Anyone Up for a Star trek Group build?
Posted by SNOOPY on Sunday, January 11, 2009 8:29 PM
 Woody wrote:
Heat is your enemy! I would also support the underside of the part, directly under where you are cutting with the Dremel. If the part isn't solidly supported you will get a wavy. uneven surface.
Woody, I am also having the problem of unlamination.  I tried two things.  two layers I tried Testors Liquid Cement and for the others I tried epoxy.  Both layer are starting to delaminate.  Any suggestions on adhesive for laminating sizes of the circles from 3-3/4" to 1-5/16" in diameter?  I was thinking of trying Weld -On #3.
    September 2003
Posted by Prince of Styrene II on Sunday, January 11, 2009 11:57 PM
 Archangel wrote:
I have a kitbash of a Klingon ship that would fit right in here. I built two years ago for Wonderfest 2006. It didn't win anything but I did get a few compliments on it. I also have the in progress shots still from when I posted it on www.Starshipmodeler.com while building it. If it fits the rules here I'd like to enter it in the group build.
So it's already done?  Isn't the idea behind a group build to actually build something & not just "enter" what's already on your shelf?
"Hold the weapons, Daddy. I'm going to go get my monkeys." The Dutchess of Styrene
Posted by Woody on Sunday, January 11, 2009 11:59 PM
I mostly use CA but I have used epoxy as well. I didn't like the epoxy as much because the texture of the cured glue isn't the same as the styrene. I also don't like to use regular model cement because it takes a long time for the parts to set when you are dealing with surfaces as big a saucer sections. They seem dry but the liquid cement can "gas" out through the surface and mess up the plastic and paint.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by SNOOPY on Monday, January 12, 2009 7:10 AM
I read it as if Archangel had another klingon ship he had started.  If it is not complete i do not mind him jumping in as long as other agree.  As far as an already done one well that does not fit our category.
Archangel can you be a little more specific on your build?
Posted by SNOOPY on Monday, January 12, 2009 7:15 AM
I would try CA but the strength properties for CA are not very good in the shearing direction.  If you have not had any problems with it I will give it a shot.  What do you think about taking either balsa or basswood sheets, cutting out the circle sizes, laminate, sand and then make resin parts?  There was also a system someone showed on the scratchbuild forum where he used Bondo resin with stacked styrene discs and make a tool to smooth out the resin.  It seems a little too messy to me but it might be something I need to think about trying.  I would like to get the saucer done before school starts in two weeks.  It is going rather slowly.
-Scott Lindsay
    September 2003
Posted by Prince of Styrene II on Monday, January 12, 2009 8:18 AM
Yes, I agree with this idea.  Maybe I misread it.  Calrification would be helpful.
Posted by Woody on Monday, January 12, 2009 12:47 PM
-Scott Lindsay
I haven't had a problem using CA laminated styrene but regardless of which glue you use I'd use plenty of clamps. Air spaces will cause de-lamination. My goal in making the blank is no air and fully cured cement/glue.
By the way did you get my PM?
    August 2005
Posted by sumpter250 on Monday, January 12, 2009 1:39 PM
Just a thought, how about "rings" instead of circles. It might be touchy aligning the rings, but the  bonded surface area would be smaller, and the liquid styrene cement could set more quickly, with less "gas out" problems.
Lead me not into temptation ..................I can find it myself
Posted by SNOOPY on Monday, January 12, 2009 4:13 PM
It probably be a quicker cure time for the adhesives but like you said I think alignment would be rough.
Woody, When you used CA, what did you use to spread the CA?  Did you just clob it on and spread with a putty knife or did you put dabs of CA every 1/2" or so then let the pressure squeeze it out from there?  I was just thinking what about 3M 77 spray?  I am not sure if it has the holding strength when being sanded.  Time to experiment?  I wish I still worked at this filter making laboratory.  To bond plastics together we would put them in special made jig that would heat both surfaces to be bonded but the opposite sides were cooled with CO2 or nitrogen and then each piece pressed together until cooled.  Presto one solid plastic piece.  Well, that was the past.
Posted by Woody on Monday, January 12, 2009 5:14 PM
Is my GB entry ok?
I use the thin CA and makes concentric rings about 1/4-1/2 inch apart. I don't place the first ring right on the edge but about 1/2 inch back. You just have to eyeball it. After the parts are placed together the glue should go all the way to the visable seam. Too much and you have a mess.
    January 2003
Posted by Archangel on Monday, January 12, 2009 9:43 PM
It is already completed. That is why I asked before entering the build .The good thing is i can start a new build though on something else easy enough. I have a Romulan Warbird from the 3 Pc adversary kit that needs to be kitbashed
Posted by SNOOPY on Wednesday, January 14, 2009 7:24 AM
 Woody wrote:
Is my GB entry ok?
