Testors window maker cement
    October 2009
Posted by Khalee2 on Wednesday, November 11, 2009 12:47 PM
How are you suppose to use the stuff. It seemed allfull runny to me so I shook up the bottle, and tried again. now tho it looks milky,did I do wrong in shakeing it up.
 Unfourntently the directions on the bottle are hard for me to read. Black lettering on purple background and way to small.
 I am trying to fill in the spots for the landing lights and marker lights on my model which is  1/72 scale. I figured it would be easyer that way than trying to put the clear parts in.
    January 2012
Posted by I make stuff on Wednesday, November 11, 2009 2:22 PM
I have it but have only used it once.  Mine was milky, and runny, like a watered down Elmers white glue.
The instructions say to use the smooth rounded handle end (opposite the bristles) of a paint brush to make windows, I used it to make periscope covers on my Sherman, it took several tries to get the "bubble" to cover the entire area of the window and dry to actually cover the space.
I squirted some in a small receptacle so I could get a visible drop on the paint brush and just moved it around until it looked like the window was covered.  It did not work great, but it worked better than anything else I could think of, and the final product I got is good.
Hope this helps'
Bill
Posted by wjbwjb29 on Thursday, November 12, 2009 12:15 PM
get a drop on a toothpick and run the pick around your window frame until it starts filling in the area to the center and remove the pick and let dry it will dry clear.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    January 2006
Posted by dirkpitt77 on Monday, November 16, 2009 7:33 PM
     I'm not really a fan of it.  I thought it was a bit too runny and prone to bubbling.  I use Mod Podge.  It's much gooey-er  (is that a word?  LOL), but dries surprisingly clear.  You can get it at Hobby Lobby or Michaels.  My .02.
  Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
Posted by echolmberg on Thursday, November 19, 2009 2:52 PM
Chris,
Is there a particular aisle/section Mod Podge can be found?
Thanks!
Eric
    March 2005
Posted by mfsob on Monday, November 23, 2009 8:22 PM
I've had good luck with the stuff on 1/72 aircraft, but I use a long straightpin with the tip filed flat to apply it. It's supposed to look milky when it comes out of the bottle, so no worries there. Get a nice sized bead on the end of your applicator tool and run it all around the edge of your window so all of the edges are wet, then try to draw the remainder of the cement across the center. Go slowly, take your time and practice.
And also remember that this stuff is not good for HUGE areas, only up to about a quarter-inch square or so, but it also fills irregular shapes, as in the triangular bomb aimer's panel on this Betty bomber. I drilled out all 20-odd windows on this 1/144 model and used Testors clear parts cement for the windows and was pleased with the results:
    January 2006
Posted by dirkpitt77 on Tuesday, November 24, 2009 12:04 PM
    I didn't get mine in a particular aisle.  It was in a display rack up by the registers.  You could ask tho-I'm sure they'll know what you're talking about.  I think it's also used to seal puzzles.
  Chris
