1/160 (N Scale) Robert E. Lee EXTENDED
    February 2019
Posted by Hirnsausen on Sunday, February 10, 2019 4:24 PM
Hi folks,
I purchased the plastic model kit "Robert E. Lee" from Lindberg Models (USA). It comes in the 1/160 scale, also known as "N scale", common for model trains. If you look at the paintings, I recommend to listen to the soundtrack "The Big Country" or "McBain". Big Smile
Before starting the work updates, at first some words about this model kit. Lindberg has decided, to make the ship looking like it was made from steal or iron: you don't see any wooden texture on the hull or any walls. But that is wrong, the ship was actually made from lumber. The kit lacks details, and that quite a lot. The lower side (bottom) of all deck overhangs also misses the strong beams that carried the decks, and again, there are only smooth surfaces. And my impression is, that a number of windows and doors and stairways are missing, too - front and back of the wheel house and the walkway above the steam engine. In addition, it would have been very nice, if some interior (cabins) would exist because a number of windows allow to look inside. And we could also run discussions about how some of the parts are designed (some unnecessary cuts of parts), Revell did it better for their Robert E. Lee ship model.
And now let's start the work updates. The first thing I did when receiving this plastic model kit, was to test-assemble the major parts, using only tiniest amounts of pattex to ensure I easily can separate all parts again without any damage. This way, I could see if the parts would fit. The following photos show the test assembly. Remember, a click on any pf these photos will show it in full screen size. :-)
Having passed the test assembly, the next step is to paint all parts, before they get out of easy reach after the real assembling later on. And so ... there shall be color!
I had to add a texture to the painted areas, due to the fact that Lindberg Models forgot to add a wooden texture to many parts. If you look closely, you can see the vertical color separations, simulating the usage of lumber. This texture makes the entire model looking much more realistic. This is not yet the gentle weathering that I later on will apply in addition, to make the ship looking used. I actually had to mix all paints by myself, as in this country there is not even one single shop anywhere that sells plastic model paint, glue, or other much needed accessories. Got only the big ones to buy. But I got it right...
Even before any painting, I did a lot of online research about the correct colors to be used for this ship. Those differ a bit from the colors mentioned by Lindberg Models. I also decided, to use on some areas some colors not seen with the original ship but on similar, other ships of that time, for the reason to add some color details to my ship. The yellow luggage cabin and the wooden cabin walls at the ship's stern show that. Having used white paint alone, would make the model look less interesting, thus this decision.
The next photo shows the shaft that propulses the two paddle-wheels at the sides. But you will note, that I added something to its middle that will allow, later on, a small and slow-spinning motor to move the wheels. There will be one full rotation every 12 seconds - this will make the model even more realistic. A too fast spin would not look real.
Making this shaft extension was surprisingly easy: simply some common (and cheap) sealing silicon, and some ordinary, cheap food starch. Put the food starch (more  than silicon) on a table surface, add the silicon on top, touch your fingers with the starch powder, and then simply knead the starch into the silicon, until the result feels and behaves like putty for children and is therefore easy to handle and to bring into desired shapes. I then put it around the shaft, shaped it to a cylinder, and then rolled it between two wooded spoon shafts to get this rounded lowering in the middle. That lowering will hopefully prevent the band between motor and shaft to slip off that extension. The silicon rubber extension will give a good grip to the band to propulse the shaft with the two wheels later on.
Photo: ordinary sealing silicon and common food starch.
To make authentic but "used" flags that got their share on steam exhaust, I designed them as graphic files and then got them at a printer shop heat-transferred onto white cotton fabrics. The price for that was low. Instead of plainly colored flags, I decided for some changes here, too: the flags show now all nine federal state flags (from the 1860s) of the states the ship passed through on its journeys! And above the name flag of the ship will now be a huge US flag, also from the 1860s, like the flags of the federal states!
And there will be a huge water-slide decal for each of the two wheel houses. Many steamers of those days had some decoration or paintings there. Now my ship has, too!
