Drybrushing is one technique to use to weather, however, due to the small nature of parts, will tend to make the weathering look heavy and out of scale. Another technique is to look up and learn to do washes. ( and make sure to open up to using enamel, acrylic, oils, and inks) This is by thinning the paint and going over the base many times until the hue that you want is obtained. My rule is to look up the grayscale (as referred by printers and photographers) to see what the base color will do when adding a lighter tone to it. Colors fade due to the elements such as salt, wind, UV and moisture, but are also tuned to the fact that ships are kept ship shape, so don't go overboard by showing a lot of rust, peeling paint, or exposed wood since a ship in that condition would not be floating long.
I use weathering not so show actual age, but to be able to blend the colors so that there is no abstract or clash to the model. I like to see my model as how a woman dresses with all the colors complementing themselves, and this can be done through washes. Washes are a must when aging sails, whether made of cloth or plastic, since it is really easy to make the sails look out of scale if the colors are not blended right.
I find that weathering varnished surfaces work well with diluted Future floor wax. By mixing too much water in it and then putting on heavy layers over a brown surface, makes the floor wax turn opaque and crack and peel, like weathered varnish. But be careful, because it could look out of scale.
Another thing to keep in mind to as why you do not see a lot of model sailing ships weathered is that the market doesn't allow it. Most sailing ship models are built for museums, collections, or interior decoration, and that these markets do not want a model that shows the stresses of time, they usually want "showroom" quality. However, that is kind of turning with the popularity of "antique" appeals in the current home interiors fashions. Then again, some go to extremes and I have been seeing "reproduction" models that look like garbage scowels.
Scott
