Materials , Hmmmmm;
    June, 2014
Materials , Hmmmmm;
Posted by Tanker - Builder on Sunday, February 03, 2019 9:09 AM
Hi;
     We are going to talk about materials today . What ?another lesson from the old phart ? Yup ! Are you ready? Well, here Goes .Whhether you build a kit or from Scratch , you need to make sure all your ducks are afloat and well . Referrences , Check ,P.E. ,Check . Kit ,Check, Ready work-space Check . Tools Check . Now here's the biggie .Do you have All your materials on hand ?
      What materials ? Well , let's See .The strip and sheet plastic you might need . Or how about the brass wire or gun barrels for instance . How about the right glues and paints ?
      Do you have the right set of tracks from Fruil-Model or your favorite provider? Do you have the right thicknesses of strip and enough for the job ?Do you prefer Evergreen or Plastruct for plastic? How about P.E. ? Tom's ? Gold Medal Models ? Eduard ?
   Can you lay your hands on all of it before you open the first session at the bench ?Well good you're ready . Now check the kit if that's where your starting .I am sure you caressed the parts long enough. Now get started .If your Scratching It , then layout the biggest parts first .Is it a ship ? Well are you going to built it with frames and keel or a solid structure ? See , there's a lot to think about .
 Now when you are comfortable that the first steps Can Be instituted then it's a fact .You have the materials . Happy Modeling ! T.B.
    May, 2009
Posted by Pawel on Sunday, February 03, 2019 12:47 PM
Hallo TB!
Why did you have to use the word "lessons"? I find it annoying. Wouldn't "editorials" be so much better here?
As for materials I like to have a lot of them, but when building I usually wait for a problem/challenge to form itself, and then I try to find a fittling material, as a solution. In the time it takes me to get the necessary stuff, I can always find something else to work on - like another part of the model, or another model.
Also, the material talk wouldn't be complete without a call to never throw anything away, as a modeller can always make use of it - some sunny day.
Thanks for reading and have a nice day
Paweł
www.vietnam.net.pl
    March, 2003
Posted by Tojo72 on Sunday, February 03, 2019 10:03 PM
No problems here,TB is just good old "Old School".He can give me lessons anytime he wants. Yes Yes Beer
    June, 2014
Posted by Tanker - Builder on Monday, February 04, 2019 8:25 AM
Tojo 72 -Thank You ,Sir !
    June, 2014
Posted by Tanker - Builder on Monday, February 04, 2019 8:26 AM
Pawel ;
 I did call them Lessons dint I ? My Bad LOL.LOL.
    April, 2005
Posted by ddp59 on Monday, February 04, 2019 9:13 AM
i don't use evergreen that often as i get a sheet of .040" 48"x96" from a plastic wholesaler cheaper then the same size evergreen & cut them into 12"x12" which would last me for years. i still have some left from my sample bundle that i got in the early 80's.
    November, 2009
Posted by Don Stauffer on Monday, February 04, 2019 12:02 PM
TB, you forgot the wood.  That is the only thing I don't get at the hobby shop.  I usually get it at Menards.
    September, 2012
Posted by GMorrison on Monday, February 04, 2019 12:15 PM
woodworkerssource.com
The local Home Depot has a good selection of 1x various widths of a pretty broad range of species. I bought 5 lf of 1x3 red oak over the weekend for $ 10.
You can see my little table saw over in my post in "saws".
It's not really up for cutting thick pieces of oak, but it sure handles basswood and cherry.
    September, 2012
Posted by GMorrison on Monday, February 04, 2019 12:18 PM
On the subject of sheet plastic, I tried the tip of using those "FOR SALE" signs. A lot of negatives. The ones I tried had a pebbly surface. Very fine but not at all what I needed. The graphics were some kind of printed material that had thickness and was darn near impossible to hide with primer. And it ran close to $ 10/ sf. which was no deal.
Having big sheets of styrene is very helpful.
    May, 2009
Posted by Pawel on Monday, February 04, 2019 2:00 PM
Here in Poland those signs are made from some plastic different than styrene - which is bad because the plastic glue doesn't melt them, you have to glue them with CA. As GMorrison mentioned, the print on one side is thick and resistant (very important for a good quality sign!). Because of that I only used the sign material for internal structure bracing. Lots of cheap styrene sheet - that's definitely good thing to have. One source for me, although not big pieces, are food packaging, disposable trays, sushi and ice cream containers - those have some good, thin sheet (0,2 - 0,5mm).
Good luck with your modelling projects!
