HMS victory build
    July 2013
Posted by steve5 on Monday, November 6, 2017 12:26 AM
finally got the nerve up to cut the hole for the main mast , I think it need's to be leaning back a bit more , any thought's welcomed . I also found this mast foot , I know it probably shouldn't be here , but I think it look's kinda cool .
    September 2005
Posted by warshipguy on Monday, November 6, 2017 7:39 AM
Steve,
I agree that there needs to be a slight rake to the main mast.  Also, that foot to the main mast is questionable; I don't believe that Victory was ever so equipped. I'll see if I have any references for you.
Bill
    July 2006
Posted by Michael D. on Monday, November 6, 2017 9:38 AM
Looking very nice there Steve!. I too had a problem getting a slight rake to the main mast, I filed down the front of the square peg at the bottom of the mast to achieve that before I fit the Qtr deck. Did you back date the masts at all?
Michael D.
    July 2013
Posted by steve5 on Monday, November 6, 2017 1:35 PM
michael
 thank's for the tip to file the square peg , will try it , not sure what you mean by back date the mast's ?
bill
I'm pretty sure the mast foot isn't meant to be there mate , I just like the look of it at the moment . we'll see .
    July 2006
Posted by Michael D. on Monday, November 6, 2017 7:27 PM
Steve,
I started by removing the molded iron hoops on all the masts as they were not introduced until 1800, I did leave the front fish ( the raised section on the fore side of the mast), but added the filler pieces to each side for a smoothe transition for the rope woodings which number 8 on the fore mast, 9 on the main and 6 on the mizen.
Also the cheeks ( the raised sections on either side of the mast) on the mizen only will need to be removed as they were used around 1790, this did require some material to fill the void left after removal, I used brass tube and putty.
All of the this would be approprate from 1773 and on. A lot of work for sure considering the beautiful job you've done already, if you're up to it I have some pics..Cheers.
Michael D.
    July 2013
Posted by steve5 on Monday, November 6, 2017 9:17 PM
I just knew this wasn't going to be simple , Indifferent . LOL , I would really appreciate those photo's michael , thank's mate .
    July 2013
Posted by steve5 on Tuesday, November 7, 2017 11:32 PM
I noticed that michael , had added 3 grate's , to the quarter deck . they have finally arrived , now to put these jigsaw puzzles together .
steve5
    September 2005
Posted by warshipguy on Wednesday, November 8, 2017 6:23 AM
Steve,
I just checked several photos of the Victory. There does appear to be a very slight aft rake of the main mast. It is so slight that it is almost unnoticeable. But, it is there.
Bill
    July 2006
Posted by Michael D. on Wednesday, November 8, 2017 5:53 PM
Steve I put up the pics, I felt it appropriate not to hijack your thread mate.
Michael D.
    July 2013
Posted by steve5 on Wednesday, November 8, 2017 9:51 PM
michael
thankyou for that mate , that has made my life a lot easier , the research you must be putting into this , is awe inspiring , and your right , the rope does look good .
bill
cheer's mate , I'm trying but I'm having a bit of trouble getting it to go back , But I'll get there .
    July 2013
Posted by steve5 on Wednesday, November 8, 2017 10:03 PM
dafi , michael , how do these look , I was thinking of putting in 4 .
    July 2013
Posted by steve5 on Thursday, November 9, 2017 11:17 PM
got this little bit of decoration in for the front of the poop deck .
    July 2013
Posted by steve5 on Monday, November 13, 2017 4:15 AM
first part done michael , the hoop's have been removed , I have ordered some 2.5mm 1/4 round styrene for it , should be here in a couple of week's .
    July 2013
Posted by steve5 on Friday, November 17, 2017 4:18 PM
grates are in
only just noticed those chip's , oop's .
    July 2013
Posted by steve5 on Saturday, November 18, 2017 11:43 PM
made a new walkway , and post's , both need painting , I think 4 post's might look better
    April 2016
Posted by dafi on Sunday, November 19, 2017 4:26 AM
Hello Steve,
may I give a correction? The walkway was much more narrow in 1765. Also I believe there were no posts - the french did this way. The english used some knees on the wall. If posts were used, they should be placed unterneath the skid beams. But have a look at Goodwins and Lavery: Construction and fitting + Construction and Fitting.
On the picturs in RMG I did  not see hints on the posts, but realised two set of ladders: one in the front and one in the aft of the waist.
