Raised detail question re Rivets
    December 2005
Posted by Stuart06 on Monday, April 6, 2015 1:45 PM
I am working on Revel's Merlin 101 and had to sand some joints so that you cannot see some gaps. Although I can re-scribe any panel lines, the problem is the raised rivet details. In 1:72 scale they are extremely small. All the rivets are raised so I don't thing a rivet roller will help (or would/could it?) What would be he best technique to get these rivets back. I was thinking of using dots of super glue, but worry about lining them straight and even? (is that the best method?)
Most of my friends are imaginary
Sell your watch, because time is money $$
In Canada hwy speed is measured by number of moose tracks per hockey goal.
    May 2011
Posted by Real G on Monday, April 6, 2015 2:20 PM
Other than simulating rivets with a pounce wheel, you could try these:
http://www.archertransfers.com/
They are tiny resin dots printed on clear decal film.  I have not tried them, but have a project that requires extensive raised rivets so I'll be getting some.  Download their catalog and print it out "actual size", as they have 1:1 patterns shown.  Look at the N-Gauge (1/160) stuff, as they are probably your best bet to get something that matches.
Good luck!
“Ya ya ya, unicorn papoi!”
    August 2008
Posted by tankerbuilder on Tuesday, April 7, 2015 8:14 AM
AHA !
   You got a very good answer . I have those ,supplied by a client .Totally awesome .There are sizes that will definitely help you .
Posted by Don Stauffer on Tuesday, April 7, 2015 9:05 AM
If you have sheets of dry transfer lettering, and do not use many periods, the small font periods make nice rivets- basically the same as above stuff.  Another way to make small rivets is with white glue.  Pour a little on some scrap, dip end of toothpick in it, then on model surface.  Don't make them too big- many kits with non-flush rivets- even good expensive kits- have very oversize rivets.
    August 2008
Posted by tankerbuilder on Sunday, May 24, 2015 1:09 PM
Hello Don !
  Did you know that the best white glue to use for rivets is Aleens Tacky Glue . Because it is so thick you can make thousands of scale rivets for a Titanic model . Look great too !
