Question about hairspray technique
    June 2014
Posted by R_Bolton on Thursday, June 26, 2014 5:52 PM
Can this technique be used over decals. Thanks in advance, Rick
Posted by icit on Thursday, June 26, 2014 10:09 PM
Yes, but be very careful with the amount of pressure you are using when scrapping or rubbing with whatever tool you are using. I have taken the extra care to ensure that the decals are sealed, and completely dried, as would be part of the normal decaling process before applying the hairspray. I use a hair dryer on the individual applications and I have had good results with it. I would also suggest trying it off model on scrape plastic or an old kit if you're not comfortable with it. Good luck.
ICIT
    June 2014
Posted by R_Bolton on Friday, June 27, 2014 3:05 PM
Thank you very much