The ship will also have white and black-dyed cotton balls as steam imitation, yellow fire LEDs inside the two main chimneys to simulate fire coming out (visible through the black smoke), fire-yellow light below the steam engine (I know I know, that is technically wrong), and a gentle, not bright illumination where all the cabins would be. There will also be curtains (wine-red and olive-green) behind most windows, as those heavy curtain colors were common of that era. There will be plenty of freight on the cargo deck, and a lot of life aboard the ship...
    January 2015
Posted by PFJN on Monday, February 11, 2019 11:11 AM
Hi,
Your pictures aren't showing up in your post, though if I click on the links it does take me to them.
The model looks very interesting and I can't wait to see more. Big Smile
PF
1st Group BuildSP
fox
    January 2007
Posted by fox on Monday, February 11, 2019 11:32 AM
Looks like you're planning to put a lot of work into her. Will be following your build closely as I have one in my stash and will need all the help that I can get to build it.
Good luck.
Jim  Captain
 Main WIP:
    February 2016
Posted by gene1 on Monday, February 11, 2019 1:25 PM
In case you all need some info or help on that kit , Steve5 did a beautiful job on it a few years ago. He even got wood decks for it. I built it back in the mid 1950's when it first came out, but steve5's is the best of that kit ever.
    February 2019
Posted by Hirnsausen on Monday, February 11, 2019 1:34 PM
Yes, I know. It was his thread why i decided to join here, too. :-)
Is there any way to edit my initial posting? I want to malke all photos visible. But i don't see any EDIT feature...
    February 2019
Posted by Hirnsausen on Monday, February 11, 2019 6:39 PM
UPDATES
The side of the luggage cabin that is facing the steam engine, got now "dirty".
Dirty Luggage Cabin Dirty Beams
Yes yes, steam engines are very dirty and should be replaced with solar energy... Wink
Dirty Steam Engine Dirty Deck around the Steam Engine
The decks show now signs of heavy usage - the surface has been rubbed off by shoes...
Used Deck Passenger Cabin Area
Cotton Fabrics for the window curtains, tents, sun and rain protection for the cargo deck, and those half-round decorations in the colors of the US flag. Some work ahead...
Cotton Fabrics
In the case of this particular model kit, zip-ties are your friend. Your very close friend...
You'll need Zip-Ties Beams for the Main Deck Beams for the Luggage Cabin
By the way, this is my work table. I added a number of features to it, that allows me high-precision work: bright illumination, mount for rotary tools, and magnifier.
Work Table Work table
    March 2009
Posted by surfsup on Monday, February 11, 2019 6:51 PM
Very nice work so far. Watching with interest.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    February 2019
Posted by Hirnsausen on Monday, February 11, 2019 9:25 PM
Thanks for all the nice postings! Well-appreciated! And here is a question: look to the painting above. here, the hull of the REL is painted all in black, and I think, it looks better that way. Should i paint the hull entirely in black, or should I keep the above-water area in white like on the other paintings? What would look better?
UPDATES
Okay, and it goes on! I finished now the underlaying beams that carry the over-hang of the ship's main deck. And I think, it looks quite nice! Gotta paint it tomorrow...
Beams Added to Main Deck Beams Added to Main Deck Beams Added to Main Deck
    February 2019
Posted by Hirnsausen on Wednesday, February 13, 2019 9:30 AM
UPDATES
Just for a new test, I put the ship together again, this time not even drops of glue used. As the tar was darker, I will darken the gray decks soon. My airbrush has a problem, that is halting my painting and therefore my construction for now. Cannot buy any airbrush here in Jamaica, replacement by online shopping will take 1 or even 2 months until delivery, saving money not even included. Huh?
    May 2006
Posted by Shipwreck on Wednesday, February 13, 2019 10:55 AM
Hirnsausen, Sorry to hear about your airbrush problem. I have a possible solution. You are painting on plastic that is representing wood. Use a paint brush; it will probably look better than sprayed paint!
