Die-cast paint?
    May 2003
Die-cast paint?
Posted by klem on Saturday, August 30, 2003 1:20 PM
I stripped an 1/18 die-cast Civic and I'm repainting it. Any suggesstions on brands of paint and methods of application would be appreciated. I'm looking to get a deep metallic paint finish, almost transparent.
"We the unwilling, led by the unknowing, are doing the impossible, for the ungrateful. We've been doing so much for so long with so little we are now capable of doing anything with nothing." Unknown
    January 2003
Posted by leemitcheltree on Sunday, August 31, 2003 9:50 PM
Klem,
I always use automotive acrylic to respray die cast models.
It dries very hard, very quickly, and can then be polished using normal automotive polishes and waxes.
I buy spray cans of automotive touch-up paint which have been mixed to manufacturers specs - easy to get the right color.
I've also had specific colors mixed to manufacturers specs (the Poscher 1/6 F-40 and their Testarossa).
I almost never sparay out of the cans - too much orange peel.
It's easier to control the amount of paint you apply by using an airbrush. I use a short length of drinking straw to spray from the can into my airbrush jar. It's very easy to get perfect (or almost) results everytime. Just experiment a little with the correct thinning ratios for whatever paint you're using.
I always spray at around 15-20 psi - and as I get closer to the final topcoat, I use less paint and more thinners - allowing more drying time in between coats.
Liquid paint from a can requires far more thinning than paint from an aerosol spray can.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by proosen on Monday, September 1, 2003 3:55 AM
Hi Klem!
You could try to use nailpolish if you want to try something different, the backside is that it's smells quite strong and needs a basecoat of some sort. Gold, silver, copper or some ohter appropriate coulor.
Good luck!
Niclas
