Lindberg Brig of War
    February 2019
Posted by jadowning17 on Thursday, February 14, 2019 2:49 PM
Greetings all. I'm starting a newer version of Lindberg's Brig of War and wondered how the build went for other modelers. I understand it's an old Pyro mold and based on a model of the Fair American. I've already removed the partally furled lower square sail on the mainmast as many brigs I've seen do not have a sail bent to that yard and I plan to separate the leech ends of the plastic sails from the yards to space the yard/sail assemblies more realistically on the mast. Any other suggestions or comments on this build are welcome.
Also I'm interested in posting photos but not sure how. Looks like Photobucket is the site most folks use?
Thanks
    July 2014
Posted by Nino on Friday, February 15, 2019 1:12 PM
Hi Jon, and Welcome!
   Couple of things...
       I do not recommend Photobucket.  Use anything but that.  There are several other GOOD free alternatives: Imgur, Flickr, POSTIMAGE, among others and a few Pay sites that are inexpensive and dispense with Ads for Russian brides. There are many Hosting Site suggestions that have been posted over the last 2 years here on FSM.  Take a look at the Technical Assistance Forum for guidance and also the Testing Forums for playing around.
    Getting the link for Posting an image is a bit different depending on what Hosting site you use.  Once you pick a site and upload some images to it, we'll get you the info you need to get those pictures added. Just ask.
     Thank you for this Thread. That old Pyro, now Lindberg, Brig of War lends itself to a fun easy build and good learning experience and, if you have the desire, to some worthwhile corrections to the Hull, Deck and Yards.
     If you have built it before you've noticed it's rather robust hull shape; The Stern is quite wide. The real Brigs were quite slimmer toward the stern. Besides the Hull shape the yards are too short.  The masts are a correct height however.
  Some History... This model was said to be a copy of the Fair American. Pyro surely Pirated this piece of Plastic from the Plan Produced for the Fair American kit  by Model Shipways. Except Pyro made it closer to a bathtub toy shape.
A most interesting discussion of the Pyro Brig of War is here:
http://roberts-old-ships.blogspot.com/2015/11/the-lindberg-brig-of-war-conundrum-in.html
A Build of the Fair American wood kit is here:
https://modelshipworld.com/index.php?/topic/18683-fair-american-by-jimvanlan99-model-shipways-148/&page=2
     I really like this kit and have a couple in the stash. Made one as a kid and only built another two years ago with as many "fixes" as I was capable. I want to make another with better corrections. My experience with model ships dates from 2014 after a dry spell of 50 years so I'm still learning.
I will be an avid watcher to your Posts.
Thanks.
         Nino
Posted by rcboater on Saturday, February 16, 2019 9:33 AM
Yeah, if you’re looking for something resembling an accurate, realistic model, this kit is a terrible choice. But it can still be a fun project, a cheap way to practice some modeling skills to improve kit parts or scratchbuild replacements.
Even if you ignore the hull’s major dimensional issues, improving the masts and rigging will make a noticeable improvement. The resulting model will look good on the shelf, especially if displayed at eye level!
-Bill
Webmaster, IPMS Patriot Chapter  www.ipmspatriot.org
Billerica, MA
    February 2019
Posted by jadowning17 on Monday, February 18, 2019 11:23 AM
Pictures coming soon hopefully!
    February 2019
Posted by jadowning17 on Monday, February 18, 2019 11:24 AM
Thank you!
    February 2019
Posted by jadowning17 on Monday, March 4, 2019 10:35 PM
Any ideas on what to do with the ringbolts on the deck? There's 10 of them. I've painted them black and wanted to add some detail by drilling through the "hole" in the middle and run some black or tan rigging thread up from below before I install the deck. Just not sure what I'd use them for. The Model shipways model of the FairAmerican doesn't show them. Suggestions?
    February 2019
Posted by jadowning17 on Monday, March 4, 2019 10:47 PM
Here are some in progress photos. I've cut the yard and sail assemblies apart for more realistic spacing on the masts. I used anchor stocks and a boat, probably hang it over the stern, from an old Constitution parts model. Going to take the suggestion from Nino to use a paint pen for the clew lines and reefing lines on the sails. I didn't want a square sail on the main yard so I cut it off.
