S.S. Doctor Lykes Revell H-355
    October 2016
Posted by Mrchntmarine on Monday, September 14, 2020 11:45 AM
So its done for now.  Have to do a stand later on.....  Ive tried to get some shots on a white background....  The 1st 2 picture i want to point out - I missed these holes altogether and did not notice them until taking the pictures.  I gasped!  Going back over the directions I see them no where and have no idea what they are for???  There are on both port and starboard sides fore and aft.  Anyone have a guess?  Anyhow, the custom decals turned out good.  The film was indeed a bit thinner that what ive come across before.  Anyhow, it was fun and the cracked hull repir turned out good i think.
Keep on building!
    September 2012
Posted by GMorrison on Monday, September 14, 2020 12:04 PM
Nice! She looks great. That's a nice kit and it's been a long time since I've seen one not built up as Hawaiian Pilot.
Those holes are for stays for the rigging. If your instructions did not include them; here are the rigging diagrams.
https://www.scalemates.com/products/img/4/6/3/103463-64-instructions.pdf
Bill
Modeling is an excuse to buy books
    October 2016
Posted by Mrchntmarine on Monday, September 14, 2020 12:40 PM
tks bill.  I thought they might be for rigging....  But there weren't any eye bolts or such and i really could tell by the detailed(HAHA) instructions what wold go there.  I had no parts and none were called out.  The rigging lines shown in the directions seem to fad into the deck.  Attached is what i had and also where the holes are.  I might make up some eye bolts to fill the holes??
Keep on building!
Posted by Don Stauffer on Monday, September 14, 2020 12:53 PM
Looks great!  I like to see civil ships.
Posted by Tojo72 on Monday, September 14, 2020 1:42 PM
I like it,whats the scale
    October 2016
Posted by Mrchntmarine on Monday, September 14, 2020 1:57 PM
Tojo72
1/367
Keep on building!
    April 2005
Posted by ddp59 on Monday, September 14, 2020 2:31 PM
depends on if scale is derived from the hull length, hull width at deck level or hull width at bottom of hull as hull sides are tapered not parallel.
    September 2012
Posted by GMorrison on Monday, September 14, 2020 2:55 PM
And, so often those three dimensions proportionally don't usually match up one to the other.
    October 2016
Posted by Mrchntmarine on Monday, September 14, 2020 3:27 PM
She was a C3 vessell  LOA 492 feet.  However the model is 15" top of bow to top of stern deck.
Keep on building!
    June 2018
Posted by DRUMS01 on Monday, September 14, 2020 3:28 PM
Nice build! good work......
Ben
I am a Veteran; to all other Veterans thank you for your service. Retired now and living well
PROJECTS:
- 1/350 USS Alabama (GB) - DONE
    September 2012
Posted by GMorrison on Monday, September 14, 2020 3:29 PM
To the extent that it matters, I usually measure something like the distances between masts or something like that, compare to a scaled drawings and call it that.
    October 2019
Posted by Tanker-Builder on Tuesday, September 15, 2020 1:00 PM
Hot Diggety Dog !
   It's so nice to see work like this on a Civvy Ship!. Very Nice Job. The rigging was supposed to be done Before you mounted the deck actually. That's where REVELL messed up! They weren't clear about that. What you can do is run it to the holes and find the right Evergreen rod or stretched sprue to plug the hole and lock the rigging in place. That Kingpost rigging was necessary.
      There were some of those in the Matson Fleet and I did do Chief Engineer on one, and then moved over to the liner Division. This was to wind down from Tanker duty with Shell. This way I could be home every month or so instead of six or ten months before home visits.
 The only other thing I did to my "Pilot" was to find Model Rail Boxcar walkways that looked right. Cut them linearly and created rails for it. 1/350 ladders( Long Stairs ) look right on her too, and Flat ladders where indicated.
    September 2012
Posted by GMorrison on Tuesday, September 15, 2020 1:57 PM
 Turnbuckle. But TB is right vis. simplicity.
Bill
    October 2016
Posted by Mrchntmarine on Tuesday, September 15, 2020 2:07 PM
Tks all!  Bill - very detailed diagram.  Where did it come from?  I may still do the rigging - i need to look around for what to use and how detailed i want to get.  Im guessing there are probably rigging kits somewhere out on the net.  This kit did not come with anything close to that - cable spindles or pulley's or the like....  And then, what to use as cable??  On and on - you all know the drill......   We'lll see.
Keep on building!
    September 2012
Posted by GMorrison on Tuesday, September 15, 2020 2:24 PM
Here's a link to another thread that has a lot of good info from Onyxman (Fred).
http://cs.finescale.com/fsm/modeling_subjects/f/7/t/162687.aspx?page=7
Here's a somewhat simpler image.
They look like something from the American Merchant Seaman's Manual.
