Eye Shadow?
    June 2015
Eye Shadow?
Posted by chatles on Friday, August 21, 2015 3:12 PM
My daughtrer has tons of makeup such as eye shadow and some of the colors would work really well for weathering and such.  Can this type of thing be used or would I risk damaging a model?
Thanks, Craig
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, August 25, 2015 11:38 AM
Unusual but in my opinion, no.
Posted by Texgunner on Tuesday, August 25, 2015 2:59 PM
chatles
Thanks, Craig
I can't imagine that hurting a model in any way.  In fact, I've read numerous suggestions for using it to weather models.  I'd say give it a try, and report back your findings!
Gary
"All you mugs need to get busy building, and post pics!"
    April 2015
Posted by Scarecrow Joe on Tuesday, August 25, 2015 3:17 PM
I used some in my MPC Falcon, specially some brown and rusty colors.
 IMG_4933 by Oscar Baez Soria, on Flickr
 IMG_5245 by Oscar Baez Soria, on Flickr
    September 2006
Posted by the Baron on Wednesday, August 26, 2015 11:34 AM
Why not?  Isn't it essentially the same thing you get when you buy prepared weathering powders?  That is, it's a pigment, ground very fine, with binders to keep it in place when applied.
You will also find many references to using make-up brushes for weathering.  Many of them are wide and let you apply pigments over a broad area (of course, in their intended use, they're used to apply pigments over a broad area, heh heh!) (Sorry, couldn't resist the pun)
    June 2015
Posted by chatles on Thursday, August 27, 2015 1:33 PM
Thanks everyone for the advice.  I think I'll give it a try.  I just wasn't sure if there were oils and such in the makeup that could damage the models finish.  I suppose I should avoid the ones with glitter Wink
Craig
    April 2009
Posted by Cadet Chuck on Friday, August 28, 2015 11:06 AM
I've used it on both resin and plastic models, on top of the final paint coat, and  you can spray clear sealer over it, and it won't run.  Works fine!
    December 2011
Posted by Chrisk-k on Friday, August 28, 2015 8:35 PM
Eye shadows are pigments.  I have MIG and AK pigments, so I don't use eye shadows.
However, what's really useful for me is Eye Shadow Sponges.  They are perfect for applying pigments and creating subtle effects.  I bought 100 ESS on eBay for $6.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
