Canopys and future - how to glue after dipping?
    September 2006
Posted by rookie 104 on Monday, March 18, 2013 6:23 PM
Hi,
I have never dipped my canopys in future but want to start doing so.
I am a bit confused, though, on how to glue them on after dipping.
 Do you scrape the Future off the edge of the canopy that is to be glued? I assume that regular glue will not adhere to the Future dipped part. Is this so?
Also I believe I read somewhere that you can use superglue if you dip the canopy in Future and it will not haze the clear plastic.
Would you just superglue on the canopy without scrapping the Future off the edge?
Thank you
    August 2012
Posted by AndrewW on Monday, March 18, 2013 9:00 PM
Personally, I've always just set them down with white glue or scraped a little and used Testor's model cement.  Haven't heard of supergluing them, but would be interested to know if it's true.
Life is hard, it's even harder when you're stupid - John Wayne.
    December 2011
Posted by Chrisk-k on Monday, March 18, 2013 10:16 PM
I'd be interested to know if superglue doesn't haze the canopy.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    March 2010
Posted by Nathan T on Monday, March 18, 2013 10:47 PM
It doesn't if your careful. If you load on the superglue it can still fog it. I use small dabs of superglue along with Micro crystal clear, just to help a subborn fitting canopy stay in place. I use Zap a gap CA.
    May 2009
Posted by Pawel on Tuesday, March 19, 2013 4:00 AM
Hello!
I also used super glue several times on futured canopies and didn't have problems with fogging. I used the glue sparingly, though. Anyhow, that's what I always recommend for gluing canopies. Good luck and have a nice day
Paweł
www.vietnam.net.pl
Posted by Don Stauffer on Tuesday, March 19, 2013 9:45 AM
CA will adhere to future.  But, of course, the bond between the future and the canopy isn't the strongest.
Also, in spite of what others say, I HAVE had CA craze future coated canopies.
    September 2006
Posted by the Baron on Tuesday, March 19, 2013 11:54 AM
I use white glue to attach canopies.  CA can craze clear parts, Futured or otherwise, but it seems to depend on how closed or open the space is.  Apparently the crazing or clouding comes from fumes given off, as the glue cures.  If there is enough air flow to prevent the build-up, you can apparently avoid it.
But even styrene glue can give some problems, if you drip or smudge it.  That's why I like white glue for clear parts.
    November 2006
Posted by Bearcat57 on Tuesday, March 19, 2013 2:36 PM
Why use CA or styrene cement for canopies? One little slip-up and it's pretty much ruined. I really see no need to use anything other than white glue or canopy/window cement. It's not like canopies bear any sort of load, so the amount of adhesion white glue gives is usually more than sufficient, plus any smears are easily wiped off.
    April 2009
Posted by Cadet Chuck on Tuesday, March 19, 2013 2:43 PM
White glue has worked well for me,too.  You can use Elmer's glue, or a similar product called "Alleen's Tacky Glue". It's thicker and stickier than Elmer's, and it dries perfectly clear.  No need to remove the paint from the surfaces to be glued, either.  You can get tacky glue at Hobby Lobby or most craft stores.
Posted by Don Stauffer on Wednesday, March 20, 2013 9:34 AM
While canopies don't bear too much stress, I have had them come loose during removal of the masking tape.  But this is rarer than windows.  In both masking and removing masking tape from fuselage windows I have often had them come loose, and then rattle around inside the fuselage where they are unretrievable.  So I always use epoxy for fuselage windows (bombers, airliners).
    September 2006
Posted by rookie 104 on Wednesday, March 20, 2013 7:46 PM
Thanks a lot everyone - Your responses have cleared things up really well for me.
rookie 104
    January 2003
Posted by murph on Thursday, April 11, 2013 9:38 AM
White glue is good but I really like this stuff.  It's strong and fills little gaps that may require a bit of touch up.
www.testors.com/.../Clear_Parts_Cement___1_Oz.
Retired and living the dream!
    January 2014
Posted by Silver on Tuesday, April 8, 2014 6:10 PM
After dipping let dry then apply Future on the area the canopy sits then attach the canopy.It will hold.
    November 2008
Posted by plasticjunkie on Tuesday, April 15, 2014 7:45 PM
IMO Testors Clear Parts Cement is the best to glue on clear parts. It's very strong, dries clear and fills in gaps that can be touched up with paint.
 GIFMaker.org_jy_Ayj_O
    August 2009
Posted by JOE RIX on Tuesday, April 15, 2014 9:52 PM
I  use Testors Clear Parts Cement. Excellent stuff. Although I have used Zap-A-Gap CA with no ill effects.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
Posted by Don Stauffer on Wednesday, April 16, 2014 9:20 AM
I also use Testors clear parts cement, but I sure don't find it very strong. I have found NO white-glue-based cement that strong for gluing plastics.  For canopies it is fine- if they break loose it isn't hard to glue them back on.  But for critical joints I don't use white glue or the proprietary brands that are similar.
