Cat Girl
    September 2006
Cat Girl
Posted by Banshee1000 on Monday, January 12, 2015 10:50 PM
The E2046 kit.
Posted by Gamera on Wednesday, January 14, 2015 11:54 AM
Very nice clean job! Just wondering did you brush paint or airbrush her?
    September 2006
Posted by Banshee1000 on Wednesday, January 14, 2015 8:37 PM
Thank you, Gamera.  She is air brushed.
Posted by Gamera on Thursday, January 15, 2015 10:05 AM
Very cool! Just wondering if the dress, hair, etc were separate parts are did you have to mask all that? If you did, wow!
    February 2011
Posted by Raualduke on Thursday, January 15, 2015 11:14 AM
Sexy.what flesh tone did you use?
    September 2006
Posted by Banshee1000 on Thursday, January 15, 2015 10:54 PM
Thank you, Gamera!  I appreciate your comments!
The hair was in two halves, a thin front piece with the two front curls and the curl over the face, and then the large part of the rear hair and ears, so that was the only difficult masking.  The hair had to be glued together over the head and face after painting the face, so I only had to mask the face and neck to putty, sand and repaint.
These kits are fun, but there is always one painful part like that!  I built this Sol Angel Rebirth a few years ago, and it had the same problem; the left arm has to be attached before the right arm can be attached, but because of the overlapped pieces it was necessary to prepaint everything, then attach the arm, putty and sand and then repaint it..  It's always painful to take sandpaper to the finished paint!
    September 2006
Posted by Banshee1000 on Thursday, January 15, 2015 11:08 PM
Hi Raualduke.  It's a mix of Model Master Enamel white, red and yellow.  The light surfaces are highlighted with white and the base and shadow areas of the body were darkened with straight yellow, and blended over with the original base..
Posted by Gamera on Friday, January 16, 2015 8:26 AM
Oh wow that's cool! I just got back into figure modeling so I can appreciate what a pain some stuff like that can be to mask and paint. Nothing as complex as that though!
    February 2011
Posted by Raualduke on Saturday, January 17, 2015 12:35 AM
Thanks banshee 1000 .not sure I could pull that off the way you did. Very well done
