The Lonely Queen of the North
I'd be super excited. That's a kit that will build up well. May I offer the following:
I build ships primarily and they take a while. I'd probably spend at least 6 months to a year to get this one done. So if possible, and given the price and those 2190 parts, figure out some storage box or shelf or etc. where it can be safe while you work on it.
Those Revell of Germany end opening boxes are a nightmare and a sure way to break or scratch up parts. I suggest you either empty it once and set it aside, or usually I solidly tape all of the corners closed and cut the top on three sides so that it opens like a lid.
PE companies are a little notorious for showing their product installed on models unpainted. It looks swell as brass and advertises the product, but don't do it. Paint everything before you install it, in particular the stuff that goes on those beautiful wood decks.
There's at least one review I found, a footnote on the scalemates site, by Modellversium, a German modeling site. Use the translate button and read it. I thought it was well written. It points out the important differences in the ship with her sister. None are particularly consequential, but the kit is/was originally a Bismark, and it sounds like Revell included the added parts for some of them. But it explains how to go about fixing them if you are so inclined. Probably the only one I personally would care about is the shape of the bow, probably a little tricky to fix, but not really critical to the success of the build.
I like your taste! Have a good time building it.
