1/350 Academy USS Indianapolis
    January, 2017
Posted by bpippin43 on Monday, June 03, 2019 9:19 PM
I recently purchased this kit which instructions are very vague relating to painting.  Can anyone steer me to some assistance?  Thanks.
    July, 2014
Posted by Nino on Wednesday, June 05, 2019 10:49 AM
As I recall the Academy kit is supposed to represent the Indianapolis in 1945 after the overhaul at Mare island.  She is in measure 22 camo.
Here is a site with info on measure 22 camo:
Here is a site with High Quality pictures of CA-35 at Mare island for the overhaul:
Some of the Pics may assist with adding details
Let us know if this helps.
     Nino
    September, 2012
Posted by GMorrison on Wednesday, June 05, 2019 10:59 AM
If you like acrylics, AK Interactive has a set, USN Naval Camouflage Volume 1, that has the colors you need except for the hull red and black. I just bought two sets and am going to give them a try.
My old go-to is Testor's Model Master Enamel, however it's become a little harder to find.
Per Nino's link, the colors you are looing for are USN 20-B Deck Blue, 5- N Navy Blue and 5-H Haze Gray.
    January, 2017
Posted by bpippin43 on Wednesday, June 05, 2019 8:56 PM
This will help a lot.  Many thanks.
    February, 2016
Posted by gene1 on Wednesday, June 05, 2019 10:02 PM
These pictures of my Academy Indianapolis might help you. With it is the I 58 that sunk her.
They are 1/350 kits & I did use MM acrylic paints on them.
    August, 2005
Posted by Tracy White on Thursday, June 13, 2019 12:16 AM
Nino
So, this is not the correct Measure 22 to use for Indianapolis if you want to build her *as sunk* you need to do the 1945 version of Measure 22 - from the same site:
Essentially, by 1944 the Navy had figured out that it wasn't the color that waas important as much as it was the tone of the paint (light, medium, dark). There was more need for the ultramarine blue pigment necessary to make the purple-blue based colors than there was supply, so the Navy decided to go to neutral paints.
There was such a large stock of blue paints in the fleet that it's hard to say when a specific ship might have repainted in the neutral colors, however it is safe to say that by July of 1945 Mare Island Navy Yard, which was the Navy's West coast paint manufacturing yard, would have been painting ships in the neutral colors.
So Indianapolis would likely be in (neutral) #7 Navy Gray, (neutral) 5-H Haze Gray, and #20 Deck Gray on her decks. This was ordered for the Pacific fleet in February 1945
There is a small chance that Mare Island would still have stocks of 5-N Navy Blue left and of course it's totally up to the model builder to build as they want so it's not a 100% sure thing, but it's likely that she was in Neutral grays when lost.
Mission Model Paints has a couple of the colors in their acrylic line, I know there are more but I'm out of time for tonight.
Tracy White Researcher@Large
    July, 2014
Posted by Nino on Thursday, June 13, 2019 3:38 AM
 Thanks Tracy.
  The Academy kit is a 1945 version but  I figured the Indianapolis was painted the end of '44 in measure 22 so that was my reasoning.
I suspect the page referencing the 1945 painting as measure 21 threw me off too.
Thanks for that much better explanation.
   Jim.
