Precise super glue application?
    August 2019
Posted by dreadpyrat on Monday, June 29, 2020 12:18 AM
Hi all, any tips on applying thin or thick super glue precisely? I feel like I've seen people use aftermarket bottles with metal tube tips to apply glue in thin beads.
I need to put down a bit of glue and using a toothpick isnt fast enough for what I need. I dont like using disposable stuff like those plastic tips you can buy in bulk; its just wasteful. Any recommendations for bottles that that fit the bill and that you can store the glue in when not in use?
 Thanks!
Tags: glue
    July 2013
Posted by steve5 on Monday, June 29, 2020 3:25 AM
quite a few guy's here , jam a needle point first into a handle of some type and cut the eye in half , the two points hold just enough glue for the job .
I've got this one too , it's very good .
http://www.creativedynamicllc.com/the-glue-looper.html
Posted by gregbale on Monday, June 29, 2020 8:21 AM
steve5
I do a variation on this, a 2" section of stiff wire superglued into a toothpick half. It lets me do a much tinier drop when needed, than the needle's half-loop.
When residue builds up I burn it off with a lighter and it's good as new. [Use only in well-ventilated areas, obviously.]
Greg
 George Lewis:
    April 2020
Posted by Eaglecash867 on Monday, June 29, 2020 8:43 AM
If you need an applicator that is thin, flexible, and has a long reach, I've had success with using a piece of uncooked spaghetti.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Don Stauffer on Monday, June 29, 2020 12:54 PM
I ise the toothpick for gel CA, the cut needle for the thin stuff.  Why do you need to do it quickly?
    August 2019
Posted by dreadpyrat on Monday, June 29, 2020 5:26 PM
You know, that Glue Looper looks perfect for me. I'll pick some up. Thanks so much all! Apprecaite the feedback.
