Black Knight charges in to banish model blahs
    May 2011
Posted by Real G on Tuesday, June 27, 2017 12:53 PM
I have not been in the mood to work on stuff lately.  But with tax season, a job change, and my sis having surgery all behind me I thought it was time to get back in the game.  Typical of my poor judgement, I picked Love Love Garden's (yes that's the company's name!) Black Knight, which is actually a resin conversion of one of Hasegawa's Mk.44 suits from Robot Battle V.  Gotta love the box it came in too!  The kit does not come with decals, and strangely all paint callouts on the modified Hasegawa instruction sheet have been mysteriously removed!  But thankfully there are some nice photos of the completed kit available on line.
https://flic.kr/p/Arm7tF] [/url]BK-01 by N.T. Izumi, on Flickr
The Hasegawa plastic parts go together very easily, and the kit can be built entirely in modules that all come together in the end.  The resin parts have heavy mold parting lines and such to clean up, but they fit well.
https://flic.kr/p/VBCPgU] [/url]BK-05 by N.T. Izumi, on Flickr
The resin parts have a rough cast texture, but the Hasegawa kit is perfectly smooth.  To remedy this, some automotive glazing putty was thinned with Gunze Mr. Thinner and stippled on the plastic parts.  Rather than mopping the mixture on, I avoided inside corners and add-on pieces to keep things sharp.
https://flic.kr/p/VBCP3h] [/url]BK-09 by N.T. Izumi, on Flickr
https://flic.kr/p/VZbTSh] [/url]BK-16 by N.T. Izumi, on Flickr
The glazing putty felt like loose rust after it dried, so to glue it down, some Tamiya Primer was stippled over the putty.  This also imparted additional texture.
https://flic.kr/p/VZbTim] [/url]BK-19 by N.T. Izumi, on Flickr
https://flic.kr/p/VZbTzd] [/url]BK-18 by N.T. Izumi, on Flickr
The resin "lobes" that go on to the rear of the body are really heavy, and I worried about the kit toppling over.  But a quick test fit proved that the kit could stand on its own:
https://flic.kr/p/W68dHV] [/url]BK-22 by N.T. Izumi, on Flickr
...but just barely.  Hasegawa's feeble polycap joints were not designed to take the additional weight of the resin pieces.  I'll need a stand.
Anyway, that is the state of play at the moment.  At first I thought it was folly to choose this kit to restart the modeling fire, but the base kit and resin conversion parts were very easy to work with.  Now to keep pushing to the finish line (and get back on the group builds)...
“Ya ya ya, unicorn papoi!”
Posted by Gamera on Tuesday, June 27, 2017 6:39 PM
Oh wow that's cool!!!
Somehow it makes me think of an armoured combat Vorlon encounter suit!
    May 2011
Posted by Real G on Wednesday, June 28, 2017 12:34 PM
Gamera
...or Sgt. Keroro!  Stick out tongue
https://flic.kr/p/UPwMTQ] [/url]BK-26 by N.T. Izumi, on Flickr
https://en.wikipedia.org/wiki/Sgt._Frog
    May 2015
Posted by Griffin25 on Wednesday, June 28, 2017 5:42 PM
What a cool and original kit. Looks like a blast and can't wait to see it complete. I love, love, love it! Big Smile
Griffin
    January 2006
Posted by SprueOne on Wednesday, June 28, 2017 8:49 PM
Oh man. Looks cool. Following this build fo sho.
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    May 2011
Posted by Real G on Monday, July 3, 2017 6:20 PM
Following Fermis' advice, hopefully the rubbish before and after the photos will be gone forever.
https://farm5.staticflickr.com/4280/35603332156_db3ba4196c_k.jpg
Oh nuts, there is no "preview" button.  Oh well here goes.
Anyway, just replacing the soft plastic (TEPE, not polyethylene or vinyl) molded cables with coil spring and mesh pipe.  While the kit parts are well detailed and are nicely wiggly, the parting lines are impossible to clean up.  Some solder or wire will be run inside the replacements to emulate the wigglyness of the kit parts.
Okay, it still doesn't work for me.  I'm tech-challenged.  Sucks to be me.
https://flic.kr/p/Wf9ofq] [/url]BK-27 by N.T. Izumi, on Flickr
Posted by Gamera on Tuesday, July 4, 2017 8:17 AM
Those look cool G, looking forward to seeing how you fit them in there.
    January 2006
Posted by SprueOne on Tuesday, July 4, 2017 10:30 AM
Good idea upgrading those parts. It will look much better.