    March 2014
Posted by Tarasdad on Wednesday, April 16, 2014 8:21 PM
Foam safe CA is non-fuming and odorless. Haven't tried it on clear styrene so can't vouch for how well it will work. I have the Testor's Clear Parts Cement, Pacer Formula 560 and Aleen's Tacky Glue on hand. I'm sure one or the other will suffice.
Tarasdad
On the Bench:
  • Revell 1/48 F-15 Strike Eagle
  • Revell 1/48 A-10 Warthog
  • Revell 1/426 USS Arizona
    February 2007
Posted by mitsdude on Tuesday, April 22, 2014 1:56 AM
I've become a big fan of Formula 560 Canopy Glue.
In the past I have used Hypo GS watch crystal cement with great success. I stopped using it because the lid has this itty bitty pin that you have to stick back in the hole where the glue comes out. I had a heck of a time getting the lid on. The glue will keep oozing out until the lid is on. Meanwhile I'm having to attach/adjust  the clear part to the model. I was having to choose between wasting the glue or having an incorrectly glued clear part.
    June 2009
Posted by jimbot58 on Tuesday, April 22, 2014 3:39 AM
I like using Micro Krystal-Klear. Seems to be a bit more tacky than the Testors product and it is easier to clean up the excess with a damp Q-tip. I stay away from the CA, Future dipped or not!
On my workbench now:
Fujimi F-4K Phantom "Yellow Bird" and Zvezda Su-27SM Flanker
dmk
    September 2008
Posted by dmk on Wednesday, July 9, 2014 3:08 PM
rookie 104
 It's usually pretty easy to take a sanding stick and just sand off the Future along the edges. With smaller parts I just leave it alone and hope for the best, but with something larger like a canopy it is easy.   I like a secure bond and less worry of parts falling off and getting lost or broken.
On parts with frames that will be painted, I often (very carefully) use plastic solvent  (Weld-on, Tenex, etc)  to attach it, taking advantage of capillary action.
    May 2013
Posted by Greg on Wednesday, July 9, 2014 5:53 PM
Last yr I had a problem with a finicky gunner's canopy staying together, so I experimented with several white glues. Tried every product mentioned in this thread. Even my trusty formula 560 (mentioned by mitsdude) failed. Finally broke down and ordered a couple things of Gator's Grip glue. Did the trick and I've been quite a fan of it since.
Having said that, my level of experience is low compared to all the other posters in this thread.
Far as I know it's only avail from the gent who makes it. Here's a link
http://www.gatorsmask.com/gatorglueorder1.html  (Sorry, still haven't figured out how to post a hotlink here)
    January 2014
Posted by Silver on Tuesday, September 9, 2014 1:25 PM
Let dry then use a future to glue in .Just brush on then set in.After ten min brush a little Future around the joining edges.
Posted by Texgunner on Wednesday, September 10, 2014 8:00 AM
Greg, maybe I can help you with those hotlinks.   You need to just paste your link into your post.  Here's yours:
Okay, now, highlight it with your cursor.  Just drag across and it will turn blue.  Then, in the little control panel above your text, you'll notice that the link of chain icon is now more visible.  Now, click on that chain icon and another little window opens.  Click "insert" and the link should appear as an active (hot) link.  Give that a try and see if it helps.
best regards, Gary
And speaking of "hotlinks", how do these look?
"All you mugs need to get busy building, and post pics!"
    May 2013
Posted by hogfanfs on Wednesday, September 10, 2014 11:06 AM
Texgunner
Forget the links, I want the ribs!!!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    May 2013
Posted by Greg on Wednesday, September 10, 2014 11:53 AM
Gary, that certainly does the trick. Thanks, Mate!
Good play on words re the hotlinks. Smile Good looking BBQ!
Posted by Texgunner on Wednesday, September 10, 2014 12:14 PM
Greg
You're quite welcome Greg!  I'm glad I could be of assistance.
And btw, that BBQ tastes even better than it looks (he modestly proclaimed!).
    March 2005
Posted by TarnShip on Wednesday, September 10, 2014 1:49 PM
I am going to try a combination of the methods, with a twist.
I am going to try out the Foam Safe CA I just linked to in that thread. 4 little dots of the CA on the canopy joint. Hold the Kicker microbrush near it to cure it. Then fill with Aleene's or Future on the rest of the canopy seam line.
Between being foam safe (less fumes), kicked (less time for fogging), and small quantity being used (less fumes again), I think we can get smooth and strong canopy joints this way.
Rex
almost gone
    February 2007
Posted by mitsdude on Saturday, October 18, 2014 2:11 AM
I read a hint a few days ago about using Future itself as a canopy glue. Pour some Future in a container and exposed to air to let some of the water evaporate until it has a syrup/molasses like consistency. Then seal the container and use when needed.
Don't know how well this works but its something to try that wouldn't cost anything!
