Bn2T Locomotive
MrT
    December 2010
Bn2T Locomotive
Posted by MrT on Tuesday, November 15, 2016 12:59 PM
Ok here is the plan.  I intend to use a paper model which I received today as a pattern and scratch build the little loco out of plastic, metal, or what ever else I can find.  So I guess we will see how this works out.  I have heard of ship modelers doing this so it ought to work for this.
Frame is coming together.....
Still plenty to do.
Progress on the frame....
Added some more rivets.....
Installed some of the brake parts.
Learning things as I go along like some holes don't need to be drilled or damage will occur.
The second locomotive will be better.
Building the locomotive wheels.
This is the assembly jig.
The wheels are built up in layers.  I have decided to go with a solid cast wheel instead of a spoke version.
On the frame.
I continued to work on the drive wheels for the "The Little Engine That Could".  Counter weights and driver offsets added.
I assembled most of the left side wheels.  I still need to add the driver cam's, but the loco is setting on all four drive wheels.
The wheels were pretty tough, but I'm sure there will be more challenges to come.
All the rivets are in and I have added part of the connecting rod assembly.
I'm still smoothing things out, but I think it will come around sooner or later.
The beginnings of a steam cylinder.
A mostly complete steam cylinder.  Ready to move to the other side.
Ok that brings us up to date.
Thanks for looking!  More to come.
Terry
    May 2009
Posted by Pawel on Tuesday, November 15, 2016 2:53 PM
Hello!
A nice idea, and the model is lookin' good so far! If you need some help with the translation from polish please don't hesitate to ask me. I've seen those loks built out of paper, too and they looked good. Of course those little details can look a little better done out of other materials. Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    October 2010
Posted by hypertex on Wednesday, November 16, 2016 8:51 AM
Super cool! I like trains, wish there were more train kits. I can't wait to see more.
Posted by Don Stauffer on Wednesday, November 16, 2016 9:21 AM
I want to scratch build a 1:24 Link trainer.  I had enough pictures and published measurements of the prototype to do a set of drawings, but then I found a 1:24 paper model of the Link.  That has sure eased the job.  I put the paper model together, and am continuing to work on the drawings.  I think paper models are a real boon to folks getting ready to scratch some subject!
MrT
    December 2010
Posted by MrT on Wednesday, November 16, 2016 4:07 PM
Pawel
Hello!
Paweł
Thank you Pawel
MrT
    December 2010
Posted by MrT on Wednesday, November 16, 2016 4:08 PM
hypertex
Yes not nearly enough.
Thanks
MrT
    December 2010
Posted by MrT on Wednesday, November 16, 2016 4:09 PM
Don Stauffer
They sure seem to be good place to start anyway.
Thanks for stopping by.
    June 2014
Posted by Tanker - Builder on Sunday, November 20, 2016 8:30 AM
Terry !
    Now you see why I use the Paper Models as patterns !
 As a train buff too , I laud your efforts here . The finished Locomotive ought be a stunner . You must keep at it ! Note; Did you know that for a time some engines and a lot of rolling stock ( Passenger cars ) rolled on compressed paper wheels ?
    Yessir . A fellow was trying to develop  a wheel that was lighter , but was just as strong . he found back in the thirties that if you compressed paper with Aliphatic resin to 5000 pounds per square inch , the resulting wheel with a steel tire could travel many rail miles before becoming to weak to use .
     The ones used on engines were rare , But , that's what yours look like . Good job .  T.B.         P.S. On some locos you can use thin wall P.V.C. Pipe for the basic tube for the boiler ! Also the holes you drilled could be filled with rivets made out of brass rod epoxied in place .The strength then wouldn't be an issue .
MrT
    December 2010
Posted by MrT on Monday, November 21, 2016 1:40 PM
Tanker - Builder
Terry !
Well I sure didn't know about the paper wheels....wow!
I have been considering pipe for the boiler.  Just been leaving that till later.  The connecting rods are next.
Thanks!
    June 2014
Posted by Tanker - Builder on Thursday, December 29, 2016 9:23 AM
Yeah Terry !
   I found that tidbit in a book about the famous passenger rail cars of the early years .
    Supposedly , one of the benefits was indeed a smoother ride !
MrT
    December 2010
Posted by MrT on Monday, February 20, 2017 8:45 AM
More locomotive progress.  Started on the connecting rods and springs.
Just a small update.  Thanks for looking.
MrT
    December 2010
Posted by MrT on Monday, February 20, 2017 10:51 PM
Before moving on some paint needed to be applied.
Cool
    May 2009
Posted by Pawel on Tuesday, February 21, 2017 6:56 AM
Hallo!
That engine started looking a lot better with some paint on - and it wasn't lookin' bad before, neither! In case of this project replacing paper with styrene seems to really make sense, although I've seen people building it out of paper, too, and with good results. Anyhow - good luck with your build and thanks for sharing, have a nice day
Paweł
www.vietnam.net.pl
Posted by Don Stauffer on Tuesday, February 21, 2017 8:48 AM
Looking really nice!
MrT
    December 2010
Posted by MrT on Wednesday, February 22, 2017 9:57 AM
Thanks guys!