    May 2011
Posted by Real G on Wednesday, July 5, 2017 12:28 PM
Thanks for the comments guys!  A bit of progress, but not much.  I was kind of busy yesterday with the BBQ grill.  Big Smile
The attachment point for the gun support arm (ala smartgun from "Aliens") was vague, so I just found the flattest spot on the body and glued it down.  I made a shallow depression on the body where the arm ball joint was, to provide some clearance.  Seems to have worked.
https://flic.kr/p/VQNaSS] [/url]BK-31 by N.T. Izumi, on Flickr
https://flic.kr/p/Vcsmo6] [/url]BK-32 by N.T. Izumi, on Flickr
The body kind of reminds me of that giant catepillar monster from "Monsters vs Aliens".  Stick out tongue  You know, with the snot thing...
The resin parts for the gun did not fit well, and neither did the plastic shield.  After some attempts to get everything to match up, I just gave up and glued everything down.  The gun muzzle had mold slip lines, so I cut it off and replaced it with a short piece of plastic rod.  The bore was drilled out after the muzzle was set, to make things easier for my failing eyesight and motor control.
https://flic.kr/p/VQNbey] [/url]BK-28 by N.T. Izumi, on Flickr
https://flic.kr/p/VQNb79] [/url]BK-29 by N.T. Izumi, on Flickr
https://flic.kr/p/Vcsm6x] [/url]BK-30 by N.T. Izumi, on Flickr
Things look super messy right now, but that is just the pre-painting.  Just need to clean up some resin parts, then off to the paint shop!
    April 2009
Posted by Cadet Chuck on Wednesday, July 5, 2017 2:17 PM
What IS that???  Looks like a bad potato to me.  Please forgive this old geezer, who just doesn't get it!
Indifferent
    May 2011
Posted by Real G on Wednesday, July 5, 2017 3:52 PM
Cadet Chuck,
The Black Knight is a powered space suit designed for lunar surface attack.  If you think it looks wacky, the base Mk.44 kit looks even worse, kind of like a robot Homer Simpson!  The resin aft bulges and snout, while making the design even more bulky, gives it a cooler look in my eyes.  It IS one of the ugliest robot-type kits I have though.  Stick out tongue
    April 2009
Posted by Cadet Chuck on Wednesday, July 5, 2017 8:24 PM
Thanks, Real G.  I'm just not at all familiar with that subject-  I'll have to learn a bit more.  Enjoy!
Chuck
    May 2011
Posted by Real G on Monday, December 18, 2017 4:28 PM
Slowly getting back to working on models.  The Black Knight got some black primer on a few nights ago.  Everything looks in order, so now the actual colors will follow.
https://flic.kr/p/22zrri6] [/url]BK-36 by N.T. Izumi, on Flickr
    May 2011
Posted by Real G on Sunday, July 29, 2018 4:56 PM
The Black Knight charges in at the 11th hour to sub in for my failed 2018 Nats entry.  I'm sad, but hey I paid my entry fee so I cannot go "stag"!
The model was black based at the end of last year, so it was ready to be painted.  The airbrush was rolled out Friday night and decals went on yesterday.
I still can't post pics using my phone, but if I can get to a real computer, I will.  I'll also post photos from the contest upon my return next week.
Posted by Gamera on Tuesday, July 31, 2018 4:39 PM
Good luck G!!! Hope you can finish on time!
    May 2011
Posted by Real G on Tuesday, July 31, 2018 4:46 PM
Thanks Gamera!  The house was reeking of turpentine from the oil washes yesterday, but less so today.  Just a few touch ups, some paint chipping, and a sealer coat should do it.
It's mostly a waiting game, so at least I have time to putter around and clean up the house a bit before flying out tomorrow.  It's fun ironing shirts to the tune of Judas Priest's "Turbo Lover"!
Posted by Gamera on Tuesday, July 31, 2018 5:02 PM
Great to hear!!
Our local show has a special catagory for building Revell's vintage P-51D and I don't think I'll be ready in time. This kit is friggin' horrible and it's like a hydra- every problem I solve two more pop up to bite me...
    May 2011
Posted by Real G on Tuesday, July 31, 2018 5:57 PM
Gamera, I had the old 1/48 Monogram P-51D kit, which was not bad for its time.  It was leagues better than my other WW II Monogram fighters (Me-109E, Fw-190A, A6M5, Spit Mk.IX, F6F, and Typhoon).
I have to run out to get some wire to finish the stand for my model now.
Keep going on your build, never give up, never surrender!
Posted by keavdog on Wednesday, August 1, 2018 1:47 AM
lol re love love garden.  Looking good - getting interested in the mech kits.
Thanks,
John
    June 2014
Posted by Tanker - Builder on Wednesday, August 1, 2018 10:53 AM
Hi;
 The last photo of this looks like a P*&&%$ rhino with - out his horns . If you look at it just right you can see what I mean . Why can't I find these around here ?
