Need help with fuselage covering
Bis
    April, 2018
Posted by Bis on Tuesday, June 12, 2018 4:34 PM
I am working up the nerve to apply the paper to the fuselage of my P51. My question is, since the sides of the fuselage are flat and a solid piece of wood, do I coat the entire side of the fuselage with glue and apply the paper or just the outside edges? If I do the out side edges should I glue the paper where the wing spars go into the fuselage?
Also if I glue the entire surface, I won't be able to shrink the paper to get a nice flat surface, so it will have to be right the first time.
 I hope all this makes sense , thank for any input.
From, Crockett Texas.
    September, 2012
Posted by GMorrison on Tuesday, June 12, 2018 4:50 PM
Hi Bis,
You might post this in "General Modeling Discussion". Not a lot of stick and tissue modeling is discussed here, so it's interesting to hear from you.
Bis
    April, 2018
Posted by Bis on Tuesday, June 12, 2018 5:45 PM
Thanks, I posted over there. Couldn't figure out how to just move it, so I typed it over again.
    September, 2012
Posted by GMorrison on Tuesday, June 12, 2018 5:56 PM
Good idea. Looks like you are getting responses already. This particular forum is for models entirely made out of paper. Needless to say, people don't look in on a lot.
Bis
    April, 2018
Posted by Bis on Tuesday, June 12, 2018 6:25 PM
Thanks, I had no idea.