    February 2019
Posted by jadowning17 on Monday, March 4, 2019 11:06 PM
https://flic.kr/s/aHsmBjoPQx
Please click on photo or above link to see more pictures.
    July 2014
Posted by Nino on Tuesday, March 5, 2019 1:30 PM
jadowning17
     As deck hardware these Rings seem way overscale.  Had they been placed directly behind the Cannon they could be for Rigging the guns.
I built mine years back. My solution was the same as your suggestion; Drill it and run a cable thru it.  I wish I had sanded'em off but I was so happy with my Brass masts and corrected stern that I quit "correcting" while I was ahead.
I hope some knowledgable folks will chime in on a proper solution.
My pic:
That Fair American model (Web Picture below) uses the grating hole for cable storage.
No rings on deck.
Nino
    February 2019
Posted by jadowning17 on Tuesday, March 5, 2019 9:49 PM
Thanks for the response, your deck detail is great! Well, I'll try and utilize some of those ring bolts then. Sanding and cleaning up the keel tonight,maybe add some putty and detail to the forepeak. Jon
    February 2019
Posted by jadowning17 on Monday, March 11, 2019 9:59 PM
Update time...
The hull is cemented together but the deck and boat beams on the stern are just test fit for now.
I cut two more gunports near the bow and found an extra cannon from an old Heller Phenix build. Think it's a 6 pounder on that ship but we'll pretend it's a 9 pounder bow chaser on the ol' Brig.
Getting the extra boat from a parted out 1/196 Constitution model dressed up. Made a couple oars from some scrap deadeyes left over from a Lindberg Jolly Roger. The black boat support beams at the stern were curved quarter boat davits from the Connie parts I just cut off the curved end and painted black.
Trying to put together a capstan with bars using a plastic deadeye and backstay assembly cut apart from the JR spare parts also.
Went ahead and drilled through all the ring bolts on deck, going to run some line up through them prior to fitting the deck. Still not sure what to use them for though.
Cannons are all painted. I couldn't resist painting red on the barrel ends to simulate tompions. I love that look.
Going to try and fill in the fore peak with some plastic or putty and attempt to simulate a grating. This has been a fun model to experiment on making custom pieces, still learning about all that. All the models I built in my teens and 20's I built just as is out of the box.
Cheers, and thanks for looking.Smile
    February 2019
Posted by jadowning17 on Monday, March 11, 2019 10:12 PM
Click on the link below to see the rest of the in progress photos.
IMG_20190311_213646125_HDR
    February 2019
Posted by jadowning17 on Tuesday, May 7, 2019 3:42 PM
It has been a while since I posted an update on this build. Life is busy! But I have fitted the cannons and rigged them simply (first attempt at cannon rigging), and the masts are stepped and the basic standing rigging is set. Pictures to follow soon, hopefully.
    July 2014
Posted by Nino on Monday, May 13, 2019 1:42 PM
    Your Pictures of the hull look real good.  In fact, one picture of  the hull looks real good for proper width at the stern.  Excellent brush painting on the deck "furniture" too.
I tried to find more info on the so-called Rings on the deck.  They could have been used as part of the tackle to run the Guns in but don't seem to be positioned properly for that either.
  Keep up the great work.  It is a fun model and there is a lot that can be added... if you have the good eyesight and tiny tools to do so.   I tried to add a "water channel".  I won't do that again.
    Nino
P.S.  Don't forget to take a look at some photo's of the old Fair American for ideas.
    September 2005
Posted by warshipguy on Wednesday, May 15, 2019 8:56 AM
You are doing a terrific job!  However, I do have one comment.  I do not believe that the Fair American model from which this kit was patterned was coppered.  I recommend sanding the coppering detail, rescribe the planks or do your own planking, and paint it an off-white.  It's just a thought.
Billl
    February 2019
Posted by jadowning17 on Wednesday, May 15, 2019 11:11 AM
Thanks, Nino. Always great to hear your input. I'm referencing the Fair American for the rigging now. The boat I fixed at the transom is an extra obviously. Not sure where else to put it. I decided to drill out the eyelets and run hawse cables thru them from the anchors to the capstan. Life has been very busy lately so it's slow but steady going. Cheers!
