I need to build an in-flight refueling probe for this kit. Does anyone have one that they may be able to give me some measurements from?
Semper Fi
4.6cm overall length...including the shroud that the tip fits into (which only adds about 1mm in length)
**part is from Hasegawa kit**
Thanks. This shows me length. I appreciate that.
Any way you can tell me the diameters?
This is 1:48, yes?
SargeUSMC Thanks. This shows me length. I appreciate that. Any way you can tell me the diameters? This is 1:48, yes?
Yes...1/48
#'s are in mm's.
Good enough???
Oops...the receptical(?)/head starts out at about 1.75mm wide and tapers down toward the tip.
Ok, I see the fat end is 2mm dia. What is the dia of the center section?
SargeUSMC Ok, I see the fat end is 2mm dia. What is the dia of the center section?
1.25mm (roughly)
oh, all right. I see that now. Thanks a lot.
