BTW make sure the seam is actually cemented together. I've puttied and sanded seams a dozen times and they would not go away. Found out later that the seam wasn't glued and when I'd put pressure on it with the sanding stick it would 'pop' and I'd end up with a crack again. Worst situation was on a 1/72nd B-29 - the long seams on the top and bottom of the fuselage kept popping loose over and over- took me a while to figure out this was what was happening.