Posted by CapnMac82 on Thursday, September 17, 2020 11:28 AM
Mrchntmarine
Looks like one of the various illustrations out on the net (image search "cargo boom drawing" and you'll see a tone of them).
There are similar drawings in several books, The Bluejacket's Manual, and Knight's Mondern Seamanship, just off the top of my head.
For a bit more detail, searching out the Boatswain's Chief/1c Manual describes the actions at a bit more detail.
For a quick overview, cargo booms are typically worked as a athwartships pair.
A given boom has four things going on at its far end.
There's the Lift which raises and lowers the boom vertically.
Then, there are two Vangs which orient the boom horizontally.
Lastly, there's the Hoist which sways loads up and down from the boom end.
Booms are usually worked in pairs.
One boom is spotted over the general center of the hatch, the other over the side to the pier.  The Hosts are then connected to each other at the running end.
To get something out of the hold, you drop the hatch Hoist while slacking the other hoist, the hook will drop down into the hold to where it's needed.  You bend on the cargo, and heave the hatch Hoist until the load is clear.  You then take in the slack on the dockside Hoist until the load veers from under the Hatch boom to the dock boom.  Lowering away puts the cargo on the dock.
Here's a video that might help (silly landlubbers call vangs "guys" and hoists "lifts")
    September 2010
Posted by retdfeuerwehr on Monday, September 21, 2020 6:09 PM
Nice explanation Cap'n Mac....you neglected the schooner guy, though, which kept the boom heads from splaying outboard. I was a BM3 on an AKA and had quite a bit of experience with cargo handling. The yard-and-stay rig (sometimes called the "Burton" rig) was an incredibly handy set up. Easy to rig and got the job done. I always enjoy your input on this forum.
    October 2019
Posted by Tanker-Builder on Tuesday, September 22, 2020 8:00 AM
 Hey Bill!
 Where'd you get that?That is the same one in my rigging book. You know what Mine is called. Revised Edition - Bluejackets Manual 1945. Cargo Handling, Chapter one! S'Funny, that is! They gave one to every sailor no matter what you hoped to be doing. I do believe the Bos'ns division may be the biggest divisions on some ships!
    October 2016
Posted by Mrchntmarine on Tuesday, September 22, 2020 10:16 AM
CapnMac82
Mrchntmarine
Nice video - tks.  Somewhat complicated rigging and this explains it nicely.
Keep on building!
    March 2005
Posted by mfsob on Saturday, October 3, 2020 10:44 AM
Nice, clean build of a not-often-seen subject.
And, yeah, you have to sometimes laugh at the "directions" in old kits, like you have to laugh/cry at the "directions" in some of the newer resin kits.
    October 2016
Posted by Mrchntmarine on Sunday, October 4, 2020 2:51 PM
mfsob
tks. I did enjoy it. I wish there were more of these - have to look. Speaking of directions - working on an edouard Lysander and didn't notice until after I glued the 3 piece cowling, that there was a drill hole spot in the directions and on the piece where I was suppose to  measure and cut a square out for an air intake. Busted it apart and cut out the drill splat and make my square cut.  Fit the pe and put it all back together....  Then noticed in the directions some  more PE that looked to go where the drill hole mark was - OMG - I thought I cut in the wrong spot - that I had done the cowling cut on the wrong half!
havenot triple checked but I think I got it right. Odd to mark a cut out with a drill hole spot!
Keep on building!
    October 2020
Posted by Monk36 on Friday, October 16, 2020 9:23 PM
@Mrchntmarine
Where did you find a model of Doctor Lyke's?
Paul
    October 2016
Posted by Mrchntmarine on Saturday, October 17, 2020 10:19 AM
Monk36
@Mrchntmarine
it Was a gift. I'm told it came off the internet some time ago and had been in storage. My brother had it.
Keep on building!
    August 2005
Posted by Surface_Line on Saturday, October 17, 2020 4:41 PM
Paul,
I'm pretty sure that the Dr Lykes kit is a twin with the Hawaiian Pilot kit.  There are a handful of them available on US ebay now.
Rick
    September 2012
Posted by GMorrison on Saturday, October 17, 2020 5:17 PM
It's an earlier release of the Hawaiian Pilot, which has been released over the years and isn't expensive.
Merch had custom decals made. You'll recall his were hopeless, old and cracked. I think it would also be possible to use rub down letters.
Bill
    October 2020
Posted by Monk36 on Saturday, October 17, 2020 7:43 PM
Thank you guys! I have seen the Hawaiian Pilot on eBay. I never put the two together.
Paul
    October 2016
Posted by Mrchntmarine on Saturday, October 17, 2020 9:40 PM
I have the Hawaiian Pilot too. Haven't built it yet....  The guy who did the decals did a good job - after he got the scale right. He was prompt on the mailing of the replacement though.  The kits are pretty close. By far the oldest kit I've made and the plastic was brittle and like GM, the decals were shot and turned in color.
Keep on building!
