SNOOPY wrote: |
Would it be considered cheating if I draw up some shop drawings and went to a machine chop to have them made and then just assembled everything? Not sure how much this all would cost but I do not know any other way. |
It would not be considered cheating to do so. When you build a plastic model kit, someone makes the plastic parts for you, then you assemble them, and that isn't cheating, so this is no different.
However, it will probably be quite expensive to have a shop make the parts for you. I would suggest that you look at the model in an "exploded" view in your mind. Try to break it up into its simplest components. Draw out each component to see how they will interact with its neighboring parts. Once you do that, the challenge of hand-making each part seems less daunting, and more fun.
By the way, I just visited the Starfleet Museum for the first time the other day, it's way cool!
