need help creating custom models
    December 2014
Posted by kaitlin4599 on Tuesday, December 30, 2014 8:15 PM
hello im looking to create a custom model out of a star trek romulan bird of prey i thought id start off with a micro machines version as a test bed before modding my actual revel model. so my question is what would i use for a filler? so what i want to do is remove the lower part of the secondary full and add a filler up to the bottom of the nacells what do i use for this if u have any questions ask away i can prove pix if needed
Posted by Don Stauffer on Wednesday, December 31, 2014 9:01 AM
I think the si-fi forum would be another place to ask this- more folks there might be familiar with the kit you are talking about.
    December 2014
Posted by kaitlin4599 on Wednesday, December 31, 2014 5:48 PM
mods plz move this to the sci-fi forum
    June 2010
Posted by OctaneOrange on Friday, January 2, 2015 8:49 PM
although you've been shunted to the sci-fi forum, there's one called 'scratch building', which the same techniques apply.
I use an auto body filler. it's a two-part 50-1 putty to catalyst. once set, it's sandable, drillable.
you could also try a one-part filler, like squadron green and white.
for making body parts, like hulls, i use flat styrene sheets from evergreen.
    April 2010
Posted by Gerry on Monday, February 2, 2015 11:58 PM
I did a similar thing when I modified an Enterprise model. I used expanding foam insulation. It's cheep at any Home Depot. Squirt some in and use a razor to level it off or sculpt it. The I used plastic sheets from the hobby shop to close it off. Here's a link to my build page
gerry1of1.wordpress.com/.../iss-reliant
Cutting blade on a dremal shouldll work to remove the lower part.
Gerry ...Young at Heart - Other parts slightly older.
