Space Exploration Vehicle model?
    March, 2018
Posted by workerchimp on Monday, March 26, 2018 12:12 PM
Does anyone know if there might be a kit planned for the new space exploration vehicle? This would be really cool one to add to a moon diorama scene.
    April, 2004
Posted by Jon_a_its on Tuesday, March 27, 2018 6:15 AM
Top Gear (UK) did a road test with Captain Slow, James May with these vehicles.
East Mids Model Club 28th Annual Show 20th MAY 2018
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    October, 2004
Posted by ikar01 on Saturday, July 21, 2018 2:48 PM
Josh Gates got a chance to drive one on his show, Expedition unknown.
    May, 2013
Posted by Greg on Sunday, July 22, 2018 11:19 AM
I wonder why are the wheels/tires so small? Are we planning on exploring a giant salt flat planet somewhere? Huh?
Or maybe one with an existing road infrastructure? Geeked
-Greg
    November, 2005
Posted by CapnMac82 on Sunday, July 22, 2018 5:52 PM
Greg
Well, potential bodies for exploration are all significantly less than 1G.
Moon is 0.15G (1/6); Mars is 1/3 (.037G).
So, you can get acceptably low ground pressures with significantly smaller contact surfaces.
There's a corollary issue that you also need to have enough ground pressure to actually have traction in extraterrestrial locations.  Which is complicated as you want the vehicle to have as little mass as possible, just to decrease the tare weight to have to lift.
Let's say the Earth weight of the thing is 100KG, on Mars it's only 37KG, for 4 wheels that's only 9.25kg each; for 6, it's 6.16KG each.  If the contact patch is 10x10cm would only be ±62grams per square cm.
A "springy" tire is handy as it's less complicated than suspension equipment, which is middling important for human drivers/occupants.  So, tires are better than rollers (torsion bar geometry is complicated in low-G environments, too.)
    February, 2012
Posted by Liegghio on Sunday, July 22, 2018 8:51 PM
Those may be test wheels only for use in 1g gravity and the wheels will be different for lower gravity planets. I think the original lunar rovers didn’t have exactly the same metal mesh wheels for earth testing, as the ones used on the moon.
    November, 2005
Posted by CapnMac82 on Monday, July 23, 2018 7:31 PM
The aboce is an excellent point.
My quick search did not turn up a lot of details on the earth-bound rover trainer.
