Revell 1/250 Pamir (review?)
    June 2012
Posted by arnie60 on Sunday, May 26, 2013 5:03 PM
Although I have been a frequent visitor to the ships forum, and even left a reply or two, this is my first time for posting my own work. Feel free to comment, and offer advice etc. One of my reasons for posting this is that I couldn't find any threads specifically about the Pamir with pics (which I was hoping to find to help me along).
This is my 4th build for sailing ships, and obviously I still have a lot to learn, but felt it was good enough not to totally embarrass me here. This is not really a build log but a review of the problems I ran into, i.e. the quality of the model.
Overall I was really happy w/ the detail and fit of the pieces. There were some problem areas I will show down the line here. Very little flash and no injection points that were an issue. The instructions were very clear and easy to follow with the exception of the rigging. I actually ended up leaving off about 1/3 of the rigging,  not being able to interpret what should be done exactly and the amount of rigging at this scale was frankly a bit beyond my skill and level of masochistic tendencies. I had originally planned to rig her w/ out sails, but decided that with this class of ship, its real magnificence shows in full sail. (you can view the rigging plans here: http://manuals.hobbico.com/rvl/80-5629.pdf)
Problem areas:
f8323090028
f8323090416
f8323089706
f8323089336
Finished and some general build pics:
f8323088284
f8323087228
I added the boats from the racks that I cut off to the poop deck (?). Seemed wrong to have only two boats for the entire ship, and they don't seem out of place there. the position of the davits for the forward boats doesn't make any sense to me, but the ones aft worked out pretty well.
f8323095244
I added the crane hooks with some copper wire that I bent to shape and ended up repositioning the crane arms so that the sails would fit.
f8323086384
f8323093220
f8323085402
this kit did not have any rigging blocks so I used some brass crimping beads I found in a craft store, the crane hooks and blocks are certainly not to scale, but felt it was a good trade off for the overall effect. if you look close, you can see that the shrouds at the top did not have enough length to fit correctly. This was the same for all three masts. There was no getting around it that I could figure out.
As I said, feel free to comment and could someone tell me how to post pictures so that they can be viewed in the post and not just as links?
    December 2010
Posted by 1943Mike on Monday, May 27, 2013 9:44 AM
Arnie,
I'm looking forward to viewing your pictures. Here's how to do it:
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    March 2012
Posted by David_K on Monday, May 27, 2013 10:23 AM
I'd love to see your pics Arnie, but I can't follow the link unless I sign in to *box*, or whatever the site is....
Thanks 1943 Mike, for the simplified pic uploading hint!  I've been using a far more complicated way to get pics on the forum, but it's so much easier the way you just indicated!  For some reason, I was copying the wrong style of link from Photobucket....by using the *direct* link version from Photobucket, I can post pics here just by clicking on the *insert image* button from here.
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Current Project:  Imai/ERTL Spanish Galleon #2
Recently Finished: Revell 1/96 Cutty Sark
Next Up:  ???
    June 2012
Posted by arnie60 on Tuesday, May 28, 2013 10:43 AM
    June 2012
Posted by arnie60 on Tuesday, May 28, 2013 10:49 AM
Arrgh!
I clicked on 'use rich formatting' and inserted url. same results. problem w/ box? one more try.
f8323090028
    June 2012
Posted by arnie60 on Tuesday, May 28, 2013 11:05 AM
moved them to photobucket. fingers crossed.
Yeah! K. here's the rest:
The text didn't come out too good in the pic... says fantail rail is poorly molded and did not match very well, but the upside is the other railings were easy to bend and held their shape for gluing.
Looking back on it, I probably could have rebuilt them from some evergreen so that they fit correctly. Live and learn.
The rest are just some in progress and finished pics
Thanks for taking a look.
    December 2010
Posted by 1943Mike on Tuesday, May 28, 2013 12:06 PM
Arnie,
Just as a test I'm inserting the URL of one of your images on Photobucket in this reply. It seems to work fine.
Please don't take offense but did you insert the correct URL? (In this case it's: http://i1347.photobucket.com/albums/p715/arnie5214/Presentation2_zps1f896ef9.jpg
I'm no techie but you do know that you have to right click (in Windows - which is the only OS with which I'm familiar) the image and then click "properties". That will give you your URL which you then copy (I always paste it on Word Pad just in case) and insert in the window I showed above.
Again, my apologies if I'm telling you stuff you already knew.
Hector Berlioz
    June 2012
Posted by arnie60 on Tuesday, May 28, 2013 4:02 PM
I finally figured it out, and yes, I was using the wrong links. Thanks for your help.
    December 2010
Posted by 1943Mike on Tuesday, May 28, 2013 5:36 PM
Arnie,
What did you use for the sails? They look very good to my eyes.
Hector Berlioz
    March 2012
Posted by David_K on Tuesday, May 28, 2013 6:27 PM
Nice work!  I like the ship, plenty of detail...I especially appreciate the subtle color highlights on the sails, give it just the right amount of weathering!
And I couldn't help but notice the big Testors hobby mat!  I had one of those when I used to build as a kid!  I totally need to pick one up!  Good times!
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Next Up:  ???
    June 2012
Posted by arnie60 on Tuesday, May 28, 2013 7:37 PM
Believe it or not, they're the vacuum form sails from the kit. They actually had some good detail and once I airbrushed some deck tan for weathering, they came out pretty nice. Funny, that's invariably the first comment people make about it. Normally don't like the kit sails and skip them, but as I said earlier, with a ship of this class, its full glory is in it being fully rigged for sail.
    April 2012
Posted by Flying Finn on Wednesday, May 29, 2013 10:38 PM
Arnie60,
Beautiful job!
Cheers,
Wayne
    June 2012
Posted by arnie60 on Thursday, May 30, 2013 9:39 AM
Thanks Wayne, and everyone else for your positive comments and help. There are so very many superlative modelers on this forum that I hesitated to post at first feeling outclassed, but you all have helped me get over that, and now I won't hesitate in the future.Big Smile
