Masking/Painting strategy
    September 2005
Posted by TB6088 on Wednesday, June 2, 2010 12:41 AM
I'm getting ready to attempt the Tamiya 1/350 scale New Jerseya that's been sitting on my shelf over the past year, and I've got a question about painting strategy.  In painting the decks, should I paint them first, mask, and then paint the vertical surfaces, or the other way around?  I reviewed some of the kit reviews but they didn't provide enough procedural details, so I looked at Make Ashey's Basics of Ship Modeling--- he masks all the vertical surfaces and then sprays the decks.  I don't understand why.  I'm wondering why it wouldn't be better to spray all the deck pieces prior to installation, then add the vertical surfaces, mask the decks and then spray the vertical surfaces.  This is my first attempt at something this large and complex, and I understand that masking is a huge part of the time spent on the model.  I'm just having a hard time understanding the advantages and disadvantages of the different painting approaches, and could use some enlightenment from you more experienced ship modelers.  Thanks,
Tom
    March 2007
Posted by bondoman on Wednesday, June 2, 2010 12:48 AM
Most such strategies don't include the ability to "add" the vertical surfaces, as you noted. When that's possible, painting it all before assembly is the way to go. But traditionally, before Trumpeter, decks and bulkheads were usually one piece. Try both ways. One consideration is that often there's a lot of fittings cast with the deck, like capstans, and it's easier to paint those first and then mask them and paint the deck. And don't discount hand painting. A very useful skill.
    August 2005
Posted by EdGrune on Wednesday, June 2, 2010 7:59 AM
Go back and check Ashey again.    He also demonstrates the technique where he paints the deck first.  Then he masks the deck leaving the bulkheads and deck fittings open.  He uses hundreds of little masking tape snippets to accomplish the job.   It is very labor intensive.  He then sprays the hull, bulkheads, and fittings.
Here is also a quick/no mask painting tip:  Paint the deck first.   When painting the hull & superstructure hold the model tipped away and spray from the below the deck edge line.   The deck edge can mask the deck leaving as much as much as 3/4 the height of the bulkhead accessible for painting.  Touch up the bottom of the bulkhead & fittings with a hand brush.
    May 2010
Posted by Glue Mark on Wednesday, June 2, 2010 8:10 PM
Hello Everyone!
I built the 350th Tamiya Missouri, Yamato, and Prince George by hand painting the decks and fittings before assembly, and leaving the superstructures unpainted because I liked the color. I did detail the rafts, guns, directors, spotlights etc and got a very good overall effect. The excellent fit of the entire Tamiya warship line resulted in very few, if any, noticable seams on the island structures. You just have to be carefull not to leave any glue marks, haha. I'm not a very sophisticated builder, so I try to keep it simple.
I am now in the middle of the 350th Trumpeter North Carolina, and had to give this issue some thought because the plastic was molded in what I considered too light a color. What I arrived at was to build and paint each level of the superstructures separatly, then assemble. This allowed adequate access to more areas that needed coverage. I painted the turrets and island side panels separatly as well. For the decks, before attaching anything, I decided to mask the steel plated areas, the gun placement protectors, most other metal areas, and any major areas that would be getting glue applied. I now plan to use dark tan spray enamel to paint the wooden portion of the decks, and either hand paint the masked off areas later, or leave them bare.
The kit has no signal flags or ship decals at all, so I have been surfing the after market sites for ideas. If anyone knows some good techniques and materials for flags and decals, I'd appreciate it.
Rusty
    March 2007
Posted by bondoman on Wednesday, June 2, 2010 8:54 PM
http://www.history.navy.mil/photos/sh-co-mk/camouflg/usn-wwii/3--bb3.htm
Rusty, take it a step further again you can get into a serious amount of fun. BB55 is a beautiful ship. I'd love to see your model.
    August 2005
Posted by EdGrune on Wednesday, June 2, 2010 9:25 PM
Glue Mark
Hawk Graphics offers 1:350 scale signal flags in small/medium/large sizes
http://www.hawk-graphics.com/pages/decals.html
s
Iron Shipwright offers WWII unshaded hull number decals
http://ironshipwrights.com/accessories.html
    December 2009
Posted by Harshman II on Wednesday, June 2, 2010 10:29 PM
I use hand paint..
Paint the deck first and super structure surface first. Then I tackle the hull and side super structure.
    September 2005
Posted by TB6088 on Thursday, June 3, 2010 12:53 AM
Rusty,
Thanks for the clear description of your process.  Simple sounds good to me.  You've confirmed for me that painting the decks and fittings before assembly is a reasonable approach, and it seems to make sense to assemble and paint all the superstructure subassemblies (island structures, turrets, etc.) separately and then attach them to the previously painted deck.  My experience with the fit of Tamiya kits makes me think gaps will be minimal, and if I use your approach--- not painting the superstructure elements and careful gluing--- I would expect the result would be cleaner demarcation lines between horizontal and vertical surfaces.  Considering that you avoid a large portion of the masking that Mike Ashey's approach would require--- it sounds like an approach worth trying.
Tom
    May 2010
Posted by Glue Mark on Friday, June 4, 2010 7:13 PM
TB6088
Rusty,
Tom
Tom- Glad to help. BTW, after painting the decks, I wound up painting all the exposed fittings as the bare plastic looked way out of place with all the darker superstructures.
BondoMan- I am right at the point I have to decide about paint schemes, weathering, metal parts, etc. I've been doing a lot of research! I started looking for rails when I noticed the deck already had holes for them, and still am not sure what I will do.
Ed- Thanks for the flag website. I've been thinking of making my own by printing out some website signal flags using a laserjet, and gluing them onto either wavey foil or shaped plasticard squares.
So many options; so few skills!
Rusty
