Vietnam River Monitors
    August, 2005
Posted by EdGrune on Saturday, September 01, 2018 5:16 PM
Cleaning the model room and I came across the February 1992 issue of 'Scale Modeler' magazine (formerly known as  The Worlds Largest Modeling Magazine).  Volume 27, Number 2.  Now out of business -- check the library
In it is an article by Duane Pfister describing his build of a 1:48 scale ATC(H), scratchbuilt using sheet styrene and styrene stock.  Also included is a set of dimensioned 1:48 scale plans (2-view).    Yes, it is based on an LCM-8 hull, not an LCM-6
More modern materials and techniques may make the process less painful.  Although carving the hull out of Ren-shape or MDF is still akin to my previous recommendation of starting with a block and carving away anything which doesn't look like an ATC or Tango boat
    July, 2004
Posted by stikpusher on Saturday, September 01, 2018 5:18 PM
GMorrison
My "peeve", being now a CRC (Certified Rivet Counter), is models that have an array of weapons "laying around".
Bill CRC
Good man! Every soldier knows you don’t leave your weapon lying around out of arms reach. That is drilled into you head early on in training. Unattended weapons tend to grow legs and disappear.
Even a pintle mounted crew served weapon will have one guy sitting around guarding it.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
GAF
    June, 2012
Posted by GAF on Saturday, September 01, 2018 6:04 PM
CapnMac82
 In 1/72, PE would be just fine.  At least at a guess.
The bar armor was 3/4 x 3/4 x 1/8 angle stock (20 x 20 x 3mm) with 5/8" (16mm) reinforcing bar, which was stood off 12" or 18" (30 or 45cm) off the hull.
Now, at 1/35, you are right at where the "upset" (the raised texture) on the bar would "show"--this is what was frustrating in my ancient attempts.
That 20mm angle iron is about 0.6mm at 1/35; at 1/72 only 0.2mm.
5/8" rebar?  That's good to know.
It's the checkered plates that might also be difficult to replicate.  Does anybody make a sheet of that?
Gary
    July, 2004
Posted by stikpusher on Saturday, September 01, 2018 6:07 PM
Tread plate is made in styrene by either Plastruct or Evergreen. There is also brass tread plate out there. And textured decals by Archer for application to smooth surfaces.
       - Plankton
LSM
    May, 2009
Posted by Pawel on Saturday, September 01, 2018 6:36 PM
Ed - I have to respectfully diagree. I have even seen scans of the original modification drawings for the Tango boat and they all say time and time again the base is an LCM-6. Then again, a modelling article is not really a historical information. Can you point to some other source that says a Tango boat is based on an LCM-8?
Thanks in advance and have a nice day
Paweł
www.vietnam.net.pl
    November, 2005
Posted by CapnMac82 on Sunday, September 02, 2018 2:11 PM
GAF
The diamond tread plates are only on the upper surfaces.  Generally.
The hull "compartments" (and the pilothouse roof, if memory serves) are smooth plate.
The "no loose waepons" thing is complicated in VN.  You might be stationary in a position that could be "in contact" with little warning.  But, in the rainy season, stuff gets covered up often.  Which is why MGs are so often under covers
    June, 2018
Posted by TankerEasy on Tuesday, September 04, 2018 5:02 AM
Ill try and get pics uploaded tongiht of the PBR Mk II im working on.  Does anyone know of the best place to pick up a marine stowage set that would look go well with the boat?
Air Force vet (2006-2012)
PC gamer, rig specs: i7-7700K (overclocked), MSI GTX 1080 gpu, 16 gigs G.skill Trident Z ram, Phanteks case with purdy lights CoolCool
Recently completed: WW1 vignette
On the bench: 1:16 Dragon figure
    June, 2014
Posted by Tanker - Builder on Monday, September 10, 2018 3:10 PM
Hi;
 You can find the Diamond Plate at Hobby Lobby , it's in the model railroad sccenery section .
    June, 2014
Posted by Tanker - Builder on Monday, September 10, 2018 3:14 PM
gary ;
In my experience ( remember I was there ) , most of the early ones were based on LCM-6 Boats . Now maybe the late ones that I didn't see were 8s but I kinda don't think so .Remember there are folks that see what they have been talking about only to find they are incorrect !
    January, 2015
Posted by PFJN on Monday, September 10, 2018 8:12 PM
Tanker - Builder
....Remember there are folks that see what they have been talking about only to find they are incorrect !
Hi, that reminds me of a quote a freind of mine was fond of.  I think it was something along the lines of "If I didn't believe it, I wouldn't have seen it".
    September, 2012
Posted by GMorrison on Monday, September 10, 2018 8:19 PM
PFJN
Tanker - Builder
LOL! My neighbor came over and said "I know I shouldn't believe anything on the internet, but..."
It would seem to me that if drawings could be had, it would not be hard to build this.