    July 2013
Posted by steve5 on Sunday, November 19, 2017 4:40 AM
thanks dafi , I wasn't sure how wide the walkway's were , I was only going on judgement from the couple of photo's I have seen of michael's beautiful ship . I only put the post's in for strength . I will take a plank off of the walkway's .
steve5
    July 2006
Posted by Michael D. on Sunday, November 19, 2017 10:35 PM
Looking great Steve!!, mine measure out to 12mm, hope that helps mate.
Michael D.
    July 2013
Posted by steve5 on Sunday, November 19, 2017 11:29 PM
cheer's michael , I scribed the plank's at 2.5mm , after dafi's advice , I took one plank off and it come's in at 12.5mm now . I'll do a touch of sanding off of the back , and it should be right , I was thinking of adding a .5mm square strip on the inside edge ., as I have seen such raised strip's , would this be too much michael, thank's for the info mate .
steve
    April 2016
Posted by dafi on Monday, November 20, 2017 2:30 AM
    July 2013
Posted by steve5 on Monday, November 20, 2017 3:12 AM
thank's for that daniel , I still have to take a bit off of the port side walkway , but does this look any better mate ?
    April 2016
Posted by dafi on Monday, November 20, 2017 3:25 AM
I one looks at the second picture of SLR0514, one can see it even smaller. Interesting Detail: Near the quarter deck it gets more wide, a small fence and a pillar to be seen, in front of the fence still in the broader part should be a ladder as seen on SLR0512 picture 4 (zoom in and you will see :-) Also a nice detail on 0514 are the hanging and standing knees in the waist. XXXDAn
    July 2013
Posted by steve5 on Monday, November 20, 2017 3:46 AM
actually daniel , their look's to be pillar in that 2nd pic just as the walkway thin's , after the quarter deck . it look's like the ladder , would start after that .Hmm
    April 2016
Posted by dafi on Monday, November 20, 2017 6:51 AM
That is exactely what I meant: Coming from aft first broad gangway with fence. Where the fence stops a pillar, then the ladder, then the gangway is reduced width.
On the for end of the gangway, I was expecting something similar, but I can see no change in the gangway. But in another picture in 0512 I can see through a port a ladder right in the front start of the gangway.
As in 0516 there is this one pillar shown but no others, I suppose that to be the only one. And adding all the knees would be a nice feature that can be easily done.
XXXDAn
    July 2013
Posted by steve5 on Monday, November 20, 2017 1:35 PM
it would seem likely that it would be as wide at the front end as the aft .
    September 2012
Posted by GMorrison on Monday, November 20, 2017 8:11 PM
I also believe that at least in the Trafalgar era, some of those pillars were removable.
Looking at McKays plans, as an architect, you see where the upper, main, lower and orlop deck beams all occur at the same spacing, one above the other and corresponding to the frames they attach to, which straddle the gunports, etc. But the quarterdeck has more closely spaced beams. The pillars are under four of the skid beams. Because they don't bear on an upper deck beam due to the different spacing, they are placed on the very large beams that run fore-aft and frame each side of the gratings on the upper deck.
That puts them considerably inboard of the inner edges of the gangways. And at least at that time, in his drawings, the gangways are a uniform width.
His drawings show very considerable horizontal lodging knees at those beams, as on all decks, but they don't show hanging knees.
I'm sure this is all pretty debatable, but it's fun to look at the structural framing plans and see how the whole thing ties together.
Bill
    April 2016
Posted by dafi on Tuesday, November 21, 2017 1:48 AM
Many Pillars were temporarily removable. Otherwise the capstans would have not been operational :-)
Simply take a giant jack, push up all the decks above for an inch or two, take the pillars out, take the jack out, go to the next set of pillars. Shows how flexible the whole construction was.
XXXDAn
    September 2012
Posted by GMorrison on Tuesday, November 21, 2017 2:22 PM
dafi
Daniel- That's the messenger? Very nice detail of the pillars in a neat stack next to the jack. Super modeling.
Bill
    July 2013
Posted by steve5 on Tuesday, November 21, 2017 8:47 PM
what gmorrison said , I love going over your thread , picking up little detail's .this is bit of a mock up
    July 2013
Posted by steve5 on Friday, November 24, 2017 11:52 PM
filled the gap's and bogged up the rest