    February 2019
Posted by jadowning17 on Wednesday, May 15, 2019 11:17 AM
Hi, warshipguy! Thanks for your kind input. That's a great idea to sand off the copper sheathing. I have a second, older pyro brig of war I plan on narrowing the hull at the stern like Nino and others have suggested and will definitely take a crack at sanding off the copper sheathing and doing a planking set up to replace it somehow. My current build is a gift for my brother. It's been fun and I really appreciate all the suggestions and support! My fiance has a laptop and helps me get pictures posted as time allows. Cheers ☺️
    February 2019
Posted by jadowning17 on Wednesday, May 29, 2019 9:02 PM
Please click on the link below or on the photo to see all of the photos of the progress I have made on the Lindberg Brig of War.
https://flic.kr/s/aHsmDSNdBn
Brig of War in Progress 2
I have set the masts in place, rigged the guns, hung the ship's boat over the transome, and set up the fore and aft standing rigging. I used Heller rigging thread and painted it gloss black to simulate tarred rigging on the real ship. I am currently working on the shrouds and ratlines. I am using the same method for the shrouds except that for the ratlines I will simply be using black sewing thread. Thanks for looking!
Cheers!
Jon
Posted by Don Stauffer on Thursday, May 30, 2019 8:47 AM
Looking good!
    February 2019
Posted by jadowning17 on Thursday, May 30, 2019 9:34 AM
Thanks, Don!
    February 2016
Posted by gene1 on Friday, May 31, 2019 10:21 AM
JAD, your Fair American really looks nice. Your painting is great. How big is that kit?  I built that ship in a wood hull, large kit over 55 years ago. Keep up the nice work.
    February 2019
Posted by jadowning17 on Friday, May 31, 2019 11:20 AM
Thank you, Gene. This model is about 6 inches long I believe. It's been great fun. Cheers! Jon
    September 2005
Posted by warshipguy on Friday, May 31, 2019 1:38 PM
Jon,
I have the old solid hull model of the Model Shipways Fair American. If you like, I can send some photos of the hull proportions for your next model.
Bill
    February 2016
Posted by gene1 on Friday, May 31, 2019 10:56 PM
jad, I can't believe you got that much detail in that small a model. That is a super job. warshipguys model is the one I built years ago. One you might also like is ,I believe , Lindbergs  Blockcade Runner. They are bigger with nice detail & only about $20. I have one & will build it after the Victory.
    Warshipguy was a career nuclear sub sailor. He served on 6 of them. He has a lot more guts than me.  He also gave me the Victory, along with many others.
    February 2019
Posted by jadowning17 on Saturday, June 1, 2019 7:27 AM
Bill, Thank you, that would be great! I'd like to get an idea of how much to trim from the deck to narrow it up a bit and also create a little tumblehome if that would be appropriate. On the current build I've just finished tying the ratlines for the starboard lower foremast. It's sort of crude and slow going but I'm having fun with it. Jon
    February 2019
Posted by jadowning17 on Saturday, June 1, 2019 7:41 AM
Gene, thank you for the compliment. I do enjoy detail painting. It's fun to see a model come alive with detail and colors! It's coincidental you mention the Lindberg Blockade runner. My fiance and I were in Charleston, SC last month and I learned about the Harriet Lane's presence there during the Civil War and researched her history, found the old Pyro model and snagged a newer Lindberg version on eBay a couple weeks ago. Looks like a fun build! Can't wait to see how your build goes. You do an excellent job. This weekend I will be working on the lower and topmast shrouds on the brig. It is my first attempt at tying shrouds and ratlines and kind of crude but I'm having fun with it. Cheers! Jon
    February 2019
Posted by jadowning17 on Tuesday, December 24, 2019 12:20 AM
These are the final pictures of my Lindberg Brig of War I finished in July this year. It was a fun project and I appreciate all the input from other enthusiasts on the forum. Sorry about the long delay in getting these put up.
Enjoy and Happy Holidays to all!
Cheers,
Jon
https://flic.kr/s/aHsmKe7SYB
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186164727@N03/albums/72157712341247867" title="last brigs"><img src="https://live.staticflickr.com/65535/49267473546_f6c6cd8db7_z.jpg" width="480" height="640" alt="last brigs"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
last brigs