 I hope your Sis is doing okay now . If you don't mind , I will add her to my prayer circle for protection . T.B.
    May 2011
Posted by Real G on Wednesday, August 1, 2018 12:18 PM
Tanker Builder, thank you for thinking about sis - she's doing fine, and could probably protect all of us!
The kit is actually a resin garage kit, with a Hasegawa injection molded base kit thrown in, so I would not expect to see one in any US hobby shop.
And now if you will excuse me gents, I have to look for a box for the BK to make the 2,500+ mile hop to Phoenix!
Posted by Gamera on Wednesday, August 1, 2018 5:14 PM
G, I just hope you'll post the finished model with all the awards you win!
    May 2011
Posted by Real G on Friday, August 3, 2018 1:53 AM
Gamera,
The competition is stiff this year and my models are not my best efforts.  So no wins anticipated!  But I appreciate the well wishes.  That the competition is stiff is good for the contest because that means lots of good entries in the mecha category.
I added the Aliens APC to my model box just before heading out the door.  There are a lot of ugly joints on the underside that I didn't bother to address, since I was just interested in being able to replace the batteries for the lighting.  Again, no wins here.  I just wanted to throw in something fun for people to look at.
And there are a lot of fun things that other people brought - I just love that aspect of model contests!
In the vendor's room, I only bought 2 kits, one for a friend.  I got a Wave Destroid Defender for myself.  I have been looking for this never reissued kit since pasing it up during it's initial run.  I'm shopped out already, so it looks like no more models to add to the hoarder's stash.
    May 2011
Posted by Real G on Monday, August 6, 2018 11:04 PM
So in four days, I got the Black Knight painted - not something I want to repeat any time soon.  A lot of compromises and ugly cover-ups occurred that should have never happened under a more relaxed schedule.  I tried oil washes for the first time, which promptly dissolved the paint UNDER several layers of Tamiya spray can clear coat.  I was only waiting 12 hours between paint stages, so it's all my fault.
Anyhoo, here is a condensed play-by-play:
https://flic.kr/p/29vbbWE] [/url]BK-39 by N.T. Izumi, on Flickr
https://flic.kr/p/MrFwDf] [/url]BK-40 by N.T. Izumi, on Flickr
https://flic.kr/p/MrFwgw] [/url]BK-42 by N.T. Izumi, on Flickr
https://flic.kr/p/28v6zaY] [/url]BK-45 by N.T. Izumi, on Flickr
https://flic.kr/p/28f5vWB] [/url]BK-48 by N.T. Izumi, on Flickr
https://flic.kr/p/26S8oXW] [/url]BK-50 by N.T. Izumi, on Flickr
https://flic.kr/p/29yb7Dd] [/url]BK-53 by N.T. Izumi, on Flickr
https://flic.kr/p/KX86iV] [/url]BK-60 by N.T. Izumi, on Flickr
https://flic.kr/p/29GZSNc] [/url]BK-61 by N.T. Izumi, on Flickr
https://flic.kr/p/29GZShn] [/url]BK-63 by N.T. Izumi, on Flickr
In the hotel room with a friend:
https://flic.kr/p/MKtbP1] [/url]IMG_8248 by N.T. Izumi, on Flickr
And back from a 5,000+ mile journey:
https://flic.kr/p/29T5zUx] [/url]IMG_8505 by N.T. Izumi, on Flickr
Posted by Gamera on Tuesday, August 7, 2018 7:22 AM
Ack, hate it when the paint peels up with a wash but the final results look fantastic!
And congrads on the award (if that's what it is- I don't see a 1st, 2nd, 3rd place on there).
    May 2011
Posted by Real G on Tuesday, August 7, 2018 11:01 PM
Gamera, yes that's the award that was handed out.  No 1st, 2nd, or 3rd written anywhere.
Maybe they had to go that way due to the unusually low trophy sponsorship.  I sponsored a trophy package under "The East Oahu Radical Splinter Faction Group".  I have done so on three occasions.  If club members just kick in a few dollars each, it is easy to raise the $80.  Heck that's the going price of a large kit.
    August 2012
Posted by Rambo on Wednesday, August 8, 2018 1:03 AM
That is really cool and congrats on the award. I've never built a mech before but can see one in the future. He reminds me of a big daddy from bioshock.
Clint
Posted by Gamera on Wednesday, August 8, 2018 7:22 AM
It's a beautiful award- just confused me a little there! Congradulations on winning it!!!
    May 2011
Posted by Real G on Wednesday, August 8, 2018 12:24 PM
Thanks guys!
Now everyone back to the bench!
