Bandai Starblazers 2202 Garmillas Zoellugut
    October 2021
Posted by PhoenixG on Monday, March 25, 2024 9:10 PM
Hitting a section with the Spartan where there is some downtime between actions and decided to work on this.
Zoellugut
I don't know what the scale is, but the kit includes two of the vessels and decals for all three version you see on the box art.  The parts are injected in standard grey and black.
At the moment I only intend to build one of the two vessels because this is meant to be a fun little side project.
I am starting with the grey one. Not a lot of parts, which makes it perfect for a filler build.
part trees
Straightforward assembly, but the pieces didn't quite fit as nicely as I'd like.  There didn't seem to be any interference from flash etc.  Possibly, a little warping after ejected from the mold. Clamping seemed like a good idea.
clamped
Had a small SNAFU when glueing in one of the small fins on the bottom.  It wasn't going in very well.  When I tried to back it out, I snapped off the front end of it.  A little dab of glue on it and almost as good as new.
whoops
It's hard to see the photo and even harder to see it with the eyeball.
The rest of the assembly went smoothly and it primed nicely.  The Q-tip is for scale.
Primed
it really is a tiny little ship.
Took me a bit to figure it out, but the greys on the ship aren't just simply light or dark.  They actually have a little purple mixed into them.
it's purple
And that's what I am working on now.  Figuring out the right ratio of purple to grey in order to achieve a reasonable approximation of the color.
It should also help tie the decals into it a lot better than if I simply use a darker grey.
decals
One other little twist. I failed to notice the bridge and cannon section are lighter shades.  It would have been easier to do this before assembly.
I think it will be simpler to paint the bridge and cannons first.  Mask them off and then paint the rest in the darker color.  If I do it the other way I'm going to have to mask twice.
Well that brings everything current.  Time to start experimenting with paint.  :)
On the Bench:
    October 2021
Posted by PhoenixG on Tuesday, April 9, 2024 11:13 PM
I lied.  I ended up masking around the bridge.  I started worrying about overspray messing with the darker gray.
mask
A fairly quick and dirty job.  I figured a little bleed wouldn't be very noticeable.
The color as applied is a mix of Vallejo primer, AC White, and MC Purple.  The mix wasn't very precise.  Effectively 2 drops of primer+ 1 drop White + a damp toothpick tip worth of purple is how it started.  Added a little this and that till I got a color that was close enough for my satisfaction.
painted
Practically indistinguishable unless you pay close attention to the exposed stern.
Pulling off the masking makes it a bit more apparent.  I appreciate the subtlety a tiny bit of purple adds to it.
it's purple!
Next up.  Masking the bridge and the cannons and then mixing up the darker grey + purple to apply.
On the Bench:
    August 2021
Posted by lurch on Wednesday, April 10, 2024 3:38 AM
This looks interesting. I like it. I will be following this one.
    July 2014
Posted by Bakster on Wednesday, April 10, 2024 9:07 AM
PG, this looks like a cool project. I will be following.
Looking forward to what you do with this!
    October 2021
Posted by PhoenixG on Thursday, April 11, 2024 2:29 PM
Thanks to those following along.  This one is going to have a slow start as it's only going to be worked on when there are pauses with the Spartan.  Once the Spartan is completed this will get my full attention.
On the Bench:
Posted by Gamera on Friday, April 12, 2024 5:20 PM
That's so cool!!! Looking forward to when you get to finishing her up!
    May 2023
Posted by Greysteele on Sunday, April 14, 2024 11:05 AM
Those Starblazer minis are fun to build. I wish there was a larger scale kit of this ship.
"In polite society, we call our obsessions hobbies." – Stephen King
    October 2021
Posted by PhoenixG on Monday, April 15, 2024 3:18 PM
Greysteele
If they ever did make a larger scale one I would seriously consider picking it up.  There is detail on this small one that I think would look simply amazing on something larger.
On the Bench:
    October 2021
Posted by PhoenixG on Saturday, April 20, 2024 4:19 PM
With the Spartan out of the way this now has my full attention.
A nice little amuse bouche before starting up on another big project.
I've been busy masking off the bridge and forward cannons. After spending 30 minutes trying to find my tweezers. Confused
mask1
Lots of tiny triangles of masking tape being applied here in order to cover the area. Too many different angles for straight pieces of tape.
mask2
But you get enough of them applied and eventually you've got it masked.
mask3
The forward cannons were masked with triangles cut from Tamiya 6mm masking tape.
