Submarine streaks
    August 2012
Submarine streaks
Posted by JMorgan on Sunday, January 11, 2015 5:06 AM
What is the best way to apply white saltwater streaks on submarine models?
    August 2013
Posted by Jay Jay on Sunday, January 11, 2015 10:00 AM
I am looking forward to this discussion myself.  I am doing a PBY and I think that a mud wash is kinda out on this one.
    June 2013
Posted by RobGroot4 on Sunday, January 11, 2015 6:41 PM
I'm just spitballing this one, but I had pretty good results using a wash of Tamiya light sand mixed with water on an AH-64 recently.  I imagine you could do something similar and brush it on and then use a brush dipped in rubbing alcohol to streak it as desired.  I would recommend testing on some kind of scrap plastic first.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    November 2003
Posted by Mike F6F on Monday, January 12, 2015 11:35 AM
I'd recommend using a light gray mixed with a small amount of your base color and dry brushing along the hull.  I had good success with this method for a 1/700th scale WW II carrier in the navy blue, measure 21 scheme.
You didn't mention what type of boat you are building, but this method should work on dark or lighter paint.
Jay Jay, I believe the same technique will work on your PBY.
"Grumman on a Navy Airplane is like Sterling on Silver."
Posted by Don Stauffer on Tuesday, January 13, 2015 9:06 AM
If you want translucent streaks, the two best ways to do them are either drybrushing or airbrush with paint flow turned way back.
    August 2012
Posted by JMorgan on Tuesday, January 13, 2015 1:36 PM
You do mean airbrushing with minimal paint flow?
    August 2005
Posted by EdGrune on Wednesday, January 14, 2015 6:24 AM
AK Interactive's Salt Streaking product (AK306) looks to be a promising product.  See the product description sheet at AK
http://www.ak-interactive.com/app/pdf/AK%20306%20SALT%20STREAKS%20FOR%20SHIPS.pdf
I have a sale offer from the AK Interactive APP on my phone.  I'm planning on odering several of these weathering products
    August 2012
Posted by JMorgan on Wednesday, January 14, 2015 8:22 AM
It looks like the AK product is just another enamel. Shouldn't oils do the same thing?
Posted by Don Stauffer on Wednesday, January 14, 2015 9:20 AM
JMorgan
Yes.  If you use a fine tip, and dial the paint flow back you can make nice translucent streaks.  A broad tip and low paint flow can create a large area chalking or weathering.
    August 2008
Posted by tankerbuilder on Friday, January 23, 2015 8:30 AM
J ;
You've received some fair advice .
  I use a wash of one part color , Ten parts water  or thinner . It's hard to see , but over time it will become more visible . Don't forget to have your wash run from the deck center-line , down the sides . Never from bow to stern on these puppies .
