Aircraft Instrument “Glass”
    April 2021
Posted by RichE on Wednesday, April 7, 2021 8:45 AM
I was reading in recent issue about using Elmer's glue to create instrument glass. While shopping I found Elmer's CLEAR. A small dot off a toothpick settles and spreads into a crystal clear circle and several days later it is still flexible.
    September 2006
Posted by the Baron on Wednesday, April 7, 2021 3:15 PM
Nice!  I use Future for the instrument glass, but that Elmer's Clear product sounds good, too.  It reminds me of MicroScale's Krystal Klear.  I wonder if you could use that Elmer's product to make small windows, such as on a 1/72 scale aircraft, or the smaller windows on a 1/48 B-17, or something similar.
    January 2020
Posted by wpwar11 on Wednesday, April 7, 2021 3:18 PM
I didn't know Elmers had a clear glue.  For this same technique I use Vallejo gloss varnish.  Bought it thinking I was going to use Vallejo paints but never did.  I'm going to have to try the Elmers.
Posted by Don Stauffer on Thursday, April 8, 2021 9:40 AM
I use a drop of Testors glosscoat.  I have a bottle of the stuff- comes in handy at times.  If the kit has an instrument decal, I often drill out the instrument holes in the plastic panel and just glue the instrument decal behind the panel, then put the drop of clear in the hole with a toothpick. It does not smear out because the panel hole restrains it.
Big advantage of glosscoat to me is the quick dry.
Posted by Bish on Thursday, April 8, 2021 10:49 AM
I use Evostick wood glue for the same thing. And yes you can use it to make small windows. I have also used it for landing lights. Not completly clear but good enough.
    July 2012
Posted by littletimmy on Thursday, April 8, 2021 8:51 PM
I also use Glosscote. Just a dab on the tip of a toothpick.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
dlh
    March 2017
Posted by dlh on Friday, April 9, 2021 7:51 AM
RichE
On larger gauges, I use Bondic (hardened by UV led).  The key is to get just the right amount to achieve a level, or domed surface.  These are large gauges on the Mifistofele model.
https://media.fotki.com/2v2JMb1KhxBoFJC.jpg
Posted by Don Stauffer on Friday, April 9, 2021 8:05 AM
dlh
RichE
Is that one of the brands that come with the resin in a sqeeze tube with laser on end of tube?  I have not seen it.  Where do you find it? Beatiful dash for the Meph!
    January 2020
Posted by wpwar11 on Saturday, April 10, 2021 10:16 AM
Wow!  That dash is stunning.
    October 2019
Posted by Tanker-Builder on Saturday, April 10, 2021 10:19 AM
Hi;
 I was doing a lot of 1/24 Planes in paper. Using model car aftermarket bezels for the instruments and A product from Testors " Model Master " line called " Boyds Clear Coat".I would put in a drop or two, wait a day and put another layer on it and it looked just like the slightly domed effect that's shown on the Mephsistofele Dash that Don sent in the photo.