Much to my surprise I was able to cover most of the upper bridge using pieces of the larger Tamiya 10mm masking tape.
mask4
Tamiya 10mm masking tape is my bread and butter tape.  However, after getting those larger sections done it was back to the 6mm.  I cut it down to about 4mm wide strips and applied it to to the lower surfaces of the bridge.
mask5
It conformed quite well to the curves of the lower sections of the bridge.  Thanks to the not quite perfect fit of the bridge I could slide the blade of the hobby under the edge and easily cut off the excess tape .
And just like that, the masking is done!
mask6
Next up is applying some clear coat to seal the mask and mixing up the color for the darker grey of the hull.  I'll probably start with a neutral gray as the base.
On the Bench:
    May 2011
Posted by Real G on Saturday, April 20, 2024 6:59 PM
PhoenixG
Greysteele
There is:
 https://www.scalemates.com/kits/bandai-0191395-zoellugut-class-domelaze-3rd--551325
But I don't have one.  Sorry.
I'm still hoping for a Gatlantis missile ship, the one that looked like something I'd draw in 5th grade.
“Ya ya ya, unicorn papoi!”
    October 2021
Posted by PhoenixG on Monday, April 22, 2024 2:48 PM
Real G
PhoenixG
Greysteele
There is:
Too bad.  The larger Zoellugut appears to be out of circulation at the moment.  Fingers crossed they decide to release it again.
As for the Galantis missile ship.  This the one you are thinking of?
Galantis
Which also looks to be out of circulation.
Seems like Gunpla is dominating Bandai's production output these days. Not complaining.  However, it would be nice to have a wider variety of genres to select from.
On the Bench:
    October 2021
Posted by PhoenixG on Monday, April 22, 2024 3:07 PM
Busy weekend.
Settled on Vallejo Meidum Sea Grey, White, and Purple as the colors to use for the body.  The paper below is actually a palette paper.   Having something like this to do custom color mixes is a great aid. It's a neutral grey which really helps the eye/brain see the color as mixed.
colors
This is the color I finally settled on.  It's approximately 5 parts Medium Sea Grey + 2 parts White + 1 part Purple.  I used aircolor for the white as a way to help pre-thin the paint before transferring it to the airbrush.
color
I did paint test by applying a drop of the paint to the box section and look for color matching.  The dot on the lower right was the color mix I settled on.
test
After thinning the paint mix a bit more it airbrushed quite nicely.
completed paint
Peeling of masking is still like unwrapping gifts.  Smile
peel1
The masking turned out nicely.
peelcont
Quite pleased with how the base colors applied.
overall
Gloss coat for the pinwash went down without a hitch.  Already looking sharp!
gloss
I got as far as applying the pin wash to most of the upper structure.
pinwash
detailpic
Needed to take a break at this point.  Back was starting to complain from being hunched over for so long.  The bridge and main cannon still need the pinwash and then I can start cleaning up around everything.
On the Bench:
    October 2021
Posted by PhoenixG on Friday, April 26, 2024 5:53 PM
Looks like there is a break in the bad weather (forum's server issues) going to try and squeeze in a quick update while things are a little more stable.
Finished up with the pin wash.
pin1
pin2
I like how those panels lines just pop.  Still need to clean up the mess of the wash.
Of course I just realized I did this too early.  I should have put the decals down first.  Whoops!
That got me  looking at the decal sheet and am now wondering if the darker gray is too dark for those decals.
decals
The box are has the decals as being noticeably darker than the hull.  I wonder if a mist coat of a lighter shade would work....
Otherwise it's strip it back to plastic and try again.  Given how small the model is it isn't as big a deal, but not my favorite thing to do.
Maybe I'll give the mist coat of a lighter shade a try first and go from there.
On the Bench:
Posted by Gamera on Monday, April 29, 2024 6:52 PM
That looks soooo cool Phoenix! Lots of the detail there for such a small model.
    October 2019
Posted by Tanker-Builder on Tuesday, April 30, 2024 8:27 AM
Hi!
     Fascinating project this! I just wish they made them bigger. These, like 1/700 ships are a pain for me to work on. Looks like fun though!
    July 2014
Posted by Bakster on Thursday, May 2, 2024 6:24 PM
Gamera
What he said. Watching.