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5+2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
    June 2014
Posted by Tanker - Builder on Wednesday, February 13, 2019 3:58 PM
Hey ;
   Whatsa matta fer you ? Dis is a nice job I see here !! I think you should keep goin with the hand brush , stead ob de air thingy .You can do it ! T.B.
    February 2019
Posted by Hirnsausen on Wednesday, February 13, 2019 11:18 PM
Hi, the gray decks were actually not dark-painted wood, but covered by tar sheets. Brish wouldn't be the best solution here. Still, thanks for the nice advise.
    February 2019
Posted by Hirnsausen on Thursday, February 14, 2019 11:20 PM
And here is a question: look to the painting above. here, the hull of the REL is painted all in black, and I think, it looks better that way. Could it be, that the REL was painted in different ways, over the years? Everyone: please tell me if I should paint the hull entirely in black, or should I keep the above-water area in white like on the other paintings? What would look better?
    July 2013
Posted by steve5 on Friday, February 15, 2019 12:45 AM
I'm enjoying your build hirnsausen , but I can't really answer your question it's such a personal thing . I did mine white and I'm happy with it . I looked for a good photo to post but the bottom is alway's in shadow . if you aren't going to display it up relatively high , you really won't notice it .
steve5
    July 2014
Posted by Bakster on Friday, February 15, 2019 10:28 AM
Cool build. Subscribed and watching.
    July 2014
Posted by Nino on Friday, February 15, 2019 5:02 PM
Hirnsausen
... Everyone: please tell me if I should paint the hull entirely in black, or should I keep the above-water area in white like on the other paintings? What would look better?
Steve's right. It's a  personal choice. (What paint do you have more of?)
I lean toward the Black for both above and below waterline.  With White or "bright wood" for the Deck edge.
My 2nd suggestion: You could go with white above the black at the Bow where the hull shear is higher.
However...here is a Robert E. Lee in 1898:
What color is that? Could it be red?
I am sure we will like whatever you choose.
You are doing some really great work. Thanks for Posting it.
   Nino
    February 2016
Posted by gene1 on Friday, February 15, 2019 7:12 PM
Riverboats have been a big facination to me for over 80 uears. I rode on the real wooden ones in St.Louis back in the 1930's. I have built a bunch of them & still have a big wood one I built 15 years ago. I have a sternwheeler that I have never finished. You might be right on the black hull.
Here is my wood REL & I left the decks real wood natural.
I will be back with some more that might help, after dinner.
    February 2016
Posted by gene1 on Saturday, February 16, 2019 9:13 AM
You are coming along very nice with your Robert E Lee & I am looking forward to seeing more . I never thought of a black hull, but it would make sense.
    I remember that there was more than one REL made, I think 3. They were made either at Jeffersonville Ind. or Marietta , Ohio. Both were big riverboat building towns. Jeffersonville is just above Louisville & has or had a great riverboat museum. I have been to both 3 or more times because I love riverboats. I have a picture of my grandparents on a wooden riverboat taken around the end of the 1800's or early 1900.
    February 2019
Posted by Hirnsausen on Saturday, February 16, 2019 5:35 PM
Still undecided if I make the hull above the waterline black, or even very dark gray (almost black). The hull below the waterline will be black.
UPDATE
I have started to assemble the two paddle-wheels. However, both wheels are not yet glued to the shaft in between, as later construction requires me to place the shaft alone, without wheels, to its future position. I won't add all small boards to the wheels as I need space, after permanently gluing to the shaft, to paint some inner areas on the shaft red where it came off.
    August 2007
Posted by DUSTER on Sunday, February 17, 2019 2:34 AM
 Hirnsausen, I like your work and ideas for this build.  As to the hull color I, personally like the black, but should you chose to go with any other color, remember, the Mississippi is called the “Big Muddy” for a very real reason. So any color of hull would not stay clean very long before  getting a brownish “muddy” stain to it.  So you can decide and whatever you pick will look very good, going by what you have done so far.
