Lindberg Ironclads MONITOR & VIRGINIA --FINISHED--
Posted by gregbale on Sunday, March 24, 2019 6:07 PM
I have a grudging (and largely nostalgic) fondness for Lindberg kits. As a kid prowling dime-stores [remember them?] in the '60s, Lindberg kits were plentiful, affordable, and usually decorated with garishly exciting box-art...which often bore almost no resemblance to what actually lurked inside.
As I got older and moved on to Monogram and Revell kits, I began to understand how poorly-rendered many of those old Lindberg kits were. But to give the company its props: they covered an impressively-ambitious range of subjects...many of which are still-untouched by plastic-model producers all these decades later. And thanks to regular re-releases through those same decades, they're still reasonably plentiful and delightfully inexpensive compared to even mediocre kits by some other manufacturers. They still beckon in their odd way.
My approach to building the bulk of Lindberg kits is what I call 'Low-Budget Hollywood': if a cheapo film's 2nd-unit director comes to you as the 'prop guy' with a broken-down '60s yellow schoolbus and says "You've got two days and two-hundred dollars to turn this into the Battleship Arizona"...you're not going to worry much whether the fo'c'sle draft vent-covers had ten lines of louvers or only eight. In other words, if you're going for respectable scale accuracy, most times it would be simpler and easier to scratch-build. But trying to make a sow of a kit look sort-of like 'real' can be fun...and a useful exercise in 'fixing' without 'rivet-counting.'
Lindberg's ancient combined set of the Ironclads USS Monitor and CSS Virginia (the latter built on the burned hulk of the under-repairs Union steam frigate Merrimack) is notable chiefly for being in two different scales in the same box..with the Monitor  nominally 1/210 scale, and the Virginia listed as 1/300. Both are little more than basic shapes with crude detail. The Monitor has slightly-better fit simply due to its simpler design; the more complex construction of Virginia's casemate design inevitably leaves big gaps to putty. (As a side-note, both are mostly-covered in a raised 'plating' texture; while this doesn't look out-of-place for the Monitor, the real Virginia's casemate armor exterior was made up from sections of railroad rail...a whole different look.)
First hurdle for the Monitor was taken from the late (and sorely-missed) Prof. John Tilley's remarks in an old thread (on this forum) on the kits in question: for whatever reason, Lindberg positions the revolving turret shifted noticeably toward the bow. Very odd-looking, and impossible to 'disguise.' After studying the layout, the simplest answer seemed to be to cut out a non-symmetric section of the midships deck containing the turret ring, and flip it around 180 degrees. No way to avoid the annoying puttying and sanding required, but the rescribing of plating lines and 'wheeling' in the rivet-lines was easy enough, since everything is straight lines and evenly-spaced.
From there I built everything 'stock,' merely adding a turret-top with lattice and hatches instead of the kit's featureless one (which had the same 'plating' pattern as the deck). The kit's blocky vent housings and flat-sided pilothouse forward looked 'bare bones' and uninteresting, so I started adding bits, guided by photos and illustrations of Monitor: some HO scale boxcar siding for the sloping-armor 'pyramid' around the pilothouse, and some sections of brass tubing with copper-wire boss rings for the extended vent-stacks used when the ship wasn't in combat. (I ended up making a 'horseshoe' from laminated styrene sheet for the main vents just behind the turret.)
Since I'd stumbled onto a 'non-combat' configuration, the turret awning visble in authentic photographs seemed an obvious choice to add. Twist-tie wire brackets, a bit of stretched sprue, EZ-line and tulle netting worked for the structure. I had originally intended to do the awning itself with white-glue-soaked tissue...and probably should have...but an 'inspired' moment led me to try a 'Kristal Klear'-type application instead. It worked well enough to start...but started to 'shred' here and there (like canvas in a stiff wind) as it dried, and the 'touch-ups' made it lumpier and rougher-textured than I'd intended. C'est la vie. It wasn't worth tearing off and doing again.
Stretched sprue bracing wires for the stacks and a bit of chain for the anchor, and I decided to leave it as-is. Properly 'commissioned' with some paper flags...and my little Monitor awaits its (different-scale) Confederate opponent, which will be 'Part 2.'
Greg
George Lewis:
    January 2015
Posted by PFJN on Sunday, March 24, 2019 6:50 PM
Hi,
That turned out great Smile
1st Group BuildSP
    July 2014
Posted by modelcrazy on Sunday, March 24, 2019 6:58 PM
WOW, beautiful job Greg, can't wait for the Virginia Surprise
Steve
    April 2015
Posted by Mopar Madness on Sunday, March 24, 2019 9:45 PM
That’s impressive!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2010
Posted by docidle on Sunday, March 24, 2019 11:16 PM
Greg,
Outstanding job on these ancient model(s). I can hardly wait to see the Virginia. Now I know what to do with these puppies in my stash.
