1/700 flag decals issues
    July 2004
Posted by eddiemac0 on Sunday, August 1, 2004 10:39 AM
ok, I've already posted this on the decals section, and everyone there seems lost...
My Tamiya 1/700 Yamato (first build) flags are on a waxy kind of paper. The decals folks assumed they were rub-on transfers, but were confused as to how this might work on a two sided flag. Do I cut them out, get them wet, and wrap them around???
Thanks everyone.
    January 2003
Posted by Jeff Herne on Sunday, August 1, 2004 11:58 AM
First thing to determine is tye of decal you're using...waterslide or dry transfer...maybe the instructions mention something, or someone else has built the 1/700 Tamiya Yamato.
Here's my suggestion for dry transfer...rub one side of the flag onto a piece of aluminum foil...then trim the foil to the decal...then add the second transfer to the opposite side. I'd give the whole thing a coat of clear once I was done.
For waterslide, simply do the same thing...aluminum foil allows the decal to adhere to something other than itself, and also allows you to 'wave' or curl the flag.
Regards,
Jeff Herne
Posted by Anonymous on Wednesday, August 11, 2004 6:37 AM
Great tip as usual.
Thanks for the help
    March 2004
Posted by bstrump on Saturday, August 21, 2004 11:18 PM
Eddie, if these are what I think they are, you apply your adhesive(like white glue) to one side, wrap it around the pole or the line and then fold it onto itself. Heller kits flags are like this. If you make them a little damp as well you can manipulate them into whatever shape you like and give them that "flying" look.
    May 2003
Posted by jtilley on Sunday, August 22, 2004 9:46 AM
I've got a Tamiya 1/700 Yamato in front of me (beautiful kit, by the way). I think bstrump is right. The flags are just printed on plain, thin, non-adhesive paper. Elmer's glue should work fine on it. There's plenty of blank paper surrounding the flags, for experiments.
    March 2004
Posted by bstrump on Sunday, August 22, 2004 1:25 PM
I forgot to mention to cut the adhesive with water. This will make the paper damp for you.
