Perfect Plastic Putty or Vallejo Plastic Putty?
    May 2014
Posted by SubarooMike on Friday, November 14, 2014 8:20 PM
Hello everyoneBig Smile     I am looking for a nice water clean up putty and I am torn between two:  Perfect Plastic Putty or Vellejo Plastic Putty.   I can only afford to buy one.  Which one would you recommend and why (if you have specific reasons).     Thank you for your help gents!
    April 2004
Posted by Jon_a_its on Saturday, November 15, 2014 2:09 AM
Perfect Plastic, waay more useable, & lots of how to's on their website:
Can be used 'dry', or shaped wet, dries hard, carves,  drills, sands, takes paint, etc., whereas the VJ... doesn't
I don't get on with VJ putty, doesn't go where I want, shrinks, & doesn't sand well..
About UKP£4.00-£5.00 for 40ml vs. UKP£3.00-ish for 11ml? so cheaper as well,
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    May 2014
Posted by SubarooMike on Sunday, November 16, 2014 10:10 AM
Jon_a_its
Rodger that. My fiance went ahead and ordered me some. Thanks a lot!
    November 2014
Posted by Nuckss on Tuesday, November 18, 2014 6:28 PM
I went to their webpage and can't even find perfect plastic putty listed. What's up with that?
    September 2013
Posted by Marcus McBean on Wednesday, November 19, 2014 5:52 PM
I purchase it through Amazon.
    May 2014
Posted by SubarooMike on Wednesday, November 19, 2014 6:02 PM
Ebay has it as well
    December 2011
Posted by Chrisk-k on Thursday, November 20, 2014 5:18 PM
I don't see how other putties can possibly be easier to use and more effective than Perfect Plastic Putty.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    May 2014
Posted by SubarooMike on Thursday, November 20, 2014 6:13 PM
Chrisk-k
Mine comes tomorrow! I have a few builds waiting on it so i'm pretty excited.  Do you have any tips on using it? Or is it that easy
    April 2004
Posted by Jon_a_its on Friday, November 21, 2014 4:06 AM
Don't feed the CM!
    January 2014
Posted by jelliott523 on Tuesday, November 25, 2014 2:12 PM
I haven't tried the PPP yet; however, I do use the Vallejo Plastic putty fairly often.  The thing I like about the Vallejo is that you can cut the tip so that it only applies a small, super thin line of putty.  Then, using a damp finger or q-tip you can wipe away the excess.  When I use this putty it is mainly for small seam gaps or wing fillets.  Just my .02 worth.
    August 2014
Posted by Adam148 on Saturday, December 20, 2014 9:52 AM
I have been extremely happy with Perfect Plastic Putty.  It is super-easy to work with. Highly recommended.
    November 2008
Posted by plasticjunkie on Sunday, December 28, 2014 2:48 PM
I heard about Perfect Plastic Putty on another thread and was lucky to find some at my hobby store. I really like the product as it easily cleans with water. As an example, I'm working on a plane that has a small gap at the wing/fuselage joint. I carefully spread some of the putty on and used a wet Q Tip to wipe the excess leaving a smooth even patch.
 GIFMaker.org_jy_Ayj_O
    February 2007
Posted by mitsdude on Monday, December 29, 2014 12:28 AM
One negative I've experienced with PPP is that it dries very fast. Several times I've be left with a useless blob of putty because it dried by the time I used all of it.
    March 2010
Posted by Nathan T on Monday, December 29, 2014 8:21 AM
Mits- You mean it set up in the tube even with the cap on? Or dried as soon as you spread it on the model?
    February 2007
Posted by mitsdude on Tuesday, December 30, 2014 12:31 AM
I place a  blob of putty on my workbench and use that as a "reservoir" for my putty work instead of leaving the cap off the tube. The size of the blob depends on how much I think I will need. At most it will be about the size of a pinto bean.
As I work from that reservoir if I take too long on a seam or something it will begin to dry out before I can use all of it.
Time wise I'm talking 1 to 4 minutes.
About like the 3M acryl blue glazing putty.
    March 2010
Posted by Nathan T on Tuesday, December 30, 2014 11:43 AM
Ok, thanks. Sounds like most other putties I'm used to.
