Highlighting over flat black paint
    September 2013
Posted by Vince on Tuesday, December 3, 2013 10:27 PM
I'm working on a V-22 Osprey and it calls for flat black in the wheel wells. I like to highlight the wheel wells to show depth but I'm not sure what color to use over the flat black? I experimented with gray but it didn't give the effect I was looking for. Thoughts?
Thanks,
    March 2010
Posted by Nathan T on Tuesday, December 3, 2013 10:42 PM
Add some red-brown to your black and it will give a nice faded black look without it being too stark. Dry brushing with a dark gray or neutral gray should look good too. Deck Tan or Buff added to the black would work too.
    November 2008
Posted by plasticjunkie on Wednesday, December 4, 2013 8:25 AM
If you have molded details you want to pop, mix some grey oil washes to add some depth. When dry, then  dry brush as Nathan mentioned. I found that a light wash of yellow ochre oil paint will fade a bit and separate the molded detail against the black.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Wednesday, December 4, 2013 9:25 AM
I seldom use flat black for actual surfaces. I only use it for places that are an orifice where nothing should be visible.  For all else, I soften the black. I find panzergray is a good very dark gray to either use as a weathered black or to mix with black to soften it.
    January 2014
Posted by Silver on Thursday, June 26, 2014 9:57 AM
White or lt gray sludge wash then wipe away w/ cotton swab.
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, July 5, 2014 10:53 AM
I second that on Panzer grey. Actually it's called Panzer Schwarzgrau RAL 7021.
cml
    March 2007
Posted by cml on Sunday, July 6, 2014 4:44 AM
I second Don and 214.
However, if you're not happy with highlighting with grey, perhaps a dark blue might create a highlight without contrasting too much with the black.
Chris
Posted by Don Stauffer on Sunday, July 6, 2014 8:15 AM
One possibility for wheel wells is a very feint, light wash in just a few areas of red, to simulate hydraulic fluid. I sometimes do a very light wash of this on the gear too.  It has to be absolutely minimal, however.
