That kit is apparently a re-boxing of the old Aurora Bison kit. Just to clarify for the others, It's already molded with a textured coat.
I would use a base color for the coat and then lightly-very lightly-drybrush a lighter shade of the base color, to highlight and pick up the molded texture of the coat. You could also go the other way, and use a light base, and then use slightly darker washes to emphasize the relief, leaving your base color as the highlight color on the high points. Either way, with this kit, I would try to keep it as subtle as possible.
If you need to fill any seams, pay extra attention to KnightTemplar5150's advice. Puttying will probably obliterate details around those seams, and you'll want to recreate the detail of the coat in those areas. As he describes, you'll need to scribe or sculpt those lost details back in.
It's a great kit, though, and I look forward to seeing your build.