    July, 2014
Posted by Nino on Tuesday, September 11, 2018 9:10 AM
TankerEasy
The whole story of the brown water Navy is pretty neat, its too bad it isnt talked about more.  It seems to be a part of the Vietnam war that isnt metioned much, I only know of one documentery about it.
  I came across a web site that should be of interest to you.
They do mention LCM-6 .  No LCM-8.
http://www.warboats.org/stonerbwn/The%20Brown%20Water%20Navy%20in%20Vietnam_Part%201.htm
    Nino
    May, 2009
Posted by Pawel on Tuesday, September 11, 2018 9:29 AM
Hello!
GMorrison
I even have those drawings... Mr. Carrico used to sell them on a CD. But now his business is gone...
Have a nice day
Paweł
www.vietnam.net.pl
    June, 2014
Posted by Tanker - Builder on Wednesday, September 12, 2018 7:40 AM
Hi;
 Having owned 1:1 modified versions of thos exact vessels I can say , Building one is easier than it looks . I do think one of the R.C. Model companies did offer a hull . Can't remember which though  . Simple lines and fairly straight , forward bottom .  T.B.
GAF
    June, 2012
Posted by GAF on Wednesday, September 12, 2018 8:11 AM
Tanker - Builder
gary ;
TB,
I'm not sure if it was me you were addressing (Gary), but I was not confused about the LCM-6 and LCM-8.  This schematic clearly says LCM-6:
http://archive.hnsa.org/doc/boatcat/cat-0108.htm
I was interested in the CCB as my brother was radio operator on one coming up on 50 years ago.  He was stationed out of Dong Tam, though he said they were rarely at the base.  He was wounded in February, 1969 while out on a mission, and honorably discharged later that year due to his injuries.  He just turned 70 this year, and I was thinking about building a CCB model for him if there was one available, but apparently scratch-building might be the only way for me to do it.  Thanks!
Gary
    June, 2018
Posted by TankerEasy on Wednesday, September 12, 2018 2:04 PM
Nino
TankerEasy
    Nino
Thanks Nino!  glad this post has generated some good discussion and knowledge sharing!
    June, 2014
Posted by Tanker - Builder on Saturday, September 15, 2018 1:36 PM
Hi;
 I am not really sure if that was for you or not . I have a problem with names , seems there's too many Garys ! Lol. My name is Gary too !
    June, 2018
Posted by TankerEasy on Friday, September 28, 2018 5:09 AM
Does anyone know where the PBR's were fueled at?
    November, 2005
Posted by CapnMac82 on Friday, September 28, 2018 10:09 PM
Fuel dock (sorry, had to say it Smile)
Deck plate, aft:
For reference:
There's usually a funnel stowed under one of the engine hatches with the small end poked into a coffee can.
    June, 2018
Posted by TankerEasy on Saturday, September 29, 2018 7:16 AM
i had a feeling it was the small ports at the rear, thanks fo the help!  waning to make sure i get my detailing right Cool
    November, 2005
Posted by CapnMac82 on Saturday, September 29, 2018 3:35 PM
Over at ModleShipWorld, the NRG apparently has new, spacious digs, so, they are building a 1/6scale PBR.
Hmm, wonder if the 3d print shops will make a set of the "Diesel Only" caps for the 1/35 PBR?  Smile
    September, 2012
Posted by GMorrison on Saturday, September 29, 2018 3:52 PM
CapnMac82
Hasbro made a nice figure set for that model...
    October, 2011
Posted by iroquois1963 on Sunday, November 11, 2018 10:40 AM
Hello gentlemen.
I make this construction now, saddened, it is in French, I hope that it will please you.
http://warpaints.net/viewtopic.php?f=170&t=10116
 phil
    January, 2015
Posted by PFJN on Sunday, November 11, 2018 12:41 PM
Hi,
Thanks for the link.  That looks fascinating, and Google translate does a reasonable enough job at translating for me to understand most of the text Smile
PF
    November, 2005
Posted by CapnMac82 on Sunday, November 11, 2018 5:53 PM
Allow me to render that a "live" link:  http://warpaints.net/viewtopic.php?f=170&t=10116
Nice post on the ATC (H).  Worth noting that the helo-deck ATC were one in ten.  The bulk of ATC ought have an "A" frame canvas cover to shelter the passengers from sun and rain.
Kind of a shame that the kit does not render the tops of the trurrets as a separate item, many period photos show them stowed along the side rather than over the gun mounts.
I hope you do not mind English, as mon francais c'est ***.
Well, oops, it seems Kalmbach's censorbot recognizes a common French word for excrement.  Sorry about that.
    October, 2011
Posted by iroquois1963 on Tuesday, November 13, 2018 6:36 AM
Hello.
Great satisfied that it pleases you, anyway, I would make a complete comment here when I would have finished him, because I do not arrive has to do that of warpaints and having done it here, but it is promised, I would put quite here.
CapnMac , I arrive has to make me understand of you, I had learnt has the school English, there are rests and then there is a site REVERSO which helps me .hi hi hi .
phil .
