on Monday, May 12, 2003 7:27 AM
Holley's idea of drilling the plastic for a piece of copper wire the right size to push the vinyl "hose" onto is a good one. What I found out long ago while building armor models is that those vinyl tank tracks can be a real bear to keep together. I got ahold of some of that vinyl swimming pool repair cement; it seems to hold quite well to the vinyl. BE ADVISED: it *may* adversely affect styrene, so test for compatability first on a piece of sprue. Be sure and work in a well-ventilated area with this stuff.
Good luck. Big Smile [:D]
FITTER
IBTL
