Etching P.E for paint .
    August 2008
Posted by tankerbuilder on Monday, April 6, 2015 12:55 PM
      I saw the article about P.E. and Vinegar .As you know vinegar is caustic in and of itself .This is why it can work .Make sure the P.E to be soaked is spotlessly clean first .
 I use another route here . I create a mixture of Comet cleanser and warm water .I drop in the clean P.E and swirl it in the mix gently .When I did the rails on the Wisconsin model for Nauticus and BaD shipmodels that's how I did them .
 Promise not to laugh ? Another proven method is to lay your P.E in a shallow soap dish . Cover with warm water and use a Polident cleaning tablet .That works great as well . Make sure the tablet DOES NOT ! sit on the brass or steel .                           Tanker - Builder
    September 2013
Posted by Marcus McBean on Monday, April 6, 2015 2:01 PM
Thanks for the tips, I will have to try the Polident method on my next build.  What is the mix ratio on the Comet and warm water method?
    August 2008
Posted by tankerbuilder on Wednesday, April 8, 2015 1:53 PM
The Mix on the Comet versus water is 25 % comet and 75% water .More or less . Make sure the Polident is the Smokers formula . There's one more . Promise not to laugh ? Take that empty pickle jar full of pickle juice and soak the washed brass in there .The Vinegar and pickling spices do a nice job and that way you get to use every last drop of the jar contents .
    December 2011
Posted by Chrisk-k on Thursday, April 23, 2015 2:17 PM
Spray Future on PE parts and then paint them.  That's the easiest way to make paints completely adhere to them.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Don Stauffer on Friday, April 24, 2015 9:18 AM
I wash the PE fret in two different materials- first a detergent/water mix, and then in a solvent, either lacquer thinner or MEK.  Then I use a good primer made for metal priming, either Krylon or Duplicolor.
    August 2008
Posted by tankerbuilder on Sunday, May 24, 2015 12:59 PM
Don :
I don't know about Minnesota , But if you lived in certain parts of good old California you had to have a permit to use stuff like M.E.K ( Methyl Ethyl Ketone )and it  is a very dangerous chemical if you don't use a good filter mask !
Posted by Don Stauffer on Monday, May 25, 2015 8:52 AM
Yes, MEK is very hard to get here, even though it is legal to use it.  I kept looking for it at my local building supply company and scored with a quart can.  However, lacquer thinner is readily available here and works almost as well.
Posted by Tojo72 on Monday, May 25, 2015 12:48 PM
Priming with Tamiya or Mr surfacer has worked for me
    August 2008
Posted by tankerbuilder on Friday, May 29, 2015 9:02 AM
Hi DON !
    Maybe I caught Heck from the Warden of Game here because it was in a Marina scenario . T.B.
