How to make asphalt pavement.
    March, 2015
Posted by JohnnyK on Wednesday, February 15, 2017 4:52 PM
I place my models on what looks like asphalt pavement before I photograph them.
I purchased a foam core board with black foam and paper. I removed the paper and then applied some paint to the foam. Click on this link to see how it is done.
http://model-railroad-hobbyist.com/node/17438
    July, 2014
Posted by modelcrazy on Wednesday, February 15, 2017 4:54 PM
Oh I like that, better than the cardboard I use. What scale is that? (sorry I didn't look at the link if it was in there)
ON THE BENCH
1/72 Hasegawa FW-190D9
1/35 Trumpeter PT-76B
In Que
1/700 Tamiya Scharnhorst
Completing a kit is like cutting the head off a Hydra. Two more replace it in the stash.
    March, 2015
Posted by JohnnyK on Wednesday, February 15, 2017 5:08 PM
The board in 20"x30". The plane is 1/48 scale. The most difficult part of making the board is removing the face paper.
    July, 2004
Posted by stikpusher on Wednesday, February 15, 2017 5:11 PM
Looks good. I might suggest a gray concrete color for aircraft ramps though. Concrete for airfields is more common than asphalt.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March, 2015
Posted by JohnnyK on Wednesday, February 15, 2017 5:17 PM
stikpusher
I think that is a great idea. Initially I made the asphalt boards for photographing my model cars. You are correct, aircraft ramps are concrete. I think I'll make a concrete board.
    March, 2015
Posted by JohnnyK on Wednesday, February 15, 2017 5:24 PM
One more thing. I glued the foam board to plywood. The foam board warped after is was painted.
    December, 2002
Posted by Bish on Thursday, February 16, 2017 2:24 AM
I have a reall useful link for painting concrete ramps. I will post it when i get to my comp tonight.
''I am a Norfolk man, and i glory in being so''
On the bench: Tamiya 1/72nd Bf 109E-3
    July, 2014
Posted by modelcrazy on Thursday, February 16, 2017 11:24 AM
Bish
That would be great Bish. I really need to work on my concrete.
ON THE BENCH
In Que
    December, 2002
Posted by Bish on Thursday, February 16, 2017 1:36 PM
Here is the link. I have only tried this once so far, on a Do 24 base. Most of mine aircrfat are on grass fields. I only used the painting part, which starts about a third of the way down. First time out i got a result that i was really pleased with and far better than my previous ones.
http://bowemodels.blogspot.co.uk/2013/05/technique-building-basic-wwii-era.html
    July, 2014
Posted by modelcrazy on Thursday, February 16, 2017 1:59 PM
Thank you Bish. between your link and the OP's process I can't lose! Your Do 24 base was superb Yes.
Now I can't wait to give it a try...wait, that means I won't be using water Crying
ON THE BENCH
In Que
    December, 2002
Posted by Bish on Thursday, February 16, 2017 3:16 PM
modelcrazy
Your welcome. But who says you can't.
Just sayin Wink
    July, 2014
Posted by modelcrazy on Thursday, February 16, 2017 3:21 PM
well there you have it. Problem solved.
ON THE BENCH
In Que
    November, 2009
Posted by Don Stauffer on Friday, February 17, 2017 9:13 AM
Some small civil airports do have asphalt ramps, so an asphalt ramp is not completely out of the question.
    January, 2013
Posted by BlackSheepTwoOneFour on Friday, February 17, 2017 9:29 AM
Don Stauffer
While that may be true but not on Military bases.
SUBSCRIBER-ONLY CONTENT
