To all that replied, thanks for the positive comments.
QUOTE: Originally posted by rjkplasticmod
Excellent painting . I agree with you on the Games Workshop acrylics. I now use Vallejo which is great paint.
Regards, Rick
Rick, Im now working with Vallejo and have to agree with you about them being a great paint.
Huck, the fiqure is Verlinden's 120mm Scale "English Knight 14th Century" (Kit 1086). I haven't had a problem with the Humbrol enamels going 'gummy', unless the tins aren't fully sealed. I find that if I keep the top of the tin clean it seals firmly. I believe that also the method I use when using humbrol enamels might also help in preventing the paint from going gummy.
The method I use is:-
Before use I stir the paint in the tin until it is fully mixed this helps to keep the paint pigments in solution, if the paint seams a little thick a add a drop of humbrol thinners.
I don't paint directly from the tins, I place a small quantity in small container and if required add thinners to obtain the right consistency. I never return this paint to the tin after use.
I hope this helps.
