Resin air bubbles
    October 2003
Resin air bubbles
Posted by masonme2 on Thursday, July 31, 2014 12:31 PM
How do I repair small air bubbles in resin parts? I have some slicks and several other parts that I want to use on my current build and was wondering how to fill/repair the small air bubbles that are present.
"Diplomacy is the art of saying 'Nice doggie' until you can find a rock"   Will Rogers
    August 2013
Posted by Jay Jay on Thursday, July 31, 2014 1:58 PM
I inject CA into the hole ( thin or thick depending on the size bubble )  then pack baking soda into the wet glue.
repeat the process until the bubble is a little over filled, then sand smooth.   You don't hafta wait long to sand if you then use accelerator ( recommended )
    May 2009
Posted by Pawel on Thursday, July 31, 2014 2:24 PM
Hello!
Or drill it out a little and put a small length of stretched sprue in the hole, glue with super glue. Sanding it flush takes care of it all. Hope it helps, good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
Posted by Don Stauffer on Friday, August 1, 2014 9:25 AM
I use the same putty I use to fill seams.
    January 2010
Posted by CrashTestDummy on Monday, September 8, 2014 12:07 PM
And Chuk on this forum recommends White-Out.  I haven't tried it yet, but he uses it to fill pinholes and seams.  The advantage of the stuff is that it dries very fast, and is easily-sanded down.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
