What grit sandpaper or sticks should I be using?
    July 2003
Posted by Brogar on Monday, December 3, 2012 9:30 AM
I'm attempting my first airplane in 20+ years and I am having difficulties sanding the fuselage seams smooth.  It's a Testor's 1/72 scale F4U Corsair.  I've been using needle files, a 4 way/grit sanding stick bought at the drug store for nails, sanding film I got at the hobby shop that I've glued to craft sticks to make my own sanding sticks, and just plain sheets of sandpaper.  Grits vary from 180-1000.
The filler putty I've been using has been squadron green, plain zap-a-gap super glue, super glue with baking powder, and Tamiya basic putty.  I've been playing around with the various fillers to see which ones I like best but I just can't seem to figure out what order of grit I should be using.  No matter which filler or sanding sequence I use I can still either see the seam or a ridge of filler.  Very frustrating which is why I shelved this model last year.
Please give me some ideas of grits, sticks, sand paper fillers or whatever you guys use to make those seams disappear.
Thanx
    February 2015
Posted by Bick on Monday, December 3, 2012 5:05 PM
Sandpaper is probably the most used tool in my shop. With plastic models, I usually don't go coarser than 320 grit and seldom finer than 600 grit. It's important to start with coarse, progress to fine by sanding out all the previous grits sanding marks. Once you get to 400 you're usually ready for primer. For clear canopies etc you might need to go to 1000 then polishing sticks. If you're still seeing a ridge, you just haven't sanded enough and if you can see the seam you haven't used enough filler. I often use the 4-grit nail files/polishers from the drug store - I think they work great. In re fillers, I like Tamiya or Bondo but Squadron green or white should work fine; super glue also works but is harder than the plastic when it cures and takes more effort for me. HTH
    September 2003
Posted by checkmateking02 on Monday, December 3, 2012 5:15 PM
If you use superglue as an assembly glue and filler, which I do, try sanding after about an hour of applying it.  By that time, it should be hard enough to sand, but still not like concrete.  I've heard about using baking soda with it, but never tried it, since the viscosity of the gap-filling type seems good enough.
I've been using Zap-a-Gap gap filling CA instead of liquid or tube glues for several years, and used to let it dry overnight.  Now, I've discovered you don't have to wait that long.
The regular thin Zap superglue seems (to me) too thin to do much good, but the gap filling stuff (green label) is just right.
Like Bick, I don't usually go coarser than 320 grit, and for most builds, there's no need to go beyond 600 grit--unless you're polishing up to do a natural metal finish.
Good luck.
    July 2003
Posted by Brogar on Monday, December 3, 2012 8:46 PM
So tonight I tried wet sanding and am pleased with the results.  I used some sanding sticks I got at Hobby Lobby (skinny blue ones with only 2 grits, not sure what grit they are), followed that with my home made 400 grit sanding stick, and finished it off with the finest grit on a 4 grit nail fileing stick.  I've still got a little bit of gouging in some areas and a few slight ridges in others but it should suffice for my first attempt in so long.  It's a learning curve after all.  Thanx for the advice.
Posted by Don Stauffer on Tuesday, December 4, 2012 9:26 AM
I don't use sanding sticks, merely wrap paper around blocks of wood or particle board. I keep several medium and small blocks on the workbench.  I typically use 320 grit for rough sanding if I did a decent job smoothing while applying  the putty.  I also use needle files a lot cleaning up putty.  I seldom use finer than the 320 grit until I am into priming surface.
    January 2006
Posted by dirkpitt77 on Friday, December 14, 2012 3:16 PM
If I read your post right, your problem is not so much the specific grit you're using, as the technique. It sounds to me like maybe you're just not removing enough material to get a nice even surface on both sides of your seams.
  The way I always think of it is: the coarser the sanding material, the more plastic you're removing with every swipe. Plan ahead and assess what grit you'll need for any particular sanding job. A succession of finer grits is just the "first aid" for the "demolition" you did with the coarser grits.
  As for myself, I use 220 for serious plastic removal, then proceed up to 320, then 600.  After 600 I can primer and not see too much difference in the surface.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
Posted by Don Stauffer on Saturday, December 15, 2012 11:11 AM
Another way to remove a lot of plastic in a hurry with bad or offset seams is to use an X-acto blade as a scraper.  Hold the blade and 90 degrees to surface and pull the blade along the seam.  This does dull blades rapidly, so I keep one handle just for scraping. I put a used blade in it that is too dull for regular cutting, but will still scrape okay.  Do coarse removal with this, then go to sanding or filing.