I hope you won’t mind if I “borrow” your ideas!?
Steve
    July 2014
Posted by Nino on Sunday, March 24, 2019 11:33 PM
Very Nicely Done Greg!
     I too played with the Pyro 1/210 Monitor and considered your plan for the correction. I ended up adding a deck section instead.  I think your execution turned out much better.   That is the best this old kit has every looked. Hurray for getting the Turret in the right spot.
Your enhancements, to match many of the post-battle changes to the Monitor, turned out really great. Impressive for sure.
    Nino
 EDIT:
P.S.  I forgot to mention that I really like your very correct base.
Posted by gregbale on Monday, March 25, 2019 6:50 AM
Thanks for the positive energy, guys!
Steve, feel free to 'borrow' anything that seems useful: pretty much every trick, tip or bright idea I've ever had in modeling has been inspired by others' work, so I love it if I can pass something on. One of the great things about the hobby and this forum is that we all learn from each other. Big Smile
Nino, nice spot on the 'correct' base. I've adopted that style as a common design for all my small(-ish) scale ships, just changing the flag to suit the subject and era, so I try to get it right. (It's a little easier in the internet age than it used to be, digging for it in encyclopedias!)
As to the Virginia...the longer I ponder on it, the more I feel I have to make some stab at representing a little-more-accurate version of her armor fit...but haven't decided quite how to do it, yet. Scribing all those evenly-spaced parallel lines would be a bugger, so I'll probably go with styrene strip to 'faux' the rail sections. We'll see....
Cheers
Greg
George Lewis:
    December 2015
Posted by templar1099 on Monday, March 25, 2019 7:51 AM
Really great job on it,awaiting the next project. I would love to see new plastic renditions of some ironclads as the only ones I've come across are resin.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
Posted by Don Stauffer on Monday, March 25, 2019 8:39 AM
I am very tempted to order the Bluejacket Monitor.  I believe it is wood hull with cast metal details.  Anyone built that kit and wish to comment on it?
    December 2003
Posted by scottrc on Monday, March 25, 2019 8:45 AM
Excellent work Greg. Creative use of an old Lindberg kit.
    January 2012
Posted by fright on Monday, March 25, 2019 10:13 AM
What a wonderful job you did in creating an excellent model.
Robert O
Posted by rcboater on Monday, March 25, 2019 7:27 PM
Don Stauffer
Don,
I don’t have any experience with that kit, but I did find a recent build thread for the kit on the Model Ship World site....
https://modelshipworld.com/topic/17893-uss-monitor-by-sjanicki-finished-bluejacket-scale-1192-116-1/?tab=comments#comment-550669
-Bill
Webmaster, Marine Modelers Club of New England
www.marinemodelers.org
Posted by Don Stauffer on Tuesday, March 26, 2019 9:08 AM
rcboater
Don Stauffer
Don,
-Bill
Thanks, Bill
    May 2013
Posted by Greg on Tuesday, March 26, 2019 10:34 AM
I am seriously impressed with what you have done with this kit, Greg. Yes
Honestly too many notable things about it to mention any few of them.
Posted by gregbale on Tuesday, March 26, 2019 11:58 AM
Thank you, Greg!
Greg
George Lewis:
Posted by Gamera on Tuesday, March 26, 2019 8:30 PM
That's an amazing job there Greg on turning a sow's ear into a silk purse!
Love the sun shield over the turret.
Posted by gregbale on Wednesday, March 27, 2019 8:48 AM
Gamera
Thanks, G.
As it happens, I was studying a collection of photos of the real thing recently...with sun-shield deployed, and smiling ratings sort of lolling about on deck and posing for the camera...which was what made me want to pull the old beast out and finally give it a go. (Those same pictures, BTW, showed prominent 'dimples' in the turret armor plating...obvious 'souvenirs' of her encounter with Virginia. I contemplated trying to replicate those dimples, but figured that would take me down a much more labor-intensive path than I was looking to trod! Embarrassed)
Greg
George Lewis:
    September 2005
Posted by freem on Wednesday, March 27, 2019 10:55 PM
Absolutely amazing, Greg! Echo the sentiments from the other guys.  I too have that set which I purchased in the late 80's in the stash and I built them in the early 70's but those were destroyed in battle.  Definitely moving this one up the build list!
