alternatives for glueing canopy
    August 2013
Posted by Putsie on Tuesday, December 6, 2016 8:46 PM
Hi guys !
Currently working on a 1/72 scale P6M vacuform kit.
The canopy fits well if gently pressed in place but doesn't fit snug if not held.  Could I coat the inside with "Future" to prevent fogging with supe-glue?  Or would regular model cement work well if I used tape to hold it in place while drying?  I used the watch crystal cement from Micro-Mark, but it didn't hold when I "wet-sanded" the filler along the seam.
THX
    April 2013
Posted by KnightTemplar5150 on Tuesday, December 6, 2016 10:27 PM
Some of the conversations here in the forums prompted me to try the glue which sets with a UV light to secure clear parts in place. It's worked out well - pretty cool stuff to experiment with. Easy to use, clean as a whistle, and absolutely crystal clear when cured with the light.
Posted by Don Stauffer on Wednesday, December 7, 2016 9:33 AM
CA can still fog canopies that have been Futured, but if you have access to the interior you can remove the future and the fog will come off with it.
Personally, I have begun using the new UV (laser) hardening cements.  I find it holds better than the white glue type transparency glues, and is more reliable than epoxy.
    August 2013
Posted by Putsie on Wednesday, December 7, 2016 1:56 PM
Thanks, I didn't think of that.
    August 2013
Thanks Don......
cml
    March 2007
Posted by cml on Tuesday, December 13, 2016 6:49 PM
Interesting.
I've seen those cements, but wasn't sure if they were a bit of a fad or had some real potential.
Sounds like they may well be worth investigating.
Chris
