Photo-etch and vinegar
    September 2006
Posted by shall on Thursday, April 2, 2015 12:21 PM
I've read several places that to help paint stick to photo-etch to soak it in white distilled vinegar for X amount of time. I've heard soaking times anywhere from two minutes to overnight. A plurality of people say ten minutes. This will be for ship railings (mostly) from Gold Medal Models, does ten minutes sound about right?
Thanks,
Steve
shall
    August 2013
Posted by Jay Jay on Friday, April 3, 2015 10:01 AM
This thread had the makings of a good dicussion.
Vineger ? really ?   never heard that before.  I just swish my PE around in water with a little dish soap for a few minutes and rinse and let dry. takes about 15 minutes but maybe there's a better way.   What do you think guys ?
Posted by Bish on Friday, April 3, 2015 12:20 PM
Never soaked mine in anything and never had an issue. Certainly not heard of using vinegar before.
    September 2013
Posted by Marcus McBean on Friday, April 3, 2015 12:30 PM
I saw a demonstration on You-Tube that it roughs up the PE so primer and paint sticks better.  I tried it twice and it does seem to help to reduce the paint from flaking off when you handle the PE to much.  The video doesn't say how long to soak the PE so I do it for an hour and then rinse.  I wash the PE before soaking it in cider vinegar.
Posted by Don Stauffer on Sunday, April 5, 2015 11:50 AM
Yep, an old trick.  Another I like is use of dilute lye.  Put a small amound (small fraction of teaspoon of Drano in about a half pint of water.  Works great on aluminum. It will leave a gray/black coating, clean that off before priming.
Be very careful making and using this- Drano is dangerously caustic and you want a very dilute solution. It will make bubbles while working.  As long as it is bubbling you have a workable solution.
    December 2011
Posted by Chrisk-k on Sunday, April 5, 2015 8:00 PM
I use AK & Tamiya primers. I've never had trouble painting metal or PE parts.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Don Stauffer on Monday, April 6, 2015 8:48 AM
I find stainless harder to adhere paint to than brass, but even brass needs a good primer.  For small pieces of PE that do not get bent, I generally do not have a problem, but if the piece needs to be bent and you bend it after painting, that can create problems.
