Trumpeter 1/48 scale U-boat
    February 2019
Posted by U505 on Monday, February 18, 2019 3:34 PM
Hello all,  I have the trumpeter 1/48 scale U-boat but I like to try a little something different with the interior and put as much extra detail in as possibie.
Things like valves, piping, gauges, etc. Even was considering the diving plane area.
Also the Hoist used to load Torpedoes in the tubes.
Some question l have are, where would the ammo be stored for the deck gun?
Also in the forward Torpedo Room what are the tanks for?
Does anyone know of a good books out there that would give better illustrations of each compartment?
Thanks to everybody in advance for any information they may have or ideas.
Posted by Tojo72 on Monday, February 18, 2019 5:17 PM
Well,this will be a fun project to keep up with for sure.
    June 2014
Posted by Tanker - Builder on Monday, February 18, 2019 6:06 PM
 The Tanks ?
Recharge air for firing the Torpedoes. Before you start . Go to your local Hobby Shop or Model railroad Store and pick up some Walthers oil refinery piping kits in " N "" H.O."and " O "scale . This will help with the piping runs all over the sub .Now then having done that and while you are still there pick up some " Tichy Train Group " Boxcar roof walkway kits .The Metal grating type .In " H. O " This will supply you with all the deck grating you will need if you pick up two sets . You can sand these paper thin if needed and place on inverted " Evergreen  " Small .010 angle iron strip placed upside down or right side up as needed .   T.B.   Hey U-505 , This works on the old REVELL U-47 , that's how I know .
    August 2014
Posted by goldhammer on Monday, February 18, 2019 6:10 PM
Might drop an email to the Museum of Science and Industry in Chicago and see if they have interior shots of 505 thay can send....really give you something to work off of for detailing the interior.   Or if close enough would be worth a day trip to go through her and take a boat load of pics for reference.
    February 2019
Posted by U505 on Monday, February 18, 2019 7:10 PM
Actually l live in Chicago, IL along with the famous U-505 so I do plan on taking a trip there to take pictures.
But even with pictures there are alot of pipes and valves going everywhere.
I actually have some nice individuals  from shapeways working on some parts for me for a start.
Thanks guys
    February 2019
Posted by U505 on Monday, February 18, 2019 10:23 PM
You mean the flood/ drain tank connected to the pump which is near the torpedo tube itself? Don't get me wrong I don't want to get too technical with the details but just enough! Thanks
    July 2014
Posted by Nino on Tuesday, February 19, 2019 8:28 AM
One source with interior pictures is this DVD:
U-995 German Type VII U-Boat - Illustrated Gallery of the Last Surviving Type VIIC U-Boat in the World.
Available here for $32.00:
http://www.uboataces.com/u995.shtml
 Many of the individual pics have made it to the internet too.
Here is a book with some interior pics:
U-Boat 1936-45 (Type VIIA, B, C and Type VIIC/41): An insight into the design, construction and operation of the most feared German U-boat of World War 2 (Owners' Workshop Manual)"
Look here for a sample of the book.
https://images-na.ssl-images-amazon.com/images/I/91gLgEPza2L.jpg
Those compressed air tanks were also used to launch mines thru the torpedo tubes.
The G7a Torpedoes used compressed air for the engine too. (a mixture of compressed air and steam.)
I don't have any write-up on the VII but here is some info on the torpedo loading equipment on the IXc boats which can be found here:
http://www.uboatarchive.net/Design/DesignStudiesTypeIXC-S75-3.htm
Some gear, like the small cradle, could be stored under the deck. On some Types the long beam, appears to have been stored on top of the deck.
Lots of room  between the pressure hull and deck. Our Gato Subs originally had small boats stored under the deck in the area forward of the bow gun.
Deck Gun Ammo: "It required a line of men (3 on the deck) to transport the ammunition from the main locker below the control room to the gun. The used rounds were taken back into the boat. The U-boats had a small water-proof ammunition locker for the gun on the deck in order to be able to start firing almost immediately when the order was given."
I don't have any pictures or documentaion of the early boats ammo storage.  Later "Turms" had water-tight compartments in the Fairwater for the AA guns.
Nautilus models made an upgrade for a later VIIc "Turm II Wintergarten"  showing the ammo storage locker/hatches.
I did not locate my photo of a VIIc Conning tower but here is a link to a photo of a paper kit which also shows ammo storage compartments in the VII fairwater.
https://image.dhgate.com/albu_513474012_00/1.0x0.jpg
Nino
    February 2019
Posted by U505 on Tuesday, February 19, 2019 4:07 PM
Thanks much Nino, l will look into it.
Posted by CapnMac82 on Friday, February 22, 2019 11:42 PM
Cap'n Ted over at eModelsUK has a long series on building his, and the lighting kit he used, too.
    February 2019
Posted by U505 on Monday, February 25, 2019 2:45 PM
Thanks, yes l seen his videos but he is building str8 from the box and is doing a nice job.
I like to add more details like a torpedo hoist in the front room. Anyone know any good books  or detail pictuers on a piece of equipment like that?
So many other details that could be added to give it that extra touch.
    March 2018
Posted by Luvspinball on Monday, February 25, 2019 4:09 PM
bunch of videos on YouTube of tours, personal walk-throughs, etc.  If you plan to visit, take a look at these and see what they missed so you can be sure to capture those images.
Bob
Bob Frysztak
Luvspinball
Current builds:  Revell 1/96 USS Constitution with extensive scratch building