Here is another pictrue (see NINOs post above) of the "second" REL at is launching. As it shows no stacks and seems to be still needing to have its final detail work done, the color of the hull may only be some primer color to be over painted later(?)
http://leelinesteamers.com/?page_id=1054   for more about the REL , if you have not already found it.
Steve
    February 2019
Posted by Hirnsausen on Sunday, February 17, 2019 2:50 AM
Thanks for the new photo. I am still undecided, if I make the above-waterline hull very dark gray, or if I keep it white. However, at least i have some other progress to report!
UPDATE
Finally got the bottom of the luggage cabin finish. See now the beams, and the smoke-caused dark dirt close to where the boilers will be later on. And I also got the below-waterline hull black. That was a long work, as my airbrush almost "whispers" a black mist on a too limited area. I wonder, if there are ways, to increase the output of an airbrush to a wider area and more paint at a time. However, the ship with its wheels looks strange for today's eyes but also very nice. I made sure that the red is a very decent one - not too bright. I mixed red with a small amount of black and a tiny amount of yellow, to make it very warm
And now it's time for me to end my day.
    February 2019
Posted by Hirnsausen on Sunday, February 17, 2019 5:33 PM
Fire and corrosion are dangerous things, do not take them easy...
UPDATE
I drilled a hole into each of the chimney tops. This will allow, later, that a yellow light that emits from the LEDs inside the chimney will illuminate the bottom of the black-dyed cotton balls that I will use to imitate the black smoke of the two main chimneys. This will, later on, giving the appearance of fire below the smoke!
And I finished the assembly of the two paddle-wheels, but still have to do some paint magic on them to make them looking authentic and used. Because I mixed the silicon with corn starch, I was able to paint the silicon in the middle of the shaft. That's what I call a good side effect.
The steam engine looks now used - there are small traces of corrosion all over! I still have to do some more aging where the machine has any edges, but it looks quite authentic already. Enjoy the photos!
    February 2019
Posted by Hirnsausen on Monday, February 18, 2019 2:54 AM
The style of her time...
UPDATE
I finally made the decision to use a dark color, anthrazite (that's almost black), for the lower side of the cargo deck's overhangs . And I darkened further the gray of the upper decks, to get the color closer to the tar or asphalt sheets they used in those days for deck flooring. It now starts to look really real. When looking to a number of contemporary ships of that time, I see that they often used black or dark gray for many elements of a ship. While I leave the hull above the waterine white, I now have at least a dar area below the overhanfs - and it looks good! But I also encountered a problem: my regular plastic glue seems to fail on the connection between plastic deck and the nylon zip ties. Any suggestions which glue could manage that combination between these two materials? For now, the paint adds a bit to the holding power of the plastic glue, but just.
    July 2014
Posted by Nino on Monday, February 18, 2019 7:54 AM
Hirnsausen
  Try Zap adhesives 560 Formula Canopy glue.  Takes awhile to set up but so far it has worked on everything I tied and it is water clean-up.  ( Gene1 gave me the advice to try it.)
     Nino
    February 2019
Posted by Hirnsausen on Monday, February 18, 2019 11:45 AM
Thanks! I see it now on Ebay, and will purchase it. Yes
    February 2019
Posted by Hirnsausen on Tuesday, February 19, 2019 12:25 AM
AN UNEXPECTED COINCIDENCE / A THIN TRACE LEADS TO 99 X
Since I'd painted my model of the REL (Robert E. Lee) - that paddle-wheel river steamboat that dated back to the late 1860s, I couldn't help but wondered, that this color combination of light-brown wood, red, white and gray had something so familiar to me. And I couldn't point towards the right direction. That was, until I had a drive to outside of Kingston, passing by the small community of Harbor View, and then saw it! There was that newly built Kenturcky Fried Chicken store, and it had the same colors! I passed by there each day, but it was only then when I was able to pinpoint that strange familiarity!
