Samurai
    February 2004
Samurai
Posted by chris hall on Friday, May 28, 2004 2:00 PM
I have on my waiting to be built stack a set of Tamiya 1/35 Samurai. Every now and then I take them out, look at them longingly, and put them back. The problem is that I cannot think of a way of painting the patterns (trees, leaves, yin and yang symbols, etc) on the figures' trousers.
Until I do, the Samurai will remain forever unbuilt.
Ideas, anyone?
Chris.
Cute and cuddly, boys, cute and cuddly!
Posted by Anonymous on Friday, May 28, 2004 5:35 PM
How about making water slide decals on your computer?
Posted by ajlafleche on Friday, May 28, 2004 6:52 PM
What Dannick says is good, but you can also practice the designs on scrap before commiting them to the figures. Since the specific figures in the Tamiya set are of some the 47 Ronin, Samurai who had lost their master, you could just as well find patterns of hte period that are more easily reproduced.
Posted by Anonymous on Friday, May 28, 2004 6:56 PM
Make a stencil of the design and stiff brush the pattern on the clothes??
Posted by Anonymous on Friday, May 28, 2004 8:28 PM
I painted them by hand when I built that kit about 12 years ago. It's one of the 47 Ronin kits, of which I seem to recall there were only two.
Try this. For the diamond pattern on the trousers of one of them, paint the base color, a reddish brown IIRC, and then paint solid diamonds in a pattern over the base, leaving the base color only visible as stripes. When the diamonds are dry, fill them in with base color so that the only thing left of the diamond are stripes of the approximate thickness of the distance between the diamonds. Then you can free hand whatever little pattern in the center. If you get the hang of it, you can figure out ways to replicate other patterns too. You kind of have to think in both negative and positive space, while working backwards from conventional thought.
Here's another trick. A few guys I used to know from my old figure modeling club used decals to lay out a very basic pattern, and then free handed over and around it. It worked very well for Tartans and heraldry. The decals will flow naturally over the folds, which is the hardest thing to replicate free hand, and then they could paint right over the decals and move beyond the basic pattern they provided. They don't even have to be in the right color, since you'd be painting over them, and then you'll have painted a perfectly aligned pattern over the compound curves of voluminous garments.
