Painting Hoses
    June, 2016
Painting Hoses
Posted by David from PA on Monday, July 30, 2018 4:03 PM
Can anyone give me pointers in painting soft plastic hoses to make them look real? I guess they are made out of some sort of vynal. I dont want to paint them and then have the paint crack off when I put them on the model. Thanks
David From PA
    January, 2013
Posted by BlackSheepTwoOneFour on Monday, July 30, 2018 5:41 PM
Try sanding the vinyl hoses to cut down the shine instead of painting. You’ll get that worn look in no time.
    November, 2009
Posted by Don Stauffer on Tuesday, July 31, 2018 7:23 AM
I have sometimes used black magic markers with success on vinyl hoses.  Also, a quick shot of Testors Dullcoat seems to work if hose is the right color.
    July, 2012
Posted by littletimmy on Tuesday, July 31, 2018 6:51 PM
Don Stauffer
That's the way I do it.
Also: you can use a water based color. As long as the paint is "semi-flexable" after it drys.
Laquer based paint will "EAT" the vinyl part's. And Enamel based paint's will "NEVER" dry.
( I once painted the letter's on some tire's using Testors White Enamel.... two years later, the letters were still sticky !)
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage".
    June, 2014
Posted by Tanker - Builder on Friday, August 03, 2018 7:38 AM
Hi;
 Usually when a model has soft plastic hoses , I replace them with either wire the right O.D. or with wire that has the right insulation color and size . I have painted these with no problem . T.B.