Woody, I got your PM and your entry is good.  I need to update the first page.  How do you make the concentric rings.  I have been using the step method where I cut out a circle the best I can by and then putting it into the drill press and file it down to size.  After getting the sizes I need that is when I laminate together.  This weekend will be the next attempt at getting the shape I need.
Posted by SNOOPY on Wednesday, January 14, 2009 7:27 AM
Archangel, unfortuneately this is a building site and if it is finished then no you cannot use it as an entry.  You can post pics of if.  I am sure we would be interested in seeing it but if you want to do the Romulan warbird that is okay as long as you ar scratchbuilding or kitbashing the model.  When you do any type of scratchbuilding or kitbashing of pieces post those and tell us how you did it.  Let me know your intensions.
    May 2008
Posted by Boba Fett on Wednesday, January 14, 2009 8:05 AM
Question Snoopy, are you gonna post this in GB's? You might get more people that way... Just a thought. If so, when?
    September 2003
UPDATE!
Posted by Prince of Styrene II on Wednesday, January 14, 2009 10:34 AM
Got some more done.
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/USS%20Taegu/strut_finished.jpg
I made the main nacelle strut by laminating three sheets. The middle sheet was grooved, slightly smaller in width and also has a tab to insert into the secondary hull's already present slot. The smaller width creates a trench around the outer edge. I'm also proud of the angle leading down to the grooves.
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/USS%20Taegu/struts_on.jpg
Both main struts are inserted. I also filled the aft with weights to counter all the CDs in the saucer.
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/USS%20Taegu/impulse1.jpg
I shaved off a bit of the underside "flair" just aft of the saucer which will house the impulse engines.  I think I'll also end up blending the flain into the underside of the saucer.
That's all for now!
Posted by SNOOPY on Wednesday, January 14, 2009 5:45 PM
I would and probably should but the last time I suggested a scratchbuild there I did not get any takers.  I figured anyone interested in Sci-Fi things come here so for now I will stay here.  I may at the very least post a notification of this group build.
    May 2008
Posted by Boba Fett on Wednesday, January 14, 2009 6:05 PM
I would recommend it. You might get lucky because so few people go to Sci-fi...
    January 2003
Posted by Archangel on Wednesday, January 14, 2009 9:34 PM
I sure will do that. I haven't started yet But I have an idea of turning the Warbird into a Romulan Transporter or a three engined variant to the Warbird. I know it's not a new idea but with what I have on hand its about all I can do. Here are some pictures of the model I was talking about before that is already built. I bashed a nX-wing and a D-7 together. After i had finnsihed it I had realized the nose was a bit too long . It had parts from the TOS Enterprise, The Hasagawa Wepons sets and a ceneter gear shift from a car model for detail and a part from a Monogram snap tite space shuttle.
The start.  a broken X-wing and the rear half of a D-7 kit
http://img466.imageshack.us/img466/2083/0054mr.jpg
The engines
http://img523.imageshack.us/img523/3308
http://img523.imageshack.us/img523/9936/0098hh.jpg
The boom and aft sections mated and some details added.
 http://img137.imageshack.us/img137/8663/0019hv.jpg
    January 2003
Posted by Archangel on Wednesday, January 14, 2009 10:10 PM
Here are the rest.
Here I cut out the Torpedo launch tubes and used plactic straws for them so they would look more realistic. I added a tank Turret to the top of R-2 to make it lok more like a Klingon bridge . You can see the center console for a gear shift from a car kit on the top of the nose.
http://img523.imageshack.us/img523/9927/0032zp.jpg
http://img137.imageshack.us/img137/9518/0048zp.jpg
The aft section
http://img137.imageshack.us/img137/3686/0075ot.jpg
The Finnished Product. I painted it in  Tamiya Primer Grey and used a heavy wash of black.
http://img107.imageshack.us/img107/1388/scan0003b1dp.jpg
Here is a close up of the top of the nose. You;ll see part of a plastic twizzle stick and some plastic strip added to either side of it to make the cloaking device generators.
 http://img154.imageshack.us/img154/2842/vtadsc00466ef8.jpg
http://img.photobucket.com/albums
http://img.photobucket.com/albums/v125/Archangel51534/S6300116.jpg
Posted by Woody on Monday, January 19, 2009 12:45 PM
I'm working on my layout drawings right now. I've narrowed it down to two slightly different shaped primary hulls. I hope to start cutting plastic in the next couple days.
