Recommend a resin casting kit
    May 2013
Posted by R-4360 on Tuesday, January 7, 2014 8:05 PM
I need to cast several engines (8). I'm about halfway done with the original. Micro Mark has a nice all in one kit, but it's $100. Tell what you use & about what the whole setup costs....
Scott
    May 2013
Posted by R-4360 on Tuesday, January 7, 2014 8:07 PM
Posted by Don Stauffer on Wednesday, January 8, 2014 10:09 AM
The one that I started with was from a company that I don't see ads for anymore.  Don't know if they went out of business or what.  However, once I went through the stuff from that kit, I now buy the RTV mold material and the casting resin individually when I need it.  I buy the stuff from Micro Mark. The main supplies you need are the RTV mold material and the casting resin.
Resin casting takes some practice, and there are tricks. I suggest researching old articles from FSM (including one of mine, but can't find issue now).  Biggest secret is mold design.  Think like an air bubble and figure ways you would not be trapped in mold. I suggest you be careful designing pour sprue and vent tubes.  Never bring pour sprue into top part of mold cavity.  Air trying to leave will collide with incoming resin.  Make pour sprue J-shaped entering bottom of cavity.  Provide a vent tube from every local high point in cavity.  Make mold vertical with extended top so pour sprue has a considerable distance above highest point in cavity (this creates hydraulic pressure head).
If you design the mold right you can get quite decent castings without buying a vacuum pump.
Posted by Don Stauffer on Thursday, January 9, 2014 9:19 AM
Couldn't remember the name of  the company I was referring to in the above post, but my slow aged memory finally came up with it- Ace Resin.  I do not see ads for Ace Resin any more. Their kit was very similar to the one sold by Micro Mark.  Price was lower, but that was nearly twenty years ago so I assume inflation would make it similar.
    May 2013
Posted by R-4360 on Thursday, January 9, 2014 7:46 PM
Thanks Don, I just needed input before dropping $100 on the Micro Mark setup. I don't mind spending money on something that works well, I just hate to spend  money on a product not knowing if it's any good!  I know we've all got countless tubes of glue & putty that we didn't like.
Scott
Posted by Don Stauffer on Friday, January 10, 2014 9:03 AM
The big expenses if you don't buy the set are the RTV and the resin.  Together you are talking about around 70 bucks, so you get the rest of the stuff for the remaining thirty.  I know the RTV is expensive, but do not scrimp on it and make the mold too small.
There is a new material that is re-usable- it can be melted down after use and re-used for a new mold but the few reviews I have seen so far indicate there are some limitations, so I am afraid to use it.
Posted by Bucksco on Friday, January 10, 2014 9:11 PM
Check out Smooth-on. Best casting supplies I have found.
http://www.smooth-on.com
    September 2010
Posted by retdfeuerwehr on Thursday, February 20, 2014 2:17 PM
Any idea what the shelf life is of this stuff?
Posted by Don Stauffer on Friday, February 21, 2014 9:28 AM
I know I have used resin and RTV that is at least a year old. Important for the resin- mix it well in bottle before mixing! It seperates in bottle.  However, inverting the bottle a dozen times or so before pouring into mixing container will restore it.
    April 2013
Posted by Jack Reynolds on Saturday, May 24, 2014 12:59 PM
I use Amazing Products. Mold material $20.00, casting $15.00. Enough for several 1/8 Offys. From start to finished cast 15 minutes. Iv'e tried many others and none were close.
Jack
jackreynoldsmodels.com
