Brushed Zip Kicker Back Into Bottle
    January 2015
Posted by Radial9 on Thursday, February 23, 2017 9:25 AM
In the ongoing effort to "clean up my act" when it comes to gluing, I was watching a video that used superglue for a seam filler. Rather than spray the zip kicker on the small part, making a spray mess, he poured a small amount out of the bottle and used a small brush to apply the zip kicker.
If place in a clean plastic cup and NOT putting the brush into the zip kicker cup after getting super glue near or on the brush, would it be safe to pour the remainder back into the spary bottle? Might be used for a few hour session to place various pieces together than poured back into spray bottle.
The stuff isn't cheap, would like to reuse the unused portion at the end of a session.
Thoughts??
Thanks,
Bob
    February 2017
Posted by japan617 on Thursday, February 23, 2017 11:20 AM
I have a bottle of CA kicker with the spray nozzle/tube that extends to the bottom of bottle. I've unscrewed the top and used the tube to dab it onto the CA and put it right back. No ill effects yet.
    July 2014
Posted by Bakster on Thursday, February 23, 2017 4:47 PM
japan617
I do the same. No problems.
Posted by Don Stauffer on Friday, February 24, 2017 9:10 AM
I use a tiny fork to apply the accelerator.  I made it by grinding in half the eye of a large sewing needle, and jamming the point into a length of dowel.  The advantage of this is that whatever you use will accumulate some harded CA.  Brushes are hard to clean that hardened CA out, while sewing needles are usually stainless steel and I can easily clean the crud off.
I sometimes hold the fork in front of the spray nozzle and give the spray head a quick blast- does waste some, but enough stays in fork.  For an area where I will be using the accelerator a lot, I do put a bit in a very small plastic dish (about an inch in diameter), just barely wet bottom.  Yeah, that does waste a bit, but I find CA accelerator is not a big expense compared to other accessories and supplies.
    June 2014
Posted by Tanker - Builder on Wednesday, March 29, 2017 11:53 AM
Hi BOB;
 I do this . I buy the glass Airbrush mixing bottles from Hobby-Town . I have filled one of those with Zip-Kicker .I used a hypodermic needle ,( Fine ) to apply it and when I get low I pour in more from the larger refill bottle . T.B.
    March 2010
Posted by ACESES5 on Wednesday, March 29, 2017 1:25 PM
I use a plastic tooth pick to apply a tiny drop of kicker on a small parts.              ACESES52 cents
    June 2014
Posted by Tanker - Builder on Sunday, June 4, 2017 8:46 AM
Oh!
 Another good applicator . I found that the small Bamboo skewers are perfect as well .You have the blunt end for large application and the small tip for tiny work . Now here's the trick ! Before you use this item seal both ends with super Glue and wipe off the excess . Do this twice and do not use Zip - Kicker on it when you do it . An inch on either end works fine .
     I have been using the same skewer for over three years now . If you're careful , you won't get glue on it .  T.B.