Posted by SNOOPY on Tuesday, January 20, 2009 7:20 AM
 Woody wrote:
I use a cordless drill to turn the part and a Dremel with a coarse tooth to sculpt the part. Turn the part your cutting slowly and use the dremel on as high as speed as you can that doesn't cause melting.  If the part isn't solidly supported you will get a wavy. uneven surface. I clamp the drill to the workbench, support the back side of the piece with my finger tips(put talc powder on your finger tips), and hold the dremel with my right hand.
Woody, when you use the dremel/moto tool, 1) Which attached do you use a sanding stone or one of the drum sanders? and 2) Which direction do you use the Dremel tool?  I mean is the tool turning counter the drill's rotation or perpendicular to the drills rotation.
I made to new discs to be made into a saucer.  The discs turned out pretty good.  I think they are pretty solid laminated.  I used Super Glue this time and allow 48 hours cure time.  I made the discs by putting them into my drill press, first filing them with a course file, then using a sanding block with medium sandpaper, and then one of those 3M fine sanding sponges.  Can out looking pretty good.  I made sure that things did not get over heated this time.  Tonight I will attempt to make the saucer section.
Posted by Woody on Tuesday, January 20, 2009 8:03 AM
I use a rotary rasp and coarse sanding drums. I mostly shape with the dremel turning counter to the drill. Be sure to use light pressure with the dremel and support the work piece. If it wobbles, then you'll never get a nice looking part.
Posted by Woody on Tuesday, January 20, 2009 9:20 PM
Hey Greg, You don't need a kit. I believe most of us are scratchbuilding. I'm fleshing out a concept sketch of a Manta class destroyer. 95% of my entry will be made from sheet styrene. Come on Greg pick a simple design and go for it!
Posted by SNOOPY on Friday, January 23, 2009 8:25 PM
Woody, I tackled my saucer tonight.  It turn out a lot better than the first one did. Here is a pic of it.   If you see there is still a seam line that can be seen and I have tried everything to get rid of it.  Also, I think you can see them but there are these small grooves in certain areas.  Any idea on how to get rid of them.  I have used the finest sanding block I have which smoothed everything else out but not those grooves.  Will they disappear if I spray it with primer like Mr. Surfacer?
Posted by Woody on Friday, January 23, 2009 8:50 PM
Looks good so far! I like to use a 50/50 mix of Testors enamel paint and Doctor Mico-Tool putty to fill light scratches. After I let this "thinned" putty dry completely, I wet sand with a 600 grit 3M wet/dry sandpaper. You might have to re-apply the putty mixture and sand again several times to get a perfect finish.
    August 2005
Posted by sumpter250 on Sunday, January 25, 2009 3:53 PM
I finally got the Jackill drawings redrawn in scale, for the USS Kodiak NCC 6000 secondary hull.
  Scratchbuilding the secondary hull, Warp nacelles, hull and nacelle pylons, will be the first part of this project. Modifying the Reliant kit to represent the Kodiak's primary hull will be part two. I have to figure out exactly what construction method I want to use. the hull will be styrene, at least on the outside, I may opt for micro plywood for the forms, and a secure base to anchor the primary hull to. The complete drawing is in Jackill's Starfleet Reference Manual ships of the fleet Volume II, along with the specs of the class.
Posted by Woody on Saturday, January 31, 2009 3:55 PM
Lucky me the National Guard has issued a curfew and a state of emergency. I haven't been able to join the forum because we are without power, water, and heat, due to a very bad icestorm that has crippled us here in Missouri. I'm on a run for food and a doctor for my sick 3 year old daughter, about a hundred miles from home and found a Wi-Fi signal at a hotel that still has power. It's amazing how quickly the thin coating of civilization rubs away to bring us back to a state of anarchy. They have had fights break out over gas and food. I'm sleeping with my AR-15 and a 9mm pistol. I hope our food holds out. Pray for us and I'll be back online when the world starts back up.
Posted by SNOOPY on Saturday, January 31, 2009 10:33 PM
Sounds like you need those prayers.  It is said that in this country where our government is suppose to help us they never seem to actually go through with it.  The National Guard should be bring in suppplies continuosly.  I served in the military and we did some pretty amazing stuff in other countries why can't we do the same here.  We know where and when storms will hit why not get mobolized ahead of time.  Woody, all my prayers to you friends and family.  I love this country and want to see good things happen.  I hope you never have use those weapons.  Godspeed!
    September 2003
Posted by Prince of Styrene II on Saturday, January 31, 2009 10:50 PM
Yikes, Woody!  How long ago did the storm hit?  I got my fingers crossed & are sending good thoughts your way.  Take care of that beautiful little girl, okay?  I know you will. Smile [:)]
    August 2005
Posted by sumpter250 on Sunday, February 1, 2009 11:05 AM
Woody, Prayers are with you. Keep your faith strong, and may fortune favor you.