Paweł
www.vietnam.net.pl
    June, 2014
Posted by Tanker - Builder on Thursday, February 07, 2019 4:34 PM
Hi Don .
Actually I did not mention it on purpose . Wood is where I started .I think most of our generation did .So I accepted that as a given .T.B.    Don , I recently got some nice model railroad items for our museum .From of all places MENARDS!!
    February, 2019
Posted by Hirnsausen on Monday, February 11, 2019 9:29 PM
In what kind of shops can I (hopefulyl) get strip and sheet plastic? And what tools do you use, to cut those?
    April, 2005
Posted by ddp59 on Tuesday, February 12, 2019 12:40 PM
hobby shops, plastic wholesalers. can cut using hobby & utility knives.
    February, 2019
Posted by Hirnsausen on Tuesday, February 12, 2019 6:08 PM
Thanks!. Not here in Jamaica. :-) No such shops.
What are the sizes for sheet plastic? I might have to order online, and get some people to bring it for me to jamaica, or by mail.
    November, 2009
Posted by Don Stauffer on Wednesday, February 13, 2019 9:40 AM
Hirnsausen
For straight lines I score with an X-acto knife, then bend along scribe line till it breaks.  For curved cuts I use a good pair of scissors.  I have used tinsnips for really thick sheets, though I have a bandsaw that I ordinarily use for 1/8 and thicker.
 I have delt with the three sources ddp mentioned, had good luck with all three.  I find a good supply of plastruct and evergreen at my local hobby shop, so only order from those rarely.
    June, 2014
Posted by Tanker - Builder on Wednesday, February 13, 2019 4:07 PM
Hi Fellow :
 Listen , You can mail order Evergreen sheet and strip Plastic and one of their catalogues .Their ad is in FSM . Also consider Plastruct . That is a good brand , but specify their Styrene products .They mostly produce in another type . The same with knives Blades etc . Do yoy have hardware stores there ?I don't remember seeing any there ! T.B.
    February, 2019
Posted by Hirnsausen on Thursday, February 14, 2019 10:42 AM
Very warm thanks to all answerers here! Smile
Your answers do help me a lot, I am going to order online the plastic items. I hope to find some good scissors here in Jamaica, and yes, we have here a number of hardware shops. They might not have the same product bandwidth as in First World countries, but I surely can get knifes there.
Can styrene be used to buld room walls and be glued together with plastic glue? Can enamel paint be used on styrene? Or is ABS better? No experience yet with scratch-building...
This all is for my ship, I want to add scatch-built elements to it:
http://cs.finescale.com/fsm/modeling_subjects/f/7/t/181201.aspx
    June, 2014
Posted by Tanker - Builder on Thursday, February 14, 2019 12:10 PM
Hi !
 First off , if you use styrene sheet you most certainly can use styrene glue for every part of it .Parts of different material can be assembled with super Glue in it's many forms .I would recommend if you are just starting out to use the little containers of " Gel " type super Glue .It works great !
  There are many brands of styrene glue .If you can't find them then M.E.K. can be used , but use in a well ventilated room and use sparingly on the joints . T.B.
    February, 2019
Posted by Hirnsausen on Thursday, February 14, 2019 12:13 PM
No styrene glues here in Jamaica. I would have to import that glue (takes 1 to 2 months each time and is incredibly expensive). Can plastic model glue be used?
    April, 2005
Posted by ddp59 on Thursday, February 14, 2019 1:48 PM
styrene plastic is of the same type of plastic that is used to make all of our model kits. i use regular Testors red & white color tube plastic glue for both model kits & scratch built ships with no problems. check this link. https://www.sunwardhobbies.ca/cement-for-plastics-models-testors-3501/?gclid=EAIaIQobChMI8e6L5f674AIVQh1pCh075gXAEAQYASABEgJBm_D_BwE
 what size room walls are you talking about?
    February, 2019
Posted by Hirnsausen on Thursday, February 14, 2019 8:22 PM
It is for an N scale (1/160) ship cabin. The walls would be 1.5cm (15mm) tall, and just a few centimenters long.
    April, 2005
Posted by ddp59 on Thursday, February 14, 2019 11:05 PM
it will work depending on the sheet plastic's thickness. i usually use .040"(1mm) plastic in my modelling projects like in this link http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=165105
my superstructures for my big 1/144 scale warships use that same plastic thickness without a builtin support frame. my biggest 1/144 warship is HMS Warspite with a length of about 52" with a balsa frame skinned with .040"(1mm) plastic plates.