And so, I decided to do some digging into the dusty books of history, to find out if there is any deeper reason of this color similarity...
We know, that the REL was built right after the end of the US-American Civil War, 1866, the very first year after the Civil War ended, is her year. And Kentucky Fried Chicken?
To my disappointment, Colonel Sanders (An honorable "Colonel of the "Commonwealth of Kentucky", not of the US Army) was born long after the Civil War had ended, in 1890, and in Kentucky. Damn. That means, those colors were not necessarily a common color scheme of the 1860s. Was maybe Kentucky a Confederate country during the Civil War? Again a dead end, Kentucky was "half-half". Neutral.
With other words, I could not locate any bridge between those both identical color schemes. But I still took a great benefit out from that search: During my investigation about Colonel Sanders, and with a hungry belly, I probed online for the PATENT of his chicken recipe. While i found his patent of the cooking method and tools, I learned that in order to keep it secret their ingredient list is a so-called registered Trade Secret and  not a pentent that lays out publically all ingredients. But ... when reading about the history of the cooking recipe, I came across a certain company by the name of Marion Kay Spices. Back then, before 1982, Colonel Sanders of KFC shared his secret recipe with Marion Kay Spices as he neded them to deliver that so highly special spice mix to all his franchised restaurants. In 1982, the new business owners of KFC sued Marion Kay Spices to stop all selling to their franchised restaurants, and to stop selling that KFC-labeled spice mix...
Dead end again? No. That company, that once produced for KFC that unique spice blend,still exists today. After they lost that law suit, the renamed that globally most-wanted spice blend to "99 X" and still sell it today! They do not advertise it, it is an insider tip only very few know who have conducted their research. Go to their website, and check it out! Also find the text of the 1962 KFC patent how to prepare their chicken pieces - you can't do the one thign without the other thing.
That "99 X" seems to be the real thing, and I just ordered 25 oz of it!
Imagine that this all could never have happened if it wasn't for the identical color schemes of the REL and a number of KFC restaurants...
Here one more URL for ya:
https://en.m.wikipedia.org/wiki/KFC_Original_Recipe
    July 2014
Posted by Nino on Tuesday, February 19, 2019 7:12 PM
Now I'm Hungry.
 That's cool you noticing the colors but Don't eat fried chicken while building models!
     I had a Photography business many years ago.  I never ate fried chicken. That grease can really do a job on camera lens coatings.
KFC colors... attached.
    Nino
    February 2019
Posted by Hirnsausen on Wednesday, February 20, 2019 1:49 AM
Yes, I absolutely agree - fat can be very bad for many things. Any flat (matt9 surface would become glossy, even some fresh paints won't stick anymore to the plastic surface. I make sure that my hands are clean.
UPDATE
I finally glued the deck onto the hull, and also aged the deck. Some more edge-aging will come later on. I also aged the wheels as their outer edge touches the water, which keeps those areas wet and even a little bit muddy or dirty.
But having reached here now, means that I have to pause until some items i ordered from the Internet will arrive: a small motor to turn the wheels slowly, and rechargeable batteries, and some more stuff. Can't go on without having placed all those while I can access the relevant deck areas still.
    February 2019
Posted by Hirnsausen on Friday, February 22, 2019 2:27 AM
UPDATE
Adding "windows"...
At first, that Kristal Klear appeared whote, but was transparent when dried. Very similar to the white school glue but slightly improved.
    February 2019
Posted by Hirnsausen on Saturday, February 23, 2019 6:03 AM
UPDATE
Making steam today.   Smile
Using regular white cotton balls, and then boiling them at first in water with yellow food color, and afterwards after an exchange of water, in water with black fabrics dye. This will give me a dark smoke with a tiny touch of yello (dirty black smoke). Also making plainly black smoke by leaving out the step with the yellow food paint. But, heck, the dyed cotton balls take LOOONG to dry...
