Thanks for all the comments guy's, I appreciate it.
@ checkmateking02 - This is a small ship for sure. It's the smallest sailing ship I've built since slapping together the 'Half Moon' in the early 70's. I think Rob is dead on when he said it's 1/180 scale. I had guessed about a 1/200 myself. The hull measures a little under 6 1/2".
@ Spru-ce Goose - Thanks! The C.W.Morgan is on my list also. I almost picked up the Academy New Bedford Whaler, but I'm holding out for an actual Charles W. Morgan. My wife says why not just buy the New Bedford Whaler if it's the same ship. Ahhh...she just doesn't understand, so I told her it's because of the nameplate. She got that.
@ Buckeye - Thanks! Much appreciated! Don't think my meager skills have every garnered an awesome description. C'est Bon!
@ warshipguy - Thanks Bill! You know, when I first got this little Lindberg kit, I felt the same way - it's a toy. I originally got it in a package deal with a Revell kit and tried to sell it on ebay afterwards because I just didn't want it. Like another member said on another thread - 'you can only build so many..' Bounty's. But.. I was looking for a 'fun build' and said why not.
Unfortunately (or fortunately for the Bounty) my AMS kicked in pretty quick and just couldn't let a few things slide. I didn't feel like correcting the bow - it's a fun build right? But those molded sails had to go, as did the molded ratlines. Then I stepped back and said, with a little more work I could have a pretty decent model (AND I would actually FINISH one!)
I've got 40 hours into Bounty and I have to say I've thoroughly enjoyed all but about an hour of that. The shrouds are/were the most challenging portion of this build for me. If I had something (a vise or ?) to hold the ship while I rigged it, it would be soooo much easier for me. I'm doing this rigging freehand on it's Lindberg base. It don't take much to move it, knock it over or whatever.
Anywho, back to rigging the HMS Bounty.
First pic tonight shows the added main topmast stays and main topgallant stay. I started rigging this ship from the bow back. I don't know if that's the correct or accepted method but it seems to be working OK for me.
Next, I put together the mainstay. I tied it off completely except for one line to add tension after the glue has set. I used the same brown eyes from the 1/96 Connie kit that I used on the forestay, and I used some copper eyes to mount it to the deck.
Mounted the eyes in the holes drilled in the deck.
I put a little tension on it, so the glue will set as close to the right position as possible.
I tied the anchors off with a couple of lines. I'm not real satisfied with this look, I'll probably change it after mounting the swivel guns.
Last pic for tonight shows the rigging so far and the newly mounbted deadeyes for the backstays.
Thanks for looking. More tomorrow or so.
Adrian