Chris Christenson
    March 2009
Posted by surfsup on Thursday, March 28, 2019 5:09 AM
Beautifull built and displayed Greg.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    June 2014
Posted by Tanker - Builder on Thursday, March 28, 2019 6:23 AM
Hmmmm;
      My hat is off to you. Now see, Just what I have been saying. Lindberg models make a good Base for something Better. You just proved it !  T.B.
    July 2014
Posted by Bakster on Thursday, March 28, 2019 9:50 AM
Greg-- this is excellent work, an excellent presentation--and an excellent outcome. And I love the subject too! Really nice work sir.
Yes
Posted by gregbale on Monday, April 1, 2019 4:21 PM
Thanks, guys!
Greg
George Lewis:
Posted by gregbale on Monday, April 1, 2019 4:29 PM
Here's my second half of Lindberg's ancient box-scale set, the casemate ironclad CSS Virginia, with a few embelishments. No authentic photos of the craft are known to exist, and even original drawings and eyewitness accounts are frustratingly imprecise and occasionally contradictory...so color-scheme is somewhat 'by guess and by gosh.'
The original was built on the copper-clad hull of the salvaged steam frigate USS Merrimack. I wasn't keen to try to replicate the detail of all the iron plating, so I settled for painting the base copper and then weathering overall with a green/grey mix, with more olive tones closer to the waterline. For the upper-works, since the Virginia had to sail before she was actually completed, it seems most likely to me that the iron-plated casemate sides were unpainted; but intriguing references suggest her plates may have been greased as a measure to try to deflect iron shot more easily. I settled for basic semi-gloss black overall, drybrushed in lighter tones to simulate wear and plating detail, then with a thin wash of oily-brown metallic to simulate the greased metal. The lighter-grey funnel and vents are suggested by accounts and drawings, as are the red-painted (removable) lifeboat davits, and the bow ram.
As oddly-festive as she appears with jacks and pennants flying, she must have presented a more sinister appearance when she approached the Union squadron at Hampton Roads on that March morning in 1862.
And here are the two opponents forever linked by that epic day in naval history. Neither would survive the year: after Union troops occupied Norfolk in May, the Virgina was judged unsuitable to make the run into the Atlantic, and would be scuttled and blown up to keep her from once again falling into Federal hands; Monitor would in turn be lost in December, swamped and capsized while under tow off Cape Hatteras.
Greg
George Lewis:
    January 2015
Posted by PFJN on Monday, April 1, 2019 9:21 PM
Hi,
Both builds turned out great Smile
1st Group BuildSP
Posted by Gamera on Monday, April 1, 2019 9:32 PM
Yeah great job on the Virginia too!!
I'd never heard about the grease, that's a really curious idea. Wonder if it was also supposed to help with rusting?
Posted by gregbale on Tuesday, April 2, 2019 2:03 PM
Thanks, guys.
Gamera
It must have been. The Royal Navy tried it as well, when their iron ships were first coming into service. I think they quickly determined that grease offered some protection from corrosion...but it was easier to determine the condition of protective paintwork from simple visual inspection.
Greg
George Lewis:
    October 2016
Posted by DasBeav on Thursday, April 4, 2019 10:52 PM
They turned out great, Greg!
I have walked passed that kit in Ollies a half o' dozens times and didn't realize they had a hull!Bang HeadDunce Might half to pick on up now if they still have one.
 Sooner Born...Buckeye Bred.
Posted by gregbale on Friday, April 5, 2019 7:20 AM
DasBeav
Thanks!
If memory isn't playing tricks on me, I think some boxings of the kit over the years have come with a vac-form 'diorama' base where you could position the two in an absurdly-close battle mode; it may well be that box photos gave the impression that they're waterline kits. [They're not really designed as such..but given the 'architecture' of both vessels, it would be simple enough to do them as waterline versions...though the Monitor in particular would ride a little 'high' without a bit of surgery.]
BTW...what part of Ohio are you from? (I 'grew up' in Chicago...but I was born at Booth Memorial in Cleveland, and lived my early years in beautiful Avon Lake!)
Greg
George Lewis:
    October 2016
Posted by DasBeav on Friday, April 5, 2019 8:12 AM
gregbale
DasBeav
Thanks!
This is the box from Ollies. The review I saw on the web says they are different scale also.
I live near the town of Mansfield, which is half-way between Cleveland and Columbus. It bothers me sometimes when Cleveland gets a bad rap by people.
    June 2014
Posted by Tanker - Builder on Friday, April 5, 2019 8:56 AM
Hey;
Yousa is gotta nicea pair of the Boats from Lindberg dere! Really, you have done them justice .Thanks for the views . T.B.
